    New firmware 1.21RC3 available
    Firmware installation
    31
    159
    23.8k
    • GrodanBundefined
      GrodanB
      OK, amazing that 3-4 readings and still miss this… I assumed that was the probable root cause...
      Fixing immediately! Thanks
      So I practice the method that it is better to ask and be an idiot for five minutes then being it for the rest of you life 🙂
      Edit: Re-reading it is so obvious... First time I just assumed that not allowing movement to an not homed axis was OK and did not register the homing issue...
      The resume weirdness also disappeared when adding the S2 to the G1 Z-axis movement. Strange...
      New issue?: Why can I not upload files unless there is at least one XXX.Gcode in the gcode directory? Via the up-load button.
      Did a emergency stop (reset) and the button was available again.
      • lolorcundefined
        lolorc
        ttyACM3 16°> M115
        SENDING:M115
        FRMWR_NAME: epapirwae orDut WiF ad ue Ethene FRMAR_VERSON 121C2ELRNIS:Dut ii .0or101FIMWRE_AT: 01-0-1 bil 2
        o T170 0. B16.7 /00
        I've tried to upload DuetWifiFirmware.bin several time from webui.
        M115 was still reporting 1.21RC2
        I've copied DuetWifiFirmware.bin to /sys and M997 S0
        something borken again.
        • SputnikOC3dundefined
          SputnikOC3d
          @kraegar:
          The bltouch / multi-tap fix works great.
          Probe configuration:
          M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
          3 point leveling result:
          Leadscrew adjustments made: 0.004 -0.008 -0.000, points used 3, deviation before 0.005
          is there a link to guide or tute or dozuki page outlining the implementation of this newly supported feature? My BL Touch bed leveling has been giving me fits and I think its due to inconsistent probing results - this would be rather nice
          • kraegarundefined
            kraegar
            @SputnikOC3d:
            @kraegar:
            If you're referring to the multi-tap, the relevent bits there are the S0.02 (max deviation between two sequential taps) and A5 (allow up to 5 attempts). I never see it tap more than twice, though.
            The new probe type, P9, is to specify it's a BLTouch specifically, and so you no longer need to manually deploy the probe, it does it automatically.
            • lolorcundefined
              lolorc
              @lolorc:
              ttyACM3 16°> M115
              SENDING:M115
              o T170 0. B16.7 /00
              this was an serial issue I was not able to reproduce hopefully.
              However I can't manage to upgrade to 1.21rc3, Duet2CombinedFirmware.bin been renamed to DuetWiFiFirmware.bin, uploaded through webui, copied to sdcard (+M997) M115 still reports 1.21rc2.
                SputnikOC3d
                @kraegar:
                @SputnikOC3d:
                @kraegar:
                Thanks very much for this … appreciated - but there must be some documentation for this somewhere right? How did you learn of these settings / features?
                I will try and implement. Im also desperateyl trying to find some data on the sensititivty setting for the BL Touch - docs just said to use a low setting - it was default at 500 - I modded that to 25 - wondering if that is impacting my results ... I cant find jack in docs on that issue
                • okerchoundefined
                  okercho
                  @SputnikOC3d:
                  You can check in the Gcode documentation 🙂
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                  Regards
                  Okercho
                  Custom Prusa i3 Hephestos with Duet Wi-Fi
                  E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                  Rebuilding Hypercube Evolution
                    T3P3Tony administrators
                    Also see:
                    https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                    I have linked a helpful tutorial for BL Touch by BeTrue3d.dk
                      SputnikOC3d
                      @T3P3Tony:
                      Also see:
                      Thank you …
                      Now i get ... Error: M997: Firmware binary "DuetWiFiFirmware.bin" is not valid for this electronics ????
                        SputnikOC3d
                        no blue light on wifi module … wth ... So doing some reading it stated on some docs that sometimes you need to make sure your wifiserver .bin and your firmware .bin are upload before executing the firmware update .... because Im getting M997 error - as stated above ... After upload of the new 1.21RC3 wifi server bin ... it asked if I wanted to upgrade or whatev's it calls it I hit YES.
                        It went thru some activity - showed me a green progress bar ... then now i get nothing no connection via wifi - no blue lights next to the wifi module on the board ... So now I have 1.20 firmware still and 1.21rc3 wifi server and no wifi connectivity - now what ?
                        release notes said it didnt matter if wifi bin or firmware bin done first ...
                          The blue light on the wifi module comes on only when uploading the wifi server firmware.
                          It looks like that is successful as you say the wifi server firmware version is 1.21rc3? Sounds like an issue with the main firmware upload. Try downloading the DuetCombinedFirmware.bin again (make sure you download the raw .bin file) then rename it to DuetWifiFirmware.bin then upgrade. You will need to comply it onto the SD card by putting it into your PC.
                            SputnikOC3d
                            @T3P3Tony:
                            TY … yes I agree. I did make sure and actually downloaded the main fw file again and renamed it as per instructions - before moving over the wifi server .bin file via the gui. But I will do as indicated - i have to go get a micro sd card adapter/reader for this pc - never use them in real life ... but now do.
                            Will report back ... Im following
                            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_WiFi
                            please advise if there is a better guide to follow for my situation than the one linked to above.
                            TY again …
                              That guide is the right one for this situation
                                SputnikOC3d
                                Any ideas why I got the M997 error at the onset ? Did i need to be running a more recent firmware version than 1.20 ?
                                  @SputnikOC3d:
                                  @T3P3Tony:
                                  Also see:
                                  Thank you …
                                  That normally means you downloaded the html page describing the firmware file, instead of the firmware file.
                                    SputnikOC3d
                                    @dc42:
                                    @SputnikOC3d:
                                    @T3P3Tony:
                                    Also see:
                                    Thank you …
                                    well valuable lesson learned there … compare bytes and drill down into the github into the page where the actual files reside ... so ive followed the guide- run out and got a micro sd card reader - and moved the files and commented out the line in config .g ...
                                    Issuing M997 S0 and M997 S1 ...
                                    M115 gives me ...
                                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 1.21RC3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-02-28 build 4<lf>ok <lf>Im really not clear by looking at this whether the Wifi Server firmware part is the right version?
                                    M122 gives me :
                                    <lf>Used output buffers: 1 of 32 (9 max)
                                    <lf>=== Platform ===
                                    <lf>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21RC3 running on Duet WiFi 1.02 or later
                                    <lf>Board ID: 08DGM-9568A-F23SD-6JTDD-3SJ6R-9ARZH
                                    <lf>Static ram used: 16144<lf>Dynamic ram used: 100384
                                    <lf>Recycled dynamic ram: 2256<lf>Stack ram used: 3568 current, 4528 maximum<
                                    LF>Never used ram: 7760<lf>Last reset 00:14:41 ago, cause: power up
                                    <lf>Last software reset at 2018-02-24 09:30, reason: User, spinning module GCodes, available RAM 11896 bytes (slot 3)
                                    <lf>Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                    <lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 37.6, current 37.8, max 38.1<lf>Supply voltage: min 0.5, current 0.6, max 0.6, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not avai<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                                      SputnikOC3d
                                      M552 S0
                                      M587 S"SSID" P"PWD"
                                      M552 S1
                                      Viola …
                                      new firmware and wifi server and new DWC all synced up ... sorry for the trouble guys - im back and with just a bit more gcode and duet firmware savvy - 1 Bite at a time ...
                                      • nytundefined
                                        nyt
                                        So any way to do G30 homing with doubletap?
                                          @SputnikOC3d:
                                          M552 S0
                                          M587 S"SSID" P"PWD"
                                          M552 S1
                                          Viola …
                                          Glad you are up and running!
                                          • robmundefined
                                            robm
                                            Thanks for the work on the rotating magnet filament monitor. I can confirm that the output looks better.
                                            Please will you review briefly how the configuration is supposed to work? Perhaps post in the filament monitor section…
                                            It seems like it auto-calibrates now the mm extruded per revolution of the magnet? In the previous version this was specified in the S parameter, but now its not clear to me as the documentation says '1 to enable' and later gives an example of 'S1.05 R30' meaning 'sensitivity 1.05, +/-30% error detection tolerance'. Also there's still the query about the Raa:bb form of the R parameter. My initial results (just running out the door so not much time to test!) are:
                                            [[language]]
                                            2:01:00 PM
                                            M591 D0
                                            Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 26.68mm/rev, allowed movement 0% to 10%, check every 3.0mm, current position 284.4, measured sensitivity 24.92mm/rev, measured minimum 85%, maximum 132% over 273.1mm
                                            [[language]]
                                            2:14:14 PM
                                            M591 D0
                                            Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 26.68mm/rev, allowed movement 0% to 10%, check every 3.0mm, current position 22.5, measured sensitivity 25.06mm/rev, measured minimum 85%, maximum 131% over 272.6mm
                                            my sensor hob groove diameter measured 7.75mm so calculated circumference at the bottom of groove is 24.3mm
                                            Thanks!
                                            Rob.
