New firmware 1.21RC3 available
Firmware installation
31
159
23.8k
    Yes there is an exception for G0/G1 moves in FDM mode so that you can still have a skirt that goes outside the printable area. But if you try to make other types of illegal move, such as moves when the axes are not homed, or G2/G3 moves that go outside the printable area, the print file will be terminated.
      kraegar
      The bltouch / multi-tap fix works great.
      Probe configuration:
      M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
      3 point leveling result:
      Leadscrew adjustments made: 0.004 -0.008 -0.000, points used 3, deviation before 0.005
        garyd9
        dc42, I hate to nag… but..
        Is the issue I've reported concerning M116 seemingly being ignored under certain circumstances (https://www.duet3d.com/forum/thread.php?id=4018) likely to be addressed before this round of RC's ends? The issue bit me again with 1.21RC2, and I haven't seen anything in the release notes that might relate. (I also don't know if anyone else has even tried to repeat the issue.)
        Thanks
        Gary
          I have tried to reproduce this issue without success, and I have reviewed the code and not found any explanation. Nobody else has reported it.
          What I really need from you, assuming that you still find it a problem in 1.21RC3, is a set of simple steps to reproduce it.
            kazolar
            Will try it tonight – I'm a bit hesitant to remove static IP though
              Kezat
              Fantastic! I love how you continue to support the board with F/W changes and also support on this forum, keep up the awesome work.
              Now that i have my printer a bit more stable state I will give this version a try soon.
                c310
                there is a bug in WiFi Server. i have DuetWiFi (and upgraded WiFi module to one with external connector)
                1.21 RC3 does not boot WiFi
                Printer is now online.
                m552
                SENDING:M552
                WiFi module is being started
                once i rolled back to 1.20 all is back to normal.
                now i have mixed environment
                WiFi + Web 1.20
                Firmware 1.21RC3 (2018-02-28 build 4)
                  DjDemonD
                  Just to say, as I didn't remember to do so on the RC2 thread. The multitouch probing is a big improvement. More accurate - no, but the chance that one aberrant probing point would then result in junk M665 and M666 data has reduced to practically zero. Excellent work.
                  www.precisionpiezo.co.uk
                    kraegar
                    @DjDemonD:
                    Completely agree!
                      @c310:
                      m552
                      SENDING:M552
                      WiFi + Web 1.20
                      Strange, does WiFi 1.21RC1 work for you?
                        okercho
                        @dc42:
                        @c310:
                        m552
                        SENDING:M552
                        WiFi + Web 1.20
                        I'm also still having issues with WiFi since I updated to 1.20. around 60% of the times I'm getting "WiFi reported error: Wrong password while trying to connect to ESSID. Wifi module is idle". Then I just type in the panelDue "M552 S1", and the wifi works again "Wifi module is connected to access point ESSID, IP address XXX.XXX.XXX.XXX"
                        I tried with 1.19.3 and wifi works fine (no HW issue apparently), I tried flashing my AP (Linksys) with DD-WRT and duet connects 100% of the time… but DDWRT is really unstable in my AP (beta version... :() and caused lots of issues in my network.
                        Summarizing, something changed between 1.19.3 and 1.20 that makes my duet to fight against my AP and loose most of the times :(.
                        I've updated to RC3 (wifi problems still persists), and I've tried FTP (I tried it yesterday first time, and couldn't get it working at all), but it still doesn't work fine.
                        I tried with Filezilla (connects, but sometimes returns (500 Unknown login command), ftp terminal command (didn't work:421 Service not available, remote server has closed connection.), google chrome (Err_Connection_Reset) and Mac Finder (unable to connect at all). after trying terminal, chrome and finder, I tried again Filezilla, and it connects, but even though it list the folders and the files, I cannot download anything.
                        This is from FileZilla:
                        [[language]]
                        Status: Connecting to XXX.XXX.XXX.XXX:21...
                        Status: Connection established, waiting for welcome message...
                        Status: Insecure server, it does not support FTP over TLS.
                        Status: Server does not support non-ASCII characters.
                        Status: Logged in
                        Status: Retrieving directory listing...
                        Status: Directory listing of "/" successful
                        Status: Retrieving directory listing of "/sys"...
                        Status: Directory listing of "/sys" successful
                        Status: Retrieving directory listing of "/"...
                        Error: Could not read from socket: ECONNRESET - Connection reset by peer
                        Error: Could not connect to server
                        Status: Disconnected from server
                        Status: Delaying connection for 5 seconds due to previously failed connection attempt...
                        DWC works fine, and I didn't have any packet lost during the test. I can capture traffic with wireshark if you need to. I tried to download gcodes folder too (just in case sys causes problems or something) and I've got the same error.
                        Regards
                        Okercho
                        Custom Prusa i3 Hephestos with Duet Wi-Fi
                        E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                        Rebuilding Hypercube Evolution
                          c310
                          @dc42:
                          yes, i managed to put it in.
                          Current combination has full range of Rcx 🙂
                          Firmware Version: 1.21RC3 (2018-02-28 build 4)
                          WiFi Server Version: 1.21RC1
                          Web Interface Version: 1.21-RC4
                            GrodanB
                            Why does my home all not work anymore?
                            [[GCode]]
                            ; Lift Z relative to current position
                            T0
                            G91
                            G1 Z4 F6000
                            G1 X-350 Y-240 F3000 S1 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
                            G1 X6 Y6 F600 ; move slowly 6mm in +X and +Y directions
                            G1 X-10 Y-10 S1 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
                            G90
                            ; Go to Center of the bed probe point and home the Z axis
                            G1 X150 Y100 F3000
                            G30
                            ;dock
                            T0
                            M117 Docking Printhead.
                            G1 X70 Y200 F3000
                            G1 X70 Y235 F3000
                            Get this output:
                            10:40:33 G28 Error: G0/G1: insufficient axes homed
                            Worked fine when using RC2
                            Also tried to print something that worked fine and got this:
                            10:34:47 M25 Resume-after-power-fail state saved Printing paused
                            10:34:42 Error: G0/G1: insufficient axes homed
                            10:34:41 M32 "Monopoly_Replacement_Part_Wheelbarrow.gcode"File Monopoly_Replacement_Part_Wheelbarrow.gcode selected for printing
                            Why does it claim that it tries to restart after power-failed? I just tried to start my print as I always has done… It is not impossible that I have bad start-up scripts... (my home seem to be suddenly wrong) But I do not understand this from reading the change log...
                            [[GCode]]
                            ;BigBox Printer Start Script Begin
                            ;extruder offset - refer to the wiki | http://wiki.e3d-online.com/wiki/Printer_Commissioning#Dual_Nozzle_Alignment
                            M117 Print Starting
                            G91 ; Relative coordinate
                            G1 Z5 F400 //Lower Bed 5mm//
                            G90 ; Absolute coordinate
                            ;Homing
                            M117 Homing.
                            G28 ; home all axes
                            G29 S1 //This command loads the stored IR bed levels//
                            G30 P0 X25 y100 z-99999
                            G30 P1 X275 y100 z-99999 S2
                            ;dock
                            T0
                            G1 X70 Y200 F3000
                            G1 X70 Y235 F3000
                            M117 Print Starting.
                            ;BigBox Printer Start Script End
                            I find it strange that I cannot move my Z axis away from the bed to enable the probe to be at a "safe" detection distance to avoid the hot-end to crash into the bed because the probe is to close and already passed the trig threshold. (tried that one MANY times…)
                              T3P3Tony administrators
                              GrodanB, please see David's release notes:
                              https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                              You will see you need to either home Z first, or specify the lift with S2 to override the axis homing protection.
                                GrodanB
                                OK, amazing that 3-4 readings and still miss this… I assumed that was the probable root cause...
                                Fixing immediately! Thanks
                                So I practice the method that it is better to ask and be an idiot for five minutes then being it for the rest of you life 🙂
                                Edit: Re-reading it is so obvious... First time I just assumed that not allowing movement to an not homed axis was OK and did not register the homing issue...
                                The resume weirdness also disappeared when adding the S2 to the G1 Z-axis movement. Strange...
                                New issue?: Why can I not upload files unless there is at least one XXX.Gcode in the gcode directory? Via the up-load button.
                                Did a emergency stop (reset) and the button was available again.
                                  lolorc
                                  ttyACM3 16°> M115
                                  SENDING:M115
                                  FRMWR_NAME: epapirwae orDut WiF ad ue Ethene FRMAR_VERSON 121C2ELRNIS:Dut ii .0or101FIMWRE_AT: 01-0-1 bil 2
                                  o T170 0. B16.7 /00
                                  I've tried to upload DuetWifiFirmware.bin several time from webui.
                                  M115 was still reporting 1.21RC2
                                  I've copied DuetWifiFirmware.bin to /sys and M997 S0
                                  something borken again.
                                    SputnikOC3d
                                    @kraegar:
                                    is there a link to guide or tute or dozuki page outlining the implementation of this newly supported feature? My BL Touch bed leveling has been giving me fits and I think its due to inconsistent probing results - this would be rather nice
                                      kraegar
                                      @SputnikOC3d:
                                      @kraegar:
                                      If you're referring to the multi-tap, the relevent bits there are the S0.02 (max deviation between two sequential taps) and A5 (allow up to 5 attempts). I never see it tap more than twice, though.
                                      The new probe type, P9, is to specify it's a BLTouch specifically, and so you no longer need to manually deploy the probe, it does it automatically.
                                        lolorc
                                        @lolorc:
                                        ttyACM3 16°> M115
                                        SENDING:M115
                                        o T170 0. B16.7 /00
                                        this was an serial issue I was not able to reproduce hopefully.
                                        However I can't manage to upgrade to 1.21rc3, Duet2CombinedFirmware.bin been renamed to DuetWiFiFirmware.bin, uploaded through webui, copied to sdcard (+M997) M115 still reports 1.21rc2.
                                          SputnikOC3d
                                          @kraegar:
                                          @SputnikOC3d:
                                          @kraegar:
                                          Thanks very much for this … appreciated - but there must be some documentation for this somewhere right? How did you learn of these settings / features?
                                          I will try and implement. Im also desperateyl trying to find some data on the sensititivty setting for the BL Touch - docs just said to use a low setting - it was default at 500 - I modded that to 25 - wondering if that is impacting my results ... I cant find jack in docs on that issue
                                          12 out of 159
