    Cartesian - Z-endstop & homing (Max or Min)?
    5.0k
    • Dougal1957undefined
      Dougal1957
      um strange one
      • RGN01undefined
        RGN01
        Yeah, it has me stumped!
        Richard
        • RGN01undefined
          RGN01
          Not sure if I mentioned, so adding the firmware version:
          Firmware Name:	        RepRapFirmware for Duet WiFi
          Firmware Electronics:	Duet WiFi 1.0
          Firmware Version:	1.20 (2017-12-23)
          WiFi Server Version:	1.20
          Web Interface Version:	1.20
          Richard
            After you do Z homing, are you certain that if you command the printer to Z=0 the nozzle is just touching the bed? A very small number of users have reported that their IR sensors sometimes have a secondary trigger height some distance above the proper one. In such cases we have replaced the sensor.
            • RGN01undefined
              RGN01
              Thanks, David. It is perhaps easiest if I explain what I'm doing. I ran my homez.g:
              ;Z-Probe endstop
              G1 X110 Y110
              G91			; relative positioning
              G1 S1 Z-250 F9000	; move quickly to Z axis endstop and stop there (first pass)
              G1 Z5 F6000       	; go back a few mm
              G1 S1 Z-250 F360  	; move slowly to Z axis endstop once more (second pass)
              G1 Z2 F4000      	; raise Z again
              G90               	; absolute positioning
              After running that, the nozzle stopped about 4.5mm from the bed but the Z-height displayed on DWC was 2.0mm. Issuing G1 Z0 dropped the nozzle to about 2.4mm above the bed but DWC height shows 0mm.
              The measured heights were measured using a stack of Post-It notes and a vernier so there is a reasonably large margin of error! 🙂
              I tried this with bed compensation enabled and disabled and it made no noticeable difference.
              Running bed compensation immediately after this returns "Mean error: -2.591 mm" but the bed is very close to level.
              Was the false detect of those IR probes about 2 to 2.5mm greater than the main trigger distance?
              Richard
              • RGN01undefined
                RGN01
                OK, I think I have found the issue - somehow my homeall.g, did not have G30 in it. Not at all sure how I lost it but added it back and it seems to be working correctly.
                I'm sorry for the confusion - I've been battling this for days and somehow overlooked that missing G30!
                Richard
                  I'm glad you solved it. Your homez.g file should also be using G30, not G1 S2 Z moves. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z.
                  • RGN01undefined
                    RGN01
                    Thanks, David. I've now reverted to the Z-max endstop and am using the probe for probing prior to a print. I will write up my settings etc. in a new thread as it may help someone else get this combination working (e3d Chimera, IR probe and Z-max endstop).
                    I really do appreciate you help - thank you!
                    Richard
                    • SputnikOC3dundefined
                      SputnikOC3d
                      Interested in the settings needed to get Z max endstop with Z min [ probe ] workign correctly. my current config doesnt actually stop the Z+ movement when the endstop is triggered
                      • RGN01undefined
                        RGN01
                        @SputnikOC3d:
                        Details of my printer and the config files are here https://www.duet3d.com/forum/thread.php?id=4306
                        Hope this helps.
                        Richard
                          SputnikOC3d
                          @RGN01:
                          @SputnikOC3d:
                          Hope this helps.
                          Richard
                          Thanks Richard … Im looking at this ..
                          ; Endstops Z-probe
                          M574 X1 Y2 S1 ; Set active high [ NC ] endstops
                          M574 Z2 S0 ; set active low [ NO ] endstops
                          M558 P1 H6 F300 T8000 ; Set Z probe type to unmodulated and the dive height + speeds
                          G31 P500 X9 Y21 Z2.2 ; Set Z probe trigger value, offset and trigger height
                          M557 X10:220 Y25:220 S20 ; Define mesh grid
                          Is it possible I need a NO normally OPEN type switch for this to work when using a probe on this axis? Mine is currently NC. I cant understand why that would be … but - ya never know ...
                          Also may I ask another probably dumb question ... How did you determine the X/Y offsets off the probe on your G31 code? My BL touch mounts into a Prusa MK2 extruder assmbly.... and I dont think the thingiverse creator of the add on probe mount took any time to CAD that data out ... and Im not sure how to accurately measure these offset ... Is there a tutorial or a guide somewhere _ive looked - no find ...
                          PS - I noted your max speeds and current settings are far greater than mine ... NEMA 17s on this printer? My Z is kinda noisy and my speeds arent all that exciting. Was hoping to get quieter and faster ... think I need 24v vs. my 12v PSU ... and to uptick the power and speeds ...
                          Thanks for any help you could share here
                          All the best,
                          Steve
                          • Stoopundefined
                            Stoop
                            @dc42:
                            Yes, except:
                            1. You probably want something more like G1 X100 Y100 Z5 so that bed probing starts from 5mm height.
                            2. You should not use G92 to set the Z height after the G30. Use the G31 Z parameter instead.
                            So, I'm VERY new to 3d printing.
                            WHY don't you wanna use G92 after G30?
                              @Stoop:
                              The firmware needs to know the Z probe trigger height anyway for other bed probing purposes. There is no point in putting the same information in two different places, you will just confuse yourself if/when that value changes.
