    Laser Output
    Laser Cutters
    725
      jay_s_uk @Macwolf
      @Macwolf IIRC, the 5KHz came from previously available information from when people were converting the K40 away from the original controller to boards that use GRBL etc
      • Macwolfundefined
        Macwolf @jay_s_uk
        @jay_s_uk
        Out 1 is now the output for the laser, it doesn't deliver a negative signal, does it?
        further connections are needed.
        1. 5V for TH
        2. ground
        3. I simulate the cooling.
        where exactly should I connect these cables to the power supply terminal
          dc42 administrators @Macwolf
          @Macwolf said in Laser Output:
          OUT1 is an open-drain output, suitable for connecting to an active low input with internal pullup on the laser module.
          The output on the VFD/Laser connector is active high, suitable for connecting to an active high input on the laser module. It should be low when the Duet is powered on. However, when no power is supplied to the Duet you may find that it floats high enough to trigger the laser. if that happens then try connecting a 1K pulldown resistor between the output and ground.
          What type of control input does your laser module have?
          Macwolfundefined 1 Reply Last reply Reply Quote 0
          • Macwolfundefined
            Macwolf @dc42
            @dc42 my power supply is from the same manufacturer as the tube I have a diagram, but the description is in GermanBildschirmfoto 2025-02-09 um 16.22.00.png
              jay_s_uk @Macwolf
              @Macwolf thats the same as PSU type 1 shown in the wiring diagram on the page I linked you to earlier (https://github.com/TeamGloomy/LPC-STM32-RRFUserConfigs/tree/master/K40 CO2 Laser - SKR 2 - ESP - paulg4h) so it would be wired in the same way i.e. to heater ground
              • Macwolfundefined
                Macwolf @jay_s_uk
                @jay_s_uk yes that's true, but there is no line from the contacts to the board and I don't want to try until it works
                  jay_s_uk @Macwolf
                  @Macwolf to the "L" connection like the PSU type 2
                  • Macwolfundefined
                    Macwolf @jay_s_uk
                    @jay_s_uk and the others there are more connections like 5v, p+ gnd ......where are these connected to the duet board?
                      jay_s_uk @Macwolf
                      @Macwolf which others are you talking about?
                      • Macwolfundefined
                        Macwolf @jay_s_uk
                          jay_s_uk @Macwolf
                          @Macwolf do you see those connected anywhere on the PSU type 2 to the SKR2 board?
                          • Macwolfundefined
                            Macwolf @jay_s_uk
                            @jay_s_uk no only these control the tube
                              jay_s_uk @Macwolf
                              @Macwolf ok then. so you just need to connect the "L" connection to the duet. You will need to connect a ground connection, like on PSU type 2, to your power supply powering your duet
