SBC plugin to backup Duet3d files - duetBackup
Added some embelishments and tidy up.
V1.1
- Added some status messages, sent to DWC
- Next backup time is displayed using local time (previously GMT)
- Added
-duetPassword
for folks that use a password - Added
-verbose
to enable more detailed log messages.
undefined droftarts referenced this topic
V1.2
Some improvements that facilitate two modes of operation (see desription in iniial post above). Better identification of when individual files were Added, Updated, etc
- Added
-noDelete
option - Compares files to determine if an update is needed.
- Added date / time of last change to file (except initial save).
- Added
V1.3
README.md
file shows date and time of last backupREADME.md
prevented from being deleted- Added
-ignore
. Can specify files that are not to be backed up. This also causes these files to be deleted unless-noDelete
is set.
@stuartofmt Thanks for your effort, please consider submitting it to https://plugins.duet3d.com/ as well
@chrishamm said in SBC plugin to backup Duet3d files:
Hi. I have tried to submit it but it gets summarily rejected. My guess is that its looking for a specific folder structure on github ... (or something) ... The submission instructions are unclear on this aspect.
I have raised an issue (twice) on github. I asked about the problem on the forum (11 days ago) and it was refered to @yasas but there has been no reply.
@stuartofmt Oh, sorry to hear, I'll make sure this is addressed ASAP.
@stuartofmt The reason why it cannot be approved is because there is no GitHub release on your repository:
You must create one before you can submit it on the plugin repository. Note that this release must contain your plugin ZIP since that is linked by the plugin repo.
@stuartofmt Hi @stuartofmt I'm sorry to hear this I have missed the GH issues as for some reason they have been closed/wasn't notified. I will update the error messages in case someone else runs into the same issue.
@stuartofmt I am on 3.5.4 with SBC on Bookworm RPi. I cannot install the plug-in due to the following error:
Failed to install package PyGithub==2.1.1, package manager exited with code 67
I tried to apt install it but apt cannot find it in the default repos.
TLDR; You need to be using Duet V3.6.0+ (or not use Bookworm)
Bookworm introduced some new requirements for installing python programs and modules. They need to be installed in a virtual environment. In practice, this means a virtual environment for each plugin (so they don't stomp on each other).
The plugin manager in V3.6 uses an installer that takes care of this, version 3.5 does not.Unless installing deliberately into the system environment - you should not be using apt for python packages. I suspect there are other safeguards in place as well.
On my system (SBC, Bookworm, Duet 3.6.0 - beta.4) - trying to install into the system environment, using pip, I get the expected warning
pi@srsender:~ $ python -m pip install "PyGithub==" error: externally-managed-environment This environment is externally managed To install Python packages system-wide, try apt install python3-xyz, where xyz is the package you are trying to install. If you wish to install a non-Debian-packaged Python package, create a virtual environment using python3 -m venv path/to/venv. Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make sure you have python3-full installed. For more information visit http://rptl.io/venv note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages. hint: See PEP 668 for the detailed specification.
The required version of pyGithub is however available:
pi@srsender:~ $ python -m pip index versions PyGithub WARNING: pip index is currently an experimental command. It may be removed/changed in a future release without prior warning. PyGithub (2.5.0) Available versions: 2.5.0, 2.4.0, 2.3.0, 2.2.0, 2.1.1, 2.1.0.post0, 1.59.1, 1.59.0, 1.58.2, 1.58.1, 1.58.0, 1.57, 1.56, 1.55, 1.54.1, 1.54.0.1, 1.54, 1.53, 1.52, 1.51, 1.50, 1.47, 1.46, 1.45, 1.44.1, 1.44, 1.43.8, 1.43.7, 1.43.6, 1.43.5, 1.43.4, 1.43.3, 1.43.2, 1.43.1, 1.43, 1.40, 1.39, 1.38, 1.37, 1.36, 1.35, 1.34, 1.33, 1.32, 1.31, 1.30, 1.29, 1.28, 1.27.1, 1.26.0, 1.25.2, 1.25.1, 1.25.0, 1.24.1, 1.24.0, 1.23.0, 1.22.0, 1.21.0, 1.20.0, 1.19.0, 1.18.0, 1.17.0, 1.16.0, 1.15.0, 1.14.2, 1.14.1, 1.14.0, 1.13.1, 1.13.0, 1.12.2, 1.12.1, 1.11.1, 1.11.0, 1.10.0, 1.9.1, 1.9.0, 1.8.1, 1.8.0, 1.7, 1.6, 1.5, 1.4, 1.3, 1.2, 1.1, 1.0, 0.7, 0.6, 0.5, 0.4, 0.3, 0.2, 0.1, 0.0.0
@stuartofmt Thanks. I ran into the venv elsewhere so that makes sense. I will move to 3.6.
undefined stuartofmt marked this topic as a question
undefined stuartofmt has marked this topic as solved
