[3.6.0-beta.3] DWC connection issues Duet2 / Duex5
@timschneider if you enable all Move debugging in recent versions of RRF then huge amounts of debug output are generated, which means all bets are off. M111 should only be used to enable debugging selectively, using the P and D parameters so select the modules and subsystems to debug.
Duet 2 is somewhat memory constrained so it has less output buffer memory available than Duet 3 boards. That said, it does appear from the output you have posted that there may be a particular issue with the interface to the WiFi module when there is a lot of data to output. This is on my list to investigate.
@dc42 @chrishamm
thank you both for your time and patience.
I moved forward with the knowledge of the low memory issue and reprogrammed the python client to be a fully fledged digital twin of the duet printer as per object model. In order to archive this I followed the description of M409 and implemented thea
andnext
handling aswell as theseqs
handling. So what I do now is, poll the rr_model endpoint with key=seqs
to keep track of the sequence numbers and keep the load on the duet as low as possible. If a change happens, it will act accordingly, e.g. fetch a reply or partially fetch the updated object model recursive with max depth oflevel + 1
, again to keep the load as low as possible.but even that didn't solved the problem - it appears in some cases to make it even worse (i guess two output buffers per json response)
In the following there is one DWC Client and one python client connected.
Anyhow I wanted to understand the problem and at least find a workaround, but I was not able to.
What I found was that on an error - DWC is doing a reconnect straight, which makes it even worse, as this will increase the number of connected clients and will leave gcode replies unreceived and the buffer allocated, I guess?
Using the same macro as above. Directly after sending the command, the following rr_model request in DWC will fail - python client will also receive a HTTP 503 busy and will backoff 5 sec. before even trying to do anything (leaving the session open / timeout=8s - and leaving the reply probably not fetched for this session / due to the 503 busy response). DWC will open a new session and the internal connected clients count is increased, still keeping the buffer allocated. DWC tries to fetch a rr_model and will fail again with HTTP 503 - again reconnect / client count +1 / buffer allocated and so on ...
The last rr_reply in the timeline is empty - and the reconnect and following rr_model request are successfull.
Maybe it is possible to change the behaviour of the DWC reconnect mechanism and check if the HTTP response is 503 - wait and do not reconnect and on the duet side if multiple json requests fail - drop pending gcode replies? Or as an alternative always serve the rr_model seqs requests to give a client a chance to consume rr_reply to free up output buffers. Just randomly polling the rr_reply endpoint will steal the response from DWC, so thats also not an option.
@timschneider
wow that did the trick, when the python client receives an 503 it will just query the rr_reply immediately until the response is empty to free up buffers on the duet - DWC will not reconnect and everything workseven with
M98 P"0:/macros/test-bufferoverflow3.g"
, but DWC will sometimes not receive the output of that macro as the python client consumed both replies.It will even survive
M98 P"0:/macros/test-bufferoverflow4.g"
Using this method having 6 concurrent DWC connections open and one python client is no problem anymore - it will even work with the
Edit: there is still some problem in data and memory management, sometimes i do receive partial data
Response payload is not completed: <ContentLengthError: 400, message='Not enough data for satisfy content length header.'>
due to connection closing mid transmitting from duet to the reverse proxy. -
@timschneider What do you have "AJAX retries" in the DWC settings set to?
@chrishamm
Damn! This really looks promising!https://github.com/Duet3D/RepRapFirmware/commit/a3498d31aa746d0486e5a109c091f15a8b8e41c0
This could explain all the issues we and our customers have been facing – what could be described as DWC instability.
We use object labels in every print, most of our customers have a large file list, most print jobs take longer than a day, often 3-5 days. I am really excited and looking forward to trying this out! -
@timschneider Please give it a try then. Do you need a firmware binary for testing?
@chrishamm if you have one at hand, that would be nice. If not, I can compile my own withing the next days.
@chrishamm
Hi Chris,Thank you for your prompt reply and the in-depth solution. The fix does indeed help alleviate the ‘M122 M122 M122’ issue. Calling ‘M122 M122 M122 M122 M122 M122 M122’ sometimes still causes the web server to crash (will not recover), and calling ‘M98 P"0:/macros/test-bufferoverflow4.g"’ twice resets the connection. With 3 open sessions, all DWC.With only two open DWC sessions it can still recover the
. CallingM98 P"0:/macros/test-bufferoverflow4.g"
will still reconnect DWC.
With only one session it will just reconnect with the M122 bomb and I'm unable to get it disconnected with theM98 P"0:/macros/test-bufferoverflow4.g"
.So I think part of the problem is fixed and it feels like 80% fixed – 20% left and it is somehow related to multiple client sessions.
I will be in the office tomorrow to get some usb logs.
It is maybe worth to consider if RRF is low on OutputBuffers not to concat the gcode replys of multiple requests but instead drop the previos reply.
Btw. with my special python client connected (calling rr_reply as fast as possible when receiving the first HTTP 503) I am not able to get it crashed nor disconnected now.
Edit:
I stumbled over theMinimumBuffersForObjectModel
and therr_model
request is checking if there are free buffers available, but what will happen the other way around? Like, query a rr_model and then from another socket a rr_gcode with large response in rr_reply?Tim
@timschneider said in [3.6.0-beta.3] DWC connection issues Duet2 / Duex5:
That's what happens. For the same reason the last M122 output is likely truncated if you send multiple M122s at once.
I stumbled over the MinimumBuffersForObjectModel and the rr_model request is checking if there are free buffers available, but what will happen the other way around? Like, query a rr_model and then from another socket a rr_gcode with large response in rr_reply?
rr_model waits half a second if it cannot allocate enough memory for the response and if it fails, HTTP 503 is returned. In that case a client should request the reply to free up the buffers again ASAP. I still think it would be good to add a new parameter to rr_connect to make RRF discard G-code replies for particular clients.
@chrishamm hm i don't know -
@chrishamm said in [3.6.0-beta.3] DWC connection issues Duet2 / Duex5:
that would solve the problem with bot clients - but I was connected with two or three DWC sessions only.
Maybe add a timeout to rr_reply, after 500ms or 1s the reply will be discarded regardless of if it was fetched or not?! But anyhow maybe the problem is somewhere else, I was just speculating, because the problem now appears only with multiple sessions. -
i tried to digg deeper into it and it looks like this is working even with multiple clients, but there is a behaviour I would not expect from RRF. It will serve the reply even after a reconnect / 3 timeouts (HTTP 503 on rr_model).
Maybe the firmware can drop pending gcode replies if it is short on memory and not able to serve multiple rr_model requests?
Maybe instead of dropping, turncat and leave a message why this happend. Like, "This is your response ... (turncated due to low memory)" that the pending reply will fit into exactly one output buffer.Or maybe concider setting
clientsServed++;
on connect of new clients, why whould a new client be interested in an old pending reply?Guess that would help and only minor impack normal operation (will not happen on single client connections, and on multi client connections just sometimes for large replies)
