Configurazione bl touch antclabs
Buonaseara, ho montato bltouch sulla mia scheda duet 2 ethernet . firmware version 2.03 , web interface version 1.22.6 la spiegazione letta mi mi dice di utizzare canale heater3 pin 8 sul configuratore rrf version 3.4 mi fa decidere dal menĂ¹ a tendina E3 ma non funzyina.
ricaricando il file jonson lo ritrovo impostato a E2.
Gentilmente potreste aiutarmi come risolvere.
Grazie -
Good evening, I mounted bltouch on my duet 2 ethernet card. firmware version 2.03, web interface version 1.22.6 the explanation read tells me to use channel heater3 pin 8 on the rrf configurator version 3.4 it makes me decide from the drop-down menu E3 but it doesn't work.
reloading the jonson file I find it set to E2.
Please could you help me how to solve it.
ThanksYou should use E2 (extruder 2). Heater numbers are from H0, which is 'bed heater'. So E0 = H1, E1 = H2, and E2 = H3, and you want to use H3 'heater 3' pin.
It's possible that the json file does not save the probe pin, and you will need to set it each time you go back to the RRF config tool. This won't be fixed, as we are no longer maintaining the old RRF config tool.
Consider updating RRF to the current version, see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-from-older-firmware-versions
BUONASERA GRAZIE PER L'AIUTO, HO INSTALLATO FIRMWARE VERSIONE 3.3 ANCORA PEGGI NON FUNZIONANO NEMMENO I RISCALDATORI PROVERO' LA VERSIONE 3.5.4 , TENGO A PRECISARE CHE DAL 2020 LA STAMPANTE ANDAVA BENE, ANCHE NON ESSENDO UN VETERANO HO DECISO DI MONTARCI IL BLTOUCH.
QUANDO CONFIGURO RRF IL FINECORSA DELLA Y FACCIO BENE A DISABILITARLO O PUO' ANCHE RESTARE COME SICUREZZA, ANCHE CON LA NUAVA VERSIONE FIRMWARE IL PIN 8 DELLA PORTA DI ESPANZIONE HEATER E NON FUNZIONA ,SE CONFIGURO SULLA PORTA HOT AND E1= AD E2 IL FILO LO DEVO COLLEGARE SU E1 PWM V_IN ?
EVENTUALMENTE E' CONSIGLIABILE PASSARE AL FIRMWARE 3.6 SU DUET2 ETERNET.
grazie tanto per l'aiuto -
@perfetto said in Configurazione bl touch antclabs:
Good evening thanks for the help, I installed firmware version 3.3 even worse the heaters do not work I will try version 3.5.4, I would like to point out that since 2020 the printer was working fine, even not being a veteran I decided to mount the bltouch on it.
Please post your config.g, and the response to M122. When you update to RRF 3.x, you have to update the config.g, as RRF 3 is different from RRF 2. You can downgrade back to RRF 2 if you find it too difficult. See https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
Ideally, update to the latest release 3.5.4, then use the configuration tool to make a new configuration set of files. Then we'll help you fix the issues.
When I configure RRF the limit switch of the Y am I right to disable it or can it also remain as a safety device,
Endstops are only used during homing moves, so most of the time they are disabled anyway. You can set them up as 'triggers', so that they pause the machine if they are touched. See https://docs.duet3d.com/User_manual/Reference/Gcodes#m581-configure-external-trigger
even with the new firmware version the pin 8 of the heater expansion port and it does not work, if I configure on the hot port and e1 = to e2 do I have to connect the wire to e1 pwm v_in?
Are you following the guide here? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_BLTouch
See also the BLTouch troubleshooting guide here: https://docs.duet3d.com/en/User_manual/Troubleshooting/BLTouch_troubleshooting
Again, seeing your config.g would help. Make sure your deployprobe.g and retractprobe.g are correct, too.Possibly it is advisable to switch to firmware 3.6 on Duet 2 Ethernet.
Yes, Duet 2 Ethernet will be supported by firmware 3.6, but it is still in beta at the moment. It should be releasing soon, though. Your config from 3.5.4 should work with 3.6 without changes.
@droftarts Buonasera, ho caricato il firmware 2.05.1 se voglio agganciare il filo giallo del bl touch ei =a e2 del configuatore rf devo utilizza il pin pwm v_ in o al pin +3.3 V.
grazie -
Good evening, I loaded the firmware 2.05.1 if I want to hook the yellow wire of the bl touch ei =a e2 of the rf configurator I have to use the pwm v_ in pin or the +3.3 V pin.
The yellow wire is the control wire for the BLTouch. It should connect to a PWM pin, usually heater 3.
E2 in the configuration tool is heater 3. This is referred to as M307 H3 in the firmware and config.g and M280 P3 in deployprobe.g and retractprobe.g.
Your wiring should be:
Duet Z Probe connector pin Duet expansion connector pin BLTouch pin Colour IN Out White GND GND Black 5V (pin 1) +5V Red Heater3 (pin 8 ) Control Orange or Yellow GND (pin 2) GND Brown or Blue Your configuration should be
in config.g; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
in deployprobe.g
M280 P3 S10 I1
In retractprobe.g file
M280 P3 S90 I1
If you are still having problems, post a picture of your wiring at the BLTouch end, and at the Duet end.
Grazie ci provo
@perfetto it is possible the wiring colours are different, or reversed. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_BLTouch#pinout-and-wire-colours
BUONGIORNO , HO INSTALLATO DI NUOVO FIRMWARE 2.05.1
FIRMWARE DUET WEB CONTROL 2.0.7
HO PROVATO A MODIFICARE COME DA FOTO INVIATE MA L'ERRORE PERSISTE, CON LA VERSIONE 2.05.1 IL CONTROLLO TEMPERATURA FUNZIONA.
VERSIONE PCB REVISION: 1.04C
TI INVIO FOTO DI TUTTO, SEMPRE GRAZIE PER LA DISPONIBILITA'
Good morning, I installed firmware 2.05.1 again
Duet web control firmware 2.0.7
I tried to modify as per the photos sent but the error persists, with version 2.05.1 the temperature control works.
PCB revision version: 1.04c
I will send you photos of everything, always thanks for your availabilityPlease copy and paste the TEXT of your config.g into the reply, do not post pictures of text files. I need to see the full config.g because of this error: "Error: M280: Invalid servo index 3 in M280 command"
I think you have defined H3 as a heater, after the Z-Probe section, which stops the servo working. Please send
M307 H3
and post the response. It should say "Heater 3 is disabled". If not, something else in your config.g is defining H3.Please also send
M122
, and post the responses.As far as I can see, your wiring looks correct. I can see that the BLTouch is lighting up red, so it is getting power. When you turn on the power, does the BLTouch turn on with a red light, and the pin deploys and retracts twice?
