RRF 3.6.0-beta2: www/DuetAPI.xml not found
Today I updated one printer to RRF 3.6.0-beta2. In the object model browser the documentation cannot be found. I had that with beta 1 as. There exists a DuetAPI.xml.gz. Unpacking this file helped in an earlier version, but not here.
@wschadow Are you running in standalone or SBC mode?
@wschadow I noticed this and flagged it to @chrishamm, also the 'indent comments' button is missing. I thought he fixed it (the commit is here: https://github.com/Duet3D/DuetWebControl/commit/4532d03c157fa6059c2c37c7719d9911468f5791) but perhaps it didn't make it into the current release.
Please can you make sure that DWC is updated to beta.2? Also whether SBC or standalone, as @gloomyandy says.
@wschadow They are definitely showing up in standalone mode:
And DuetAPI.xml.gz is in the DuetWebControl-SD.zip.
So I'm guessing you have an SBC setup, and something, probably DWC, hasn't updated.
@droftarts running in standalone mode
@gloomyandy standalone, see screenshots below
@wschadow Ah, yes, you're right, I'm seeing the same thing in the object browser. I do have /www/DuetAPI.xml (and the .gz version) on my SD card. @chrishamm is investigating.
@droftarts indent comments is working
@wschadow Thanks for reporting this. I've got a bug fix tested and working. Version 3.5 is not affected.
@chrishamm Thanks Christian. Thursday I'll be at formnext, maybe we see each other.
