    Mounting a radial fan on the Smart Effector
    Smart effector for delta printers
    16
    36
    6.5k
    • brandonhundefined
      brandonh
      Here's my design, this time with a 40x20mm blower fan:
      https://www.thingiverse.com/thing:2732877
      I'm happy that the design extends minimally beyond the effector triangle, but in terms of cooling efficiency, other fans/designs may be better. I've got some 40mm fans on order to try out too.
      Comments welcome! Lots of nice designs on this thread.
      • Jimborrundefined
        Jimborr
        I've also create a mount/nozzle for a 5015 blower fan. Not the prettiest there is, function before form?!
        You might loose some printarea depending on your setup though.
        https://i.imgur.com/YGceDSz.jpg?1
        I haven't done any briding tests with it yet but it looks promising.
        http://a360.co/2lfN2Qn mount
        http://a360.co/2ChBnrn nozzle
        • PlasticMetalundefined
          PlasticMetal
          I've been using this design with a 30mm fan for a couple months now, also based on the tusk idea. Sorry, no pix handy.
          It mounts on the bottom side of the SE, under 2 magballs, so no extra hardware is needed. I need to trim it down some, possibly splitting it into 2 parts as others have done.
          http://a360.co/2CD81as
          I printed it in PETG, which gives it enough flex for the fan to snap in place. I printed it with the left side on the bed (as viewed when looking at the fan); I don't recall for sure, but it was likely with 0.20 to 0.30 layers (0.6 nozzle).
          • RGN01undefined
            RGN01
            I've just finished my new mount for the Smart Effector. It is designed for a 40 x 15mm radial fan.
            https://www.thingiverse.com/thing:2749324
            Richard
            (Edited to add photo)
              Nice!
              • Gone2Farundefined
                Gone2Far
                If I might, I'd like to ask a related question. What is the minimum distance recommended for ducts or other protrusions above the nozzle tip? Don't want to crash into the bed or print.
                Thanks in advance!
                Original Prusa i3 MK2S
                Large Kossel Homebrew
                  1mm is normally sufficient, unless you need more to provide clearance from bed clips.
                  • Gone2Farundefined
                    Gone2Far
                    Thanks again.
                    • RGN01undefined
                      RGN01
                      I've just added 2 further ducts - one for 5mm tusks and one for 6mm tusks. As they are attached with magnets it is easy to switch between the 4, 5 and 6mm versions to suit the job at hand.
                      Richard
                      @RGN01:
                      https://i.imgur.com/6KUpSin.jpg
                      Richard
                      • DjDemonDundefined
                        DjDemonD
                        This was my solution
                        Sunon 30mm blowers 5v but will pwm down from 12v if you limit them in your slicer to 30-40% (you can blast them at 12v for short periods such as bridging). I have found they work quite nicely with diffuse airflow but you print and bond ducts to them if you wish.
                        No loss of print volume as they sit under the effector. Brackets I can put on thingiverse, just bond fans on with superglue/ca glue.
                        I have them in my shop.
                        www.precisionpiezo.co.uk
