    WiFiSocketServerRTOS mismatch between project name and repo name
    Firmware developers
    • gtj0undefined
      gtj0
      I've been scratching my head trying to figure out why the latest RRF 3.5-dev fails to build with "MessageFormats.h not found" errors. It turns out that the repo (and therefore directory) name is WifiSocketServerRTOS with a lower case f in Wifi however, in the RRF project "C++ General, Paths and Symbols, Includes", the reference to that project directory is WiFiSocketServerRTOS with an upper case F in WiFi. Probably works fine under Windows but won't work under Linux.
      @dc42 Changing the repo/directory name isn't really a good idea at this point so can you change the reference in RRF to use the lower case version? That'd still work under Windows.
      I can submit a quick PR if you want.
        dc42 administrators @gtj0
        @gtj0 the repo name does use the capitalised F, see https://github.com/Duet3D/WiFiSocketServerRTOS. Perhaps your local copy uses a lowercase f ?
        • gtj0undefined
          gtj0 @dc42
          @dc42 said in WiFiSocketServerRTOS mismatch between project name and repo name:
          HA! Yeah your right but I just copied the link from https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
          It looks like the links on that page are wrong...
          [WiFiSocketServerRTOS](https://github.com/Duet3D/WifiSocketServerRTOS)
            T3P3Tony administrators @gtj0
            @gtj0 Thanks. I fixed those links
            gtj0undefined 1 Reply Last reply Reply Quote 1
            • gtj0undefined
              gtj0 @T3P3Tony
              @T3P3Tony said in WiFiSocketServerRTOS mismatch between project name and repo name:
              Thanks Tony!
              • Phaedruxundefined Phaedrux has marked this topic as solved
