    Many problems with 3.5.2
    Firmware installation
    944
    • 3DOesteundefined
      3DOeste
      I reflashed 3.5.1 and all the awkward delays are gone. Commands from panel due are instantaneous.
      With 3.5.2 everything works, but has a delay before commands are executed.
      So for now I'll stay with 3.5.1.
        droftarts administrators @3DOeste
        @3DOeste Did you update DWC to 3.5.2 as well? Possibly old DWC files in the SD card /www folder are causing an issue. Also worth clearing browser cache for DWC and the ip address of the printer, and reloading the page in the browser. It is possible that there was some problem with the flash to 3.5.2, so worth redownloading 3.5.2 fresh and reflashing, if/when you want to update.
        • 3DOesteundefined
          3DOeste
          Hi, I'm sure DWC was on 3.5.2, and also try again from 3.5.1 to 3.5.2 and I have the slow response from commands from panel due (and also from DWC), back to 3.5.1 again and everithing runs fine.
            @3DOeste A suggestion from @chrishamm is to update to 3.5.2 and disconnect the PanelDue, and see if that makes a difference to the responsiveness of DWC. How is the PanelDue connected? By 4-wire cable, ribbon cable, or both?
            • 3DOesteundefined
              3DOeste
              It's connected with a 4-wire cable. I'll test disconnecting the PanelDue as soon as the current print is finished.
                dc42 administrators @3DOeste
                @3DOeste instead of disconnecting the PanelDue it is sufficient to leave it displaying its Setup page.
                3DOesteundefined 1 Reply Last reply Reply Quote 0
                • 3DOesteundefined
                  3DOeste @dc42
                  @dc42 Hi, I tried that, and it works ok. Today I installed 3.5.3, same behaviour as 3.5.2, but if after homing, I enter the panel due setup page, and then back to status, everything works as it should, without weird delays. It doesn't happen with 3.5.1.
                  dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                    @3DOeste thanks for the feedback. We added a check in 3.5.2 to reduce the chance of consistently running our of buffers when both PanelDue and DWC are active. It appears that this check is having a side-effect in your system. I have created this issue https://github.com/Duet3D/RepRapFirmware/issues/1047.
                    dc42 created this issue in Duet3D/RepRapFirmware
                    closed Startup issues when PanelDue and DWC are both active #1047
                    • AlexKidundefined
                      AlexKid
                      Looks and sounds like the same issue I have.
                      https://forum.duet3d.com/topic/36643/randomly-reconnect-of-dwc-on-duet2-ethernet?_=1727016238232 isn't it? Started with 3.5.2 and also present with 3.5.3.
                      • AlexKidundefined AlexKid referenced this topic
                        T3P3Tony administrators @3DOeste
                        @3DOeste please would you test this with 3.6beta3 RRF and 3.5.1 Paneldue firmware:
                        https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
                        https://forum.duet3d.com/topic/37179/paneldue-firmware-3-5-1-released
                        these together should have resolved this issue.
                        • 3DOesteundefined
                          3DOeste @T3P3Tony
                          @T3P3Tony Hi Tony, I tried but 3.6beta3 wroke connection with DWC, I'm trying to fix it now.
                          droftartsundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                            @3DOeste There's a bug with 3.6.0-beta.3 on Duet Ethernet boards. See https://forum.duet3d.com/post/350049 for updated version.
                              @3DOeste I was not sure ,from the other thread, if this is also fixed for you?
