    IDEX BOTH ON CORE XY
    MultiAxis Printing
    11.4k
    • dwuk3dundefined
      dwuk3d @o_lampe
      @o_lampe There are five few different G29's in the start GCODE - with what looks like some sort of conditional logic that is done by the printer -(rather than the slicer) using M1002's -
      • o_lampeundefined
        o_lampe @dwuk3d
        @dwuk said in IDEX BOTH ON CORE XY:
        It looks like the Voron Tap might be a possible solution - although it might not be accurate enough to take into account mesh adjustments if it just uses a servo.
        Yes, a servo wouldn't be the best option for mesh levelling. But there is another problem: You'd have to calculate the z-adjustment of the "mini-z axis" based on the current XY position of the other tool (which uses the classic mesh leveling) or have a mini-z axis on every tool.
        Unfortunately RRF allows only one z-plane and it doesn't provide "realtime" XY coordinates.
        You could direct the real z-motion to the main steppers (during layer change, homing etc.) and redirect the z-adjustments to the mini-z axes.
        Your post processor can easily detect, which is which:
        If there's no E(xtrusion) value in the gcode line it's a real z-move
        If you see a retraction/unretraction gcode with z-hop or a gcode line with extrusion, it's a mini-z thing.
        dwuk3dundefined 1 Reply Last reply Reply Quote 0
        • dwuk3dundefined
          dwuk3d @o_lampe
          @o_lampe agreed - will certainly try and pursue accurate independent Z adjustments for each print head. Both for z hopping and will also add mesh adjustment.
          Whilst ideally done by the firmware I guess it should be possible to take in for example 49 mesh probing adjustment points and apply them to the gcode for each print head - if necessary splitting long extrusion moves into smaller chunks if they span a bad area of the mesh.
          Auto mesh adjustments in the firmware would need to be turned off.
          Should be possible to test this out on my single headed printer.
          I presume the mesh adjusting would need to reduce as the height increases.
          • dwuk3dundefined
            dwuk3d @dwuk3d
            @dwuk Better version of my Sovol SV08 video - with a surprise 'revolutionary' mode at the end.
            IDEX Part 14 - SOVOL SV08 Upgrade ideas
            • dwuk3dundefined
              dwuk3d
              Updated post - after better understanding.
              Have started to spec up the electrics I am going to need for my proposed system - and the numbers of steppers is getting rather high.
              Looking at Duet Hardware it looks like I need a separate driver board for each extruder - presumably a 1LC - at about £43.50 each. - Will need 8 of those in the end - but only 4 initially.
              Then the AXIS drivers, plus extra Gantry etc - it looks like I am going to need a controlling £225 - 6HC board for the first 6 motors - with £112 Mini 5's for each set of 5 further motors. With finally I might be able to get away with a 3HC for the last 3 motors in phase 5.
              Is that correct - can I have for example a 6HC controlling 4 x Mini5 boards + a 3HC in the same system collaborating with each other?
              Illustration here - with the -a,-b etc. suffixes are extra board instances required.
              Have tried putting some of it into the system config tool - but am hitting some limits.
              • o_lampeundefined
                o_lampe @dwuk3d
                @dwuk Seems you've reached the end of the Duet3 galaxy...
                AFAIK there is no toolchanging system which keeps the extruder motor and only replaces the extruder.
                Although you can use a MMU like enraged rabbit.
                My hashprinter was happy with 11 stepper drivers on a Duet2 (5+2) with DUEX5.
                But Duet2 isn't ready for dual g-code streams. Maybe a post processor can make it happen, if it puts all moves in one file.
                • dwuk3dundefined
                  dwuk3d @o_lampe
                  @o_lampe hopefully Im not at the limits. It looks like a 6hc supports 16 extruders. The Mini5+ only supports 5 - so im hoping that it is what is affecting the configurator.
                  I may have to not use tool boards for some of the ectuders if that is what is causing the issue. They are quite expensive too.
                  I think I can get 7 steppers per mini5 too which will help.
                  Agree though that a tool changer which just switches the nozzle/hot end rather than the whole motor/extruder is attractive in terms of efficiency of parts as well as saving on stepper driver requirements.
                  Watched an interesting video recently by 'engineers grow' suggesting a way where this might be possible, or you can always cut the filament - and then swap the hot end like the swapper3d.
                  Re achieving multiple gantries on a non duet 6hc - I certainly think it is going to be possible (but maybe not as efficientky) by gcode post processing and combining both gantry moves into single g0/g1s for example. Or just using two independent controller boards which are controlled and synced externally.
                  SV08 arrived yesterday and working well.
                  Next stage now is to swap its normal single extruder operation over to a Duet3 6hc/while I am working on the design of the 2nd gantry,
                  Not sure whether to use a 1lc or Mini5+ to drive the extruder.
                  Probably best to use a mini5+ as 13 steppers is enough to get both gantries and 2 extruders fully working.
                  Whilst 1lc's are attractive in terms of wiring I think the need for z hopper stepper drivers makes them less useful.
                  • dwuk3dundefined
                    dwuk3d
                    First attempt at redesign of flying gantry to accommodate 2nd Y gantry
                    2nd Gantry would go at the back, with belts running 2.5mm inside the existing belts.
                    Would need to change the front idlers from 13mm to 18mm (if I can source some) - and shift a few of the pulleys inwards for the existing gantry.
                    Would lose a small amount of the build area.
                    New belts are in Red and Yellow
                    New drive motors inside the existing ones.
                    Screenshot 2025-01-08 at 12.03.14.png ![Screenshot 2025-01-08 at 12.03.58.png]
                    Updated with more detail and better routing around steppers
                    • o_lampeundefined
                      o_lampe @dwuk3d
                      Maybe now is the right time to start your own build thread? There you can reference your first entry from this thread, for people who want to read the whole prequel
                      dwuk3dundefined 2 Replies Last reply Reply Quote 1
                      • dwuk3dundefined
                        dwuk3d @o_lampe
                        @o_lampe Good suggestion - I was wondering if it would be better to be on a separate post.
                        I was expecting to get some feedback on Duet Board choices - but maybe it is too buried down in the detail - so will create a new post or two - with some specific questions about board choices.
                        I did think I would try starting one of the Sovol community group too - but it hasn't got much response yet
                        https://forum.sovol3d.com/t/sv08-double-gantry-parallel-printing-idex-project/6504/2?u=ukdavewood
                        PS/. Couldn't find any easy source of 18mm idler pulleys - so made a further redesign at the front to remove the need.
                        Have ordered basic parts that I won't be able to salvage from the two IDEX printers I have hardly turned on since I got my BambuLab X1Cs.
                        Next stage of the design is the Z hoppers.
                        • dwuk3dundefined
                          dwuk3d @o_lampe
                          @o_lampe Separate thread now created - over here
                          https://forum.duet3d.com/post/349140
                          Would be interested in your thoughts on how do to the Z hoppers.
