    Heater Fault - Using old style E3D v6 hotend
    3.1k
      Which firmware version are you using?
      • TinkerBillundefined
        TinkerBill
        RepRapFirmware-1.19
        • timcurtis67undefined
          timcurtis67
          I had the same thing happen to me with me during a recent autotune. I ended up adding a p1.0 in the m303 command and had no more issues. example M303 H1 P1.0 S240
          I'm running Duetwifi with 1.19 firmware.
            TinkerBill
            Tried M303 H1 P1.0 S240 - got to 211 then timed out. I'm wondering if the replacement blocks are made from a less heat conductive material? Then I'd need to increase the time allowed? Plausible?
              deckingman
              @TinkerBill:
              ….....................I'm wondering if the replacement blocks are made from a less heat conductive material? ............... Plausible?
              More than possible if the blocks are, shall we say clones of oriental origin. I once tried to help someone who had similar problems with a Diamond hot end clone. It turned out that instead of being made from brass, the hot end was made from brass plated steel of some sort. Brass has a thermal conductivity of about 120 Watts\Kelvin Metre and steel about 45, hence the problem. Aluminium is better than both at about 235.
                TinkerBill
                Ok… so on the assumption that it's taking longer due to me being broke/cheap rather than a fault (as it is heating up, just not quickly) what do I change? I would guess "M570 S180" as the description states it is basically defining how long the hot end can take?
                  deckingman
                  Before we get on to that, can you check your M143 in config.g to see what the limit is set to. You should have something like M143 Snnn. If nnn is set to 210, that would explain why it times out at 210 deg C.
                    TinkerBill
                    M143 is set to 290
                      It sounds to me that the heater is under-powered. Might you be using a 24V heater cartridge on a 12V system?
                        TinkerBill
                        @dc42:
                        The heater and power supply are both 12v
                          deckingman
                          One final thing to check. As you've changed the thermistor, have you got the correct values in M305 for that new thermistor? The only other possibility that I can think of is that it might be the cartridge itself. Do you have another that you can try?
                          You could try setting a lower target temperature but it's a bit like having a warning light appear on the dashboard of your car, and putting a bit of tape over it. It hides the warning but the underlying problem is still there.
                            TinkerBill
                            Well the new thermistor is 100k ohm, same as the thermistor cartridge. Also, the ir thermometer I have says it's accurate to within 5 degrees, so probably just tolerance difference.
                              TinkerBill
                              My config file doesn't have a M307 line, are the values on http://reprap.org/wiki/G-code#M307:_Set_or_report_heating_process_parameters worth using?
                              Sorry if these are dumb questions - not much software experience…
                                deckingman
                                I'm not sure what default values duet uses but they should be "good enough". Run M307 without any parameters and it will report what is in use. If the gain (the "A" value) is low, you could try setting it higher.
                                  TinkerBill
                                  I sent a M307, didn't get anything back… Probably the problem then?
                                    deckingman
                                    Sorry my bad. You need to add the heater number. H0 is the bed and H1 is the first hot end, so M307 H1 should report what's in use.
                                      TinkerBill
                                      Should have tried that myself, no worries.
                                      SENDING:M307 H1
                                      Heater 1 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.00, mode: PID
                                      Computed PID parameters for setpoint change: P13.4, I0.095, D51.4
                                      Computed PID parameters for load change: P13.4, I0.949, D51.4
                                      Is there anything wrong here? Reaally don't know what I'm looking for 😕
                                        deckingman
                                        Those number don't look far out IMO - not enough to cause the problems you are having. Everything is pointing to your heater block as that's the only other thing you have changed and it's after that change that things went awry. It's possible that you have a "lazy" heater cartridge. Do you have spare you can try? One other thing, can you hands on any copper grease? If you coat the heater cartridge in that, it will help thermal transfer between the cartridge and the block. Just a thought…..
                                          TinkerBill
                                          I've not got a spare heater cartridge, will try the copper grease. If that doesn't work, what bodge could I do to just stop the software worrying about the time taken to heat up? Rather not order another new heater cartridge…. (again I'm cheap/broke)
                                            deckingman
                                            @TinkerBill:
                                            Like I said, that would be like putting a bit of sticky tape over a warning light on your car dashboard. It will hide the warning light but the problem still exists. You could for example send M302 to enable cold extrude but it still won't print.
