No more http available
im having the below error
[[language]] Could not connect to Duet, because there are no more HTTP sessions available.
my fix is by restarting the duet by pulling the plug.
should the web server and interface be updated too?Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.20.1RC1 (2017-12-31)
WiFi Server Version: 1.20
Web Interface Version: 1.20 -
Those versions are all compatible, however there is also DuetWiFiServer 1.20+1 available now.
That error message should normally only occur if you already have 4 different browser sessions connected to the Duet and you try to connect a 5th.
Next time it happens, please connect the printer to your PC via USB and get an M122 report.
okay. thanks David.
will keep on monitoring.
