M567: array too long
Since I upgraded to version 3.6 of RRF, I now have this error message saying: "M567: array too long, max length = 0" in config.g.
Below is some part of my config.g before the update for a co-extrusion system:
M569 P121.0 S0 D2 ; driver 121.0 goes forwards (extruder 0) M569 P0.4 S0 D2 ; driver 0.4 foes forwards (extruder 1) M584 E121.0:0.4 ; set extruder mapping M563 P0 S"Coflow" D0:1: ; create tool #0 M567 P0 E0.5:0.5; Mixing ratio M568 P0 S1
Would you know how to solve the error message?
Thank you,
TIM
@Timothee-Leblond please post your full config
@jay_s_uk
Here it is:
PS: it was working before updates...; Default config.g template for DuetPi ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org) ; Display initial welcome message M291 P"You are operating an SBC image in standalone mode. Please see <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">here</a> further information." R"Welcome to your new Duet 3!" S1 T0 ; Enable PanelDue M575 P1 B57600 S1 ; Enable network ; M552 P0.0.0.0 S1 ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ Ethernet ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.8 on Fri Dec 13 2024 08:59:52 GMT-0500 (Eastern Standard Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"Charlemagne_TIM" ; set hostname M915 X Y S30 R1 F1 H10 ; set sensorless homing M302 P1 ; Allow cold extrusion M207 S0 F0 Z0 ; Completely disable retraction ; Accessories M575 P1 S0 B57600 ; configure PanelDue support ; Wait a moment for the CAN expansion boards to become available G4 S2 ; Smart Drivers M569 P0.0 S1 D3 V2 ; driver 0.0 goes forwards (X axis) -> D3 is for stealthChop mode = enable stall detection M569 P0.1 S0 D3 V2 ; driver 0.1 goes forwards (Y axis) -> D3 is for stealthChop mode = enable stall detection M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis) M569 P121.0 S0 D2 ; driver 121.0 goes forwards (extruder 0) M569 P0.4 S0 D2 ; driver 0.4 foes forwards (extruder 1) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1 Z0.2 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z1000 ; set axis driver currents M92 X80 Y80 Z200 ; configure steps per mm M208 X-6:300 Y0:300 Z-5:400 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z800 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders config for 1 extruder ;M584 E121.0 ; set extruder mapping ;M350 E16 I1 ; configure microstepping with interpolation ;M906 E800 ; set extruder driver currents ;M92 E100 ; configure steps per mm ;M566 E120 ; set maximum instantaneous speed changes (mm/min) ;M203 E3600 ; set maximum speeds (mm/min) ;M201 E250 ; set accelerations (mm/s^2) ; Extruder + thread feeder M584 E121.0:0.4 ; set extruder mapping M350 E16:16 I1 ; configure microstepping with interpolation M906 E800:800 ; set extruder driver currents M92 E2840:2840 ; configure steps per mm -> E2840 with current set up means G1 E100 will move piston 100mm down. (second = 83 for thread feeder) M566 E120:120 ; set maximum instantaneous speed changes (mm/min) M203 E3600:3600 ; set maximum speeds (mm/min) M201 E250:250 ; set accelerations (mm/s^2) ; Kinematics M669 K0 ; configure Cartesian kinematics ; Probes M950 P0 C"out6" ; Set servo output on Mini 5+ M558 P9 H10 F800:700 T8000 C"!io6.in" ; Set probe input to IO_6 on Mini 5+ G31 P500 X0 Y0 Z10 ; set Z probe trigger value, offset and trigger height ;M950 S0 C"121.io0.out" ; Set servo output on Rototoolboard ;M558 P9 H6 F250:30 T8000 C"^!121.io0.in" ; Set probe input to IO_0 on Rototoolboard ;G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height ; Endstops M574 X1 S3 ; configure X axis endstop M574 Y1 S3 ; configure Y axis endstop M574 Z1 S2 ; configure Z axis endstop M915 X Y R0 F0 ; Tools M563 P0 S"Coflow" D0:1: ; create tool #0 M567 P0 E0.5:0.5 ; Mixing ratio ; ;M567 P0 E0.02:0.98 ; set mixing ratios for tool #0 ;M563 P0 S"MainExtruder" D0 ; create Tool 0 using Extruder Drive 0 ;M563 P1 S"Thread Feeder" D1 ; create Tool 1 -> Extruder Drive 1 G10 P0 X-68 Y-55 Z-12 S0 R0 ; set Tool 0 active and standby temperatures to 0 -> XY values are the offsets of the nozzle from center of cart. T0 ; select Tool 0 at startup
I thought it could also be a misscommunication with the CAN bus but it is appearing when using M122.
@Timothee-Leblond said in M567: array too long:
Try without the rogue colon after the 1
