    Expected negative temperature rise
    • benecitoundefined
      benecito
      Never mind the error message and the fact that it is cut, but can someone please explain where a negative expected temperature rise is coming from?
      Does duet monitor the falling temperature if the bed is i.e. at 100°C and is then set to 60°C?
      Bed heater with "normal" PID values from an automatic tuning and firmware 3.4.6
        Where is that error message from? What printer?
        What was the printer doing when you saw it?
          dc42 administrators @benecito
          @benecito I think that is the minimum temperature rise expected, which is the calculated expected temperature minus a tolerance. The message generated by RRF gives the measured temperature rise too but that part appears to have been truncated.
          benecitoundefined 1 Reply Last reply Reply Quote 0
          • benecitoundefined
            benecito @dc42
            @dc42 If that's the case I will put all my duet printers into a self extinguishing cabinet right away. From my understanding this would mean a heater that might be at full power with no temperature rise will not trigger a heater fault?
            The end is truncated because the printer is still on 3.4.6 where the maximum length of the string is limited and needs to be passe don to RepetierServer.
              @benecito said in Expected negative temperature rise:
              That's correct, if all the following are true:
              • you set a temperature that is too high for the heater to reach (which may depend on the print cooling fan speed)
              • that temperature is lower than the temperature limit set by M143 (or the default if you didn't use M143 to set a temperature limit)
              • you have run tuning on that heater, so RRF knows that it shouldn't expect a temperature rise at that temperature
              • in heating up to that point, the measured temperature behaved in accordance with the model.
