Upgrading from 3.5.2 to 3.5.4 - Help request
I tried to upgrade the firmware version from 3.5.2 to 3.5.4 by uploading the zip file through the web interface. After that, the board became unresponsive. I walked through the fallback procedures, but I couldn't achieve success
The board is 6HC 1.02
.Appreciate any help
@ELAD Are you trying to flash the ZIP file with Bossa? If so, that's the wrong file. Unzip the zip file and use the "Duet3Firmware_MB6HC.bin" file with Bossa.
@droftarts
Ian thank you very much!
Problem solved
