Failed to initialise WiFi module
@jay_s_uk thank you for this. This helps a lot. So I just send the commands via YAT bypassing the problem for now?
@jay_s_uk thank you very much for the help, really appreciate it
@jay_s_uk Sorry to pester, but I have ben running a job and it now keeps cutting out with this code
Warning: VIN under-voltage event (9.2V)
@CreateAndCarveCNC that shows that you probably have an issue with your main power supply and that the board thinks the voltage is dropping below 9.2V (unless its an issue with the reference 3.3v supply on the board)
@CreateAndCarveCNC said in Failed to initialise WiFi module:
December last year with my CNC machine from Ooznest.
Meaning December 2024, a few months ago? If so, we can do a warranty replacement.
@Phaedrux yeah December 2024 I purchased. This would be perfect if it can be replaced
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@Phaedrux Thank you very much.
Just a quick question, is there code to set the work XYZ to 0?
@jay_s_uk Thank you
