Spirograph emulator with Duet2
Hi guys,
after seeing a super cool video of a coffetable with a carved spirograph pattern, I want to build a CNC version in smaller scale. I found a different version with external gears, I want to emulate with geared steppers:
It almost looks like a 5-bar SCARA, but the motors moving the arms work with continuous rotation.
I thought of using the extruder mixing ratio for all three motors to get the typical spiro-patterns.But maybe there is a better solution to go beyond the spiro-world?
@o_lampe setting them up as a single mixing extruder should work. You may possibly get some rounding error resulting in the final pen position not quite lining up with the initial position. If that happens then I suggest you configure them as axes instead.
When I was a teenager I produced spirograph patterns on the screen of an old TV using two oscillators feeding modified audio amplifiers that drove the deflection coils of the CRT.
@dc42 said in Spirograph emulator with Duet2:
Depending on how good the build will be, it will look wobbly anyway. Especially the joints and wrist bearings are giving me an headache. I want to use a Dremel grinder at least...
I thought of replacing the circular motion of the two arms with ballscrews going back and forth.
IMHO, the pattern is mostly related to different starting positions ( or different start-angles in the original toy-mechanic)But how could I mimic a sinusodial motion with a linear axis?
Do we have "s-curve" acceleration? -
@o_lampe said in Spirograph emulator with Duet2:
You would need to generate small segments of GCode that move the linear axes in a sinusoidal manner.
Experimental S-curve acceleration is under development, but I don't believe it will help in this case,
At work I started building a spirograph machine based on bicycle parts similar to this:
I then began to work out the basic math behind the pattern, which I now regret not have done earlier.
Turns out, the outer toothcount should better be a binary number. That way only the small sprockets define the number of revolutions to complete a pattern.
My chain counts 124 teeth, which leads to 31 * n revolution patterns.
I'd grind a wooden surface to dust...especially at the center.Good thing, the emulated CNC version can have any number of teeth. Plus I can vary the arm lengths and emulate non_circular sprockets.
If you're interested, there is this nice spirograph simulator. Just hit the demo button and get hypnotized
@o_lampe I saw this video the other day, not much left in the centre! https://youtu.be/zW5nZ0Hp95k
@droftarts That was the vid that got me started. All the 3D printed parts must have taken a long time...
and I thought: bike-parts?! Another guy had the same idea a while ago. It's a good starting point but not CNC-able.
The version I posted above is a better candidate. It could even work as a FDM printer.
Like a short range 5-bar SCARA with a rotary bed. I wonder if RRF supports such weird kinematics? -
@o_lampe See MakersMuse latest video where he converts rotary motion to linear motion to sine wave using a Scotch Yoke.
https://www.youtube.com/watch?v=wko3SWiV1DM
Not sure if it will be useful for you but might inspire some ideas.
