Stuck in spin loop, spinning module Network
    MarMed
    Just had a reset mid print, not sure whats going on.
    Firmware Name: RepRapFirmware for Duet WiFi
    Firmware Electronics: Duet WiFi 1.0
    Firmware Version: 1.20 (2017-12-23)
    WiFi Server Version: 1.20
    Web Interface Version: 1.20
    M122
    Used output buffers: 3 of 32 (9 max)
    RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
    Board ID: 08DAM-999TL-MQ4S4-6J1F2-3S86L-94GHZ
    Static ram used: 15448
    Dynamic ram used: 98976
    Recycled dynamic ram: 264
    Stack ram used: 1392 current, 4384 maximum
    Never used ram: 12000
    Last reset 00:01:37 ago, cause: software
    Last software reset at 2018-01-14 05:27, reason: Stuck in spin loop, spinning module Network, available RAM 3848 bytes (slot 2)
    Software reset code 0x4041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f80f, BFAR 0xe000ed38, SP 0x2001f9ac
    Stack: 0042c995 00008196 0043c277 00008196 ffffffe9 00001000 00081111 40080000 00008196 20002d8c 00437273 0043ab86 210b0200 3e1aa000 3e24de00 00000009 00000009 3e178897 45870070 438ff91a 44fc01bd 00000000 4964e1c0 44841fba
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 0.0ms
    MCU temperature: min 28.4, current 29.7, max 31.4
    Supply voltage: min 0.8, current 0.9, max 4.0, under voltage events: 0, over voltage events: 0
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Date/time: 2018-01-14 05:29:51
    Cache data hit count 354749734
    Slowest main loop (seconds): 0.014096; fastest: 0.000035
    MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Bed compensation in use: none
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    Network state is running
    WiFi firmware version 1.20
    WiFi MAC address 60:01:94:09:18:33
    WiFi Vcc 3.38, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 17232
    WiFi IP address 192.168.0.218
    WiFi signal strength -65dBm, reconnections 0, sleep mode modem
    HTTP sessions: 1 of 8
    Socket states: 2 0 0 0 0 0 0 0
    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      Thanks, I'll look into it.
        I have taken a look. It appears to have got stuck in the SD card driver because a command failed to complete. I have seen at least one other occurrence of this.
        I have it in mind to add a timeout to that function to avoid the reset happening.
          MarMed
          @dc42:
          Thank you for taking the time to look into it, I forgot to include that I had tried to load the duet web control page to check on the printer's progress when the reset happened.
          4 out of 4
