    How to correctly setup power failure detection/resurrection in 1.20?
    3.1k
    • Guyarosundefined
      Guyaros
      In the meanwhile, I wrote "homeZMaxUsingStallDetection.g" script. and it's working good.
      [c]
      M915 Z S10 F0; Configure motor stall detection, Z motor, set stall detection threshold, set stall detection filter disabled
      M574 Z2 S3; Set Z-axis home to Max endstop, Set endstop type to Motor stall detection
      M913 Z85; Reduce current of Z motor to 85%
      G91; Switch to relative positioning
      G1 Z300 F1200 S1; Lower bed all the way down, until motor stalls
      M400; Wait for move to finish
      M913 Z100; Reset motor currents back to normal 100%
      G1 Z-5; Raise bed by 5[mm]
      G92 Z165; Set Z position
      M574 Z0 S2; Set Z-axis home to Minimum endstop, set endstop type to Z-Probe (Reset to normal working mode)
      [/c]
      so I guess I am ready to try the resurrect routine.
      • justine.hauptundefined
        justine.haupt
        Had my first power failure during a big print early this morning, would like to resurrect.
        Additional questions:
        1. Why is the file in resurrect.g is called "Presurrect-prologue.g" instead of "resurrect-prologue.g" as the wiki says?
        2. I never configured auto-pause with M911, yet a seemingly good resurrect.g file has been created for the print. Is there a default auto-pause in place?
        3. My machine homed itself at the time of the power failure. I'm at a loss to explain how this could have happened.
        The contents of resurrect.g right now:
        [[language]]
        ; File "ExhaustPanel-P.gcode" resume print after print paused at 2018-01-13 05:07
        M140 P3 S70.0
        G10 P1 S0:0:0:0 R0:0:0:0
        G10 P0 S215 R215
        T0 P0
        M98 Presurrect-prologue.g
        M106 P0 S1.00
        M106 P2 S0.00
        M106 P3 S0.00
        M106 P5 S0.00
        M106 P7 S0.00
        M106 S255.00
        M116
        M290 S0.000
        G92 E10.69300
        M82
        M23 ExhaustPanel-P.gcode
        M26 S4316562 P0.000
        G0 F6000 Z6.560
        G0 F6000 X383.10 Y181.68
        G0 F6000 Z4.560
        G1 F14000.0 P0
        M24
          The "P" is the parameter letter, it is not part of the filename.
          In firmware 1.20 a resurrect.g file is created whenever you pause a print, so the one you have will be from when you last paused it, not from the time of the power failure unless the print was already paused when the power failed.
            justine.haupt
            Oh, darn. Okay, thanks David.
              @deckingman:
              Actually, not homing Z would work for me although I appreciate that not everyone is in the same situation. With 1mm lead screws and 1.8 degree motors, one full step is 0.005mm so 2 steps would only be an error of 0.01 mm. Even with 4mm lead screws, the error would be 0.04mm which with a 0.3mm layer height wouldn't be desperately bad. I'm guessing that Deltas use a much lower Z steps per mm but then don't they home at Z max in any case?
              I might be worth having the option to have G92 Z in the resurrect.g file for lead screw driven Z axes?
              I can see a potential problem with that. You will probably have a command to lift Z in the power fail script, otherwise the nozzle will be stuck to the print. But if you don't have enough power reserve, that G1 Z command may not be executed accurately or in full. So you would still be uncertain of where Z should be.
              A better solution might be:
              • Implement a GCode to set the coordinates of the pause restore point, and generate this in resurrect.g to set it to the position when the power fail occurred
              • When restarting the print, after homing X and Y and heating the nozzle, jog the head down to the correct height manually
              • Implement a R1 option on the G92 command, then you cold use G92 R1 Z0 to tell the firmware it was at the Z height that is set in the psue restore point
                justine.haupt
                But hey, that resurrect.g IS for today's date. Strange.
                  justine.haupt
                  UNEXPECTED BEHAVIOR CONFIRMATION
                  I just successfully resurrected this print despite not having M911 defined in config.g
                    justine.haupt
                    It must have automatically commanded the pause script, because it parked itself. I speculation that there was a short brownout this morning to account for it having enough power to park itself. I know you're saying that's not possible, but it did… I was sleeping when the print stopped itself, and on resurrect it picked right up where it left off.
                      Lucky you!
                        justine.haupt
                        Yeah but, it seems like it issued the pause script on its own somehow. The gantry was parked, mid print. Any idea why it would do that?
                          Did I forget to mention the new firmware precognition feature? 😉
                          An alert from a filament monitor will also cause a pause.
