What was once silent is now loud..
917
    Ya3ny
    I used to have the printer running silently until I changed something in the firmware. Might've been current draw..
    I don't recall what it was but suggestions would be greatly appreciated!
      Please post your config.g file.
        Ya3ny
        [[language]]
        ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
        ; generated by RepRapFirmware Configuration Tool on Sun Nov 05 2017 22:28:13 GMT-0500 (Eastern Standard Time)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P2 ; Set firmware compatibility to look like Marlin
        M665 R157 L397.1073 B175 H517 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Define active high microswitches
        M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
        G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
        M557 R270 S20 ; Define mesh grid
        M569 P3 S0 ; Drive 3 goes forwards
        M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
        M92 X80 Y80 Z80 E80 ; Set steps per mm
        M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M143 S260 ; Set maximum heater temperature to 260C
        M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M307 H1 A1400.8 C122.4 D5.3 B0
        M563 P0 D0 H1 ; Define tool 0
        M550 PTLM _Duet ; Set machine name
        M552 S1 ; Enable network
        M587 S"C170512D5CFB" P"9053393116" ; Configure access point. You can delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          deckingman
          Looks like micro-stepping interpolation is turned off - try turning it back on (use I1 in M350 instead of I0)
            Hey_Allen
            Don't feel bad, I did the exact same thing after updating my firmware from 1.16(-ish…) to the current release version, and was scratching my head for a bit before finding the flipped bit in the Interpolation config line.
            This might have been a change implemented in the changes, and buried somewhere in the release notes?
              Ya3ny
              @deckingman and @Hey_Allen are correct!
              Made the suggested change and it's running silently again! Thank you!!!
                nickpgre
                What's are the benefits of enabling micrtostepping with interpolation other than keeping the noise down?
                  On delta printers, you may also get less moire. On other types of printer, probably no advantage.
                  1 out of 8
