    PanelDue more useful information….
    PanelDue
    2.7k
      @BikingViking:
      Hardware overhead wise, is there any chance that the user interface for the PanelDue could be migrated to a html/css/js system in order for it to be easily customisable?
      No. If you want to do that, use a tablet computer instead.
      • BikingVikingundefined
        BikingViking
        Ok thanks David
        • Barracuda72undefined
          Barracuda72
          Another thing i would like to see…if i change the speed factor its possible at the panel..but i cant see the current speed factor. Only the extruder factor is shown
            The speed factor displays correctly for me. Which Panel Due firmware version do you have?
              Barracuda72
              it´s a 4.3" LCD…or is that the reason? too small?
              Version1.17 says the lcd 😉
              and if im not wrong, thats the actual version.
                Barracuda72
                @David…found the Error..it was Error 42..Reason sat 42cm away from the LCD 😉
                Changed at assembly the language to german..
                Speed..a really short word...the german word is " Geschwindigkeit" so..no space left for the percentage 😉
                changed to english again..problem solved...thx
                  I'm glad you solved it. Is there a shorter German word or abbreviation it could use?
                    Barracuda72
                    As the word speed is not uncommon in germany i would change it to speed..guess even my grandma would know that its Geschwindigkeit.
                      Thanks, I'll make that change that in the next PanelDue firmware release.
                      • Skimmyundefined
                        Skimmy
                        Haha, found the bug with "Geschwindigkeit" by myself… Another funny "fault" is the german translation for "invert display". It translates to "Farben invertieren" what means "invert colors". Correct translation would probably be "Anzeige invertieren". Maybe you could add this to some bug-reporting list if you like 🙂
                        my blog: https://www.well-engineered.net
                          Ya, gerne!
                          • janjohundefined
                            janjoh
                            @dc42:
                            How about a custom character? https://de.wikipedia.org/wiki/Geschwindigkeit lists it as a vector. ("V under arrow").
                            Otherwise, i think "Geschw." (with the period) would be linguistically acceptable?
                            Or else maybe "m/s" "mm/s" "mm/m"?
                              I used "Speed" because that was suggested earlier.
