    SBC may be overloaded
    • jltxundefined
      jltx
      I had a print abort right in the middle. Never seen this before. I am on 3.6.0-rc.1+2. I have printed several hours successfully on this version. How to go about debugging this?
      • Macgyverundefined
        Macgyver
        There is an additional logger you can use to gather more information.
        https://docs.duet3d.com/User_manual/Troubleshooting/Logging
        Here is the basic layout of the command.
        M929: Start/stop event logging to SD card
        When event logging is enabled, important events such as power up, start/finish printing and (if possible) power down will be logged to the SD card. Each log entry is a single line of text, starting with the date and time if available, or the elapsed time since power up if not. If the log file already exists, new log entries will be appended to the existing file.
        Parameters
        P"filename" The name of the file to log to. Only used if the S1 parameter is present. A default filename will be used if this parameter is missing.
        Sn S1 = start logging, S0 = stop logging (RRF <= 3.2.0)
        Sn S0 = stop logging, S1 = log level WARN, S2 = log level INFO, S3 = log level DEBUG (RRF >= 3.2.0)
        Examples
        M929 P"eventlog.txt" S1 ; start logging warnings to file eventlog.txt
        M929 S0 ; stop logging
        Only use it when you need it as it does really beat up on your SD card or I/O access
        • chrishammundefined
          chrishamm administrators @jltx
          @jltx M929 isn't really needed in SBC mode because journald already keeps track of most important messages. When did you flash your microSD card? Is it rated A1 or A2? Can you confirm that vcgencmd get_throttled via SSH/terminal outputs 0x0 (not throttled)?
          If you are still using the Debian Buster-based image, it's time to upgrade: https://docs.duet3d.com/en/How_to_guides/SBC_Buster_to_Bookworm
          Duet software engineer
          jltxundefined 1 Reply Last reply Reply Quote 0
          • jltxundefined
            jltx @chrishamm
            @chrishamm said in SBC may be overloaded:
            I am using A2 card with Bookworm. I did get 0x0 output. I have not seen this after the first occurrence. Where does the journald log go? /var/log?
              @jltx You can access logs using journalctl (e.g. journalctl -u duetcontrolserver -e) but I doubt anything else will show up there. Do you have any other applications running on your SBC? The message you got means something blocked the main process on the SBC from performing a data transfer.
