    Z-Homing Race condition
    Duet Web Control
    • patrickwjoyceundefined
      patrickwjoyce
      Not sure if this is the right place to post this.
      Just today, I managed to accidentally create a z-homing race condition by telling my printer to Home all axes and then sending another command that caused the X and Y axes to not move to the z-homing location before attempting to home Z. the two sequences are listed below:
      Scenario 1: Use DWC to initiate "Home All", and then clicked "run mesh compensation" before homing had finished. This resulted in the printer failing to home z because my probe is off the build plate when the hot end is at the Y-home position.
      Scenario 2: I started a print (which included homing as part of the starting g-code), and then went to use Z-Babystepping. the same thing happened as before where the X and Y homed, but then failed to move before initiating Z-home routine.
      Is there a setting or configuration change I can do to prevent this from happening. I don't recall ever having this issue before (despite doing similar sequences), and its been at least a month or more since I last changed the firmware. The only config changes I made were to reorder M556, and adjust it's values.
      I'm running this FW config
        Can you share the gcode for your homing files?
        It would also be good if you could update the firmware to 3.5.3 and verify if the behavious is still the same.
        patrickwjoyceundefined 1 Reply Last reply Reply Quote 0
          patrickwjoyce @Phaedrux
          @Phaedrux sure thing here are all the home.g and my starting machine gcode.
          Also, its worth noting that I just had a similar issue with just starting a job (it didn't happen the second time I ran the job). so it might not be a race condition, and instead an issue somewhere else. I also disabled skew compensation entirely (M556) for now
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Oct 27 2023 16:48:23 GMT-0700 (Pacific Daylight Time)
          G91                      ; relative positioning
          G1 H2 Z5 F6000           ; lift Z relative to current position
          G1 H1 X-205 Y205.5 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y-5 F6000       ; go back a few mm
          G1 H1 X-205 Y205.5 F360  ; move slowly to X and Y axis endstops once more (second pass)
          G90                      ; absolute positioning
          G1 X40 Y9.5 F6000        ; go to first bed probe point and home Z
          G30                      ; home Z by probing the bed
          ;G91                     ; relative positioning
          ;G1 Z5 F100              ; lift Z relative to current position
          ;G90                     ; absolute positioning
          ; homex.g
          ; called to home the X axis
          G1 H1 X-205 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000    ; go back a few mm
          G1 H1 X-205 F360  ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-5 F6000   ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y205.5 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y-5 F6000    ; go back a few mm
          G1 H1 Y205.5 F360  ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          G1 X40 Y9.5 F6000 ; go to first probe point
          And here is my custom start g-code:
          M140 S[first_layer_bed_temperature] ; Set Bed Temp
          M190 S[first_layer_bed_temperature] ; Wait for Bed temp to reach target
          M104 S[first_layer_temperature] T0; Set extruder Temperature
          M109 S[first_layer_temperature] T0; Wait for extruder to reach set temp
          G28 ;Home
          M572 D0 S0.5; Enable Pressure Advance
          G29 S1 ;Load Heightmap and enable bed mesh leveling
          M376 H1; Taper mesh compensation after 2mm
          ;Prime the extruder
          G92 E0 ; Zero Extruder
          G1 X-1 Y-1 Z3; Move just outside origin and up 3mm,
          G1 E40 F500; Extrude 35mm filament
          G1 Z0.25 X50; Squash blob
          G92 E0; Reset Extruder position
          EagleB3undefined 1 Reply Last reply Reply Quote 0
          • EagleB3undefined
            EagleB3 @patrickwjoyce
            @patrickwjoyce , try starting your macros (homex.g, homey.g, homez.g) with command
            M400 S1 ; wait until motion stops, do not release any axes or extruders
