Printer Not hitting any of the endstops
@jay_s_uk ```
code_text; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Feb 26 2025 14:22:18 GMT-0500 (Eastern Standard Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"Duet 3" ; set hostname ; Accessories M575 P1 S1 B57600 ; configure PanelDue support ; Network M551 P"Password1" ; set machine password M552 P192.168.1.20 S1 ; configure Ethernet adapter M553 P255.255.255.0 ; set netmask M554 P192.168.1.254 ; set gateway M586 P0 S1 ; configure HTTP ; Wait a moment for the CAN expansion boards to become available G4 S2 ; Smart Drivers M569 P0.0 S0 D2 ; driver 0.0 goes forwards (X axis) M569 P0.1 S0 D2 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S0 D2 ; driver 0.2 goes forwards (Z axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1 Z0.2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X2800 Y2800 Z6000 ; set axis driver currents M92 X53.33 Y53.33 Z400 ; configure steps per mm M208 X0:1060 Y0:530 Z0:1000 ; set minimum and maximum axis limits M566 X3000 Y3000 Z60 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders M584 E0.3 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E450 ; set extruder driver currents M92 E2682 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ; Probes M558 K0 P1 C"io5.in" H2.5 F120 T6000 ; configure analog probe via slot #0 G31 P500 X0 Y0 Z3.5 ; set Z probe trigger value, offset and trigger height ; Kinematics M669 K0 ; configure Cartesian kinematics ; Endstops M574 X1 P"io3.in" S1 ; configure X axis endstop M574 Y1 P"io1.in" S1 ; configure Y axis endstop M574 Z1 P"io2.in" S1 ; configure Z axis endstop ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed Set 0" T200000 B3950 C6.370029e-8 ; configure sensor #0 M308 S1 P"temp1" Y"thermistor" A"Heated Bed Set 1" T200000 B3950 C6.370029e-8 ; configure sensor #1 M308 S2 P"temp2" Y"thermistor" A"Roto Internal Temp" T100000 B4267 C7.046861e-8 ; configure sensor #2 M308 S3 P"121.temp0" Y"thermistor" A"Roto Extruder Temp" T100000 B4267 C7.046861e-8 ; configure sensor #3 ; Heaters M950 H0 C"out1" T0 ; create heater #0 M143 H0 P0 T0 C0 S120 A0 ; configure heater monitor #0 for heater #0 M307 H0 R0.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0 M950 H1 C"121.out0" T3 ; create heater #1 M143 H1 P0 T3 C0 S300 A0 ; configure heater monitor #0 for heater #1 M307 H1 R0.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 M950 H2 C"out2" T1 ; create heater #2 M143 H2 P0 T1 C0 S120 A0 ; configure heater monitor #0 for heater #2 M307 H2 R0.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #2 ; Heated beds M140 P0 H0 ; configure heated bed #0 M140 P2 H2 ; configure heated bed #2 ; Tools M563 P0 S"Roto Toolboard" D0 H1 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ; Fans M950 F0 C"out0+out5.tach" ; create fan #0 M106 P0 C"Roto Fan" S0 B10 H2 T60:59 ; configure fan #0 ; Miscellaneous T0 ; select first tool ; Custom settings ;E-Stop M950 J4 C"!^io4.in" M581 P4 S0 T0 R0 Sorry File mustve not fully sent they are configured
@rodneysramosj our printer is 1220 by 610mm and yes the steps are correct it moves 10mm when told
@droftarts yes they are on the low end of the printer and in my other replies there is the correct config file and it is the one we are actively using.
@rodneysramosj said in Printer Not hitting any of the endstops:
this shows your printer only being 1060mm wide. This number should be the same as the maximum print size, otherwise your motors will end up moving short
@jay_s_uk said in Printer Not hitting any of the endstops:
M208
We have set the dimensions correctly in the g code and has not resolved the issue and the printer only gives a slight movement in all directions depending on the home and says that it is home and hasn't hit any estops.
@rodneysramosj have you tested the endstops?
You can either look at DWC for this, a green box appears on each axis letter to show you its triggered, or use M119.
They should show not triggered when not pressed and triggered when pressed.
If they are the wrong way round, you will need to invert them by adding a ! to the pin name for each applicable endstop -
@rodneysramosj As @jay_s_uk said, and I already posted, check the endstops are functioning correctly: https://docs.duet3d.com/en/How_to_guides/Commissioning#h-8-check-endstops
@jay_s_uk endstops are wired correct and they are triggering correctly through config. however, it is moving in the wrong direction now and in the opposite direction from the endstops. we tried changing it in the config tool from low end to high end and now they are currently swapped back after troubleshooting.
If the movement is not towards the end-stops you need to check your homing code to see if it is using moves in the correct direction.
@fcwilt we got it to a point where it hits the endstops but it stays stopped on the endstops and doesnt come back out.
Does your code command it to back out?
@fcwilt were trying to make it retract here is our code it is currently hitting the end stop and then continues to go past the Endstop until the endstop is hit again then it fully stops. changing the back off distance from positive to negative doesn't change the way it moves. it is currently set to 5 for visibility. we are testing the endstops by hand and not by carriage. ```
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Mar 19 2025 10:03:37 GMT-0400 (Eastern Daylight Time) ; increase Z ;G91 ; relative positioning ;G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed ;G90 ; absolute positioning ; home X G91 ; relative positioning var maxTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm G1 H1 X{var.maxTravel} F1200 ; coarse home in the -X direction G4 P500 G1 X-75 F6000 ; move back 5mm M400 G1 H1 X{var.maxTravel} F300 ; fine home in the -X direction G90 ; absolute positioning ; decrease Z again ;G91 ; relative positioning ;G1 H2 Z-5 F6000 ; move Z relative to current position ;G90 ; absolute positioning ``` -
@rodneysramosj Is the X endstop a max endstop or min endstop? Currently your G1 H1 X... homing moves are positive, so should be moving to the right, towards a max endstop. If this is wrong, you probably need to check the direction the motors are moving is correct, see https://docs.duet3d.com/en/How_to_guides/Commissioning#h-10-check-stepper-motors
Your printer origin X0 Y0 Z0 should be in the front left corner. Positive X moves should move the nozzle to the right, positive Y moves should move the nozzle towards the back.
