    New PanelDue firmware 1.21RC4 available
    Firmware installation
    13
    35
    4.3k
    • DjDemonDundefined
      DjDemonD
      www.precisionpiezo.co.uk
      • Dougal1957undefined
        Dougal1957
        @dc42:
        @Dougal1957:
        David
        Have you built the 7.0C Version for the V2 boards?
        I have downloaded it and flashed the board but it is still showing as 1.20B1.
        Tried it 3 times just in case!
        Doug
        I thought I had, but I've just rebuilt it and re-uploaded it. So please try again.
        Tried this again and it still shows as 1.20Beta 1 it's as if the Github hasn't refreshed time stamp shows same as the original files as well on the Git.
        Doug
        Ignore that My bad I was getting them from https://github.com/dc42/PanelDueFirmware/tree/master/Release/Edge-old which tho are labeled as 1.20rc4 they are all different file lengths from the ones in the release folder. Pays to follow links rather than go to the source GitHub
          Please confirm that you are getting it from here https://github.com/dc42/PanelDueFirmware/releases/tag/v1.21RC4.
            Dougal1957
            @dc42:
            See my edited post above all now sorted thanks.
            Doug
              I see what happened. I renamed the Edge folder to Edge-old because I didn't want people using it; but the renaming means that github thinks the files init are new, so it has labeled then as being from the beta4 commit.
              • timcurtis67undefined
                timcurtis67
                Is it necessary to update to a version 3 board if I want to add a splash screen to my 7" paneldue? I have a V2 currently.
                  Dougal1957
                  @dc42:
                  Well I am getting old and senile David so get easily confused. but all sorted now
                    That depends:
                    • The binary + splash screen compressed image must together fit into the flash memory of the processor
                    • V2 boards may have ATSAM3S2B processors (128Kb flash), or ATSAM3S4B processors (256kb) flash
                    If your V2 board is the 256Kb flash version, you can add a splash screen. If it is the 128Kb version, you can only add a splash screen if you are using the 4.3" display and the splash screen compresses well.
                      timcurtis67
                      Thanks David, I will check the memeory on my Paneldue tonight. I may just upgrade anyway due to the other features of V3.
                      • garyd9undefined
                        garyd9
                        @garyd9:
                        I'd submit a pull request for this, but I'm currently at my paying job so can't fork, edit, etc:
                        Posted a pull request for two of the changes (that don't change any functionality.)
                        • mrac1undefined
                          mrac1
                          I've installed the update today and I like the macro reachability, but the issue with dialogs is not solved and I really, really don't like the dimming "feature". Please insert something in the settings tab to switch it off!
                          • garyd9undefined
                            garyd9
                            @mrac1:
                            I just submitted a github pull request that includes this (as well as an option to only dim if the printer status is idle.)
                            • JuJuDeltaundefined
                              JuJuDelta
                              I am having trouble flashing my PanelDue7i
                              I am using same Bossac tools that work with my older 7" PanelDuet V1.0 which work with that.
                              On a W10 64 bit PC:
                              Connect 7i to PC with uUSB cables, get the usual enuneration beeps, device manager reports Bossa Program Port on com3
                              I do the erase reset on the 7i, screen goes blank,
                              Go to terminal mode and run
                              C:\3D_Printer_Stuff\Bossac>LISTCOMPORTS
                              COM3 - Arduino LLC (www.arduino.cc) - USB\VID_03EB&PID_6124\6&2A0F59D2&0&4
                              C:\3D_Printer_Stuff\Bossac>bossac.exe –port=COM3 -e -w -v -b PanelDue7i.bin
                              No device found on COM3
                              Repeating the above with 7" PanelDuet V1.0 and relevant bin file works.
                              Any ideas ?
                              T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                              • garyd9undefined
                                garyd9
                                I've found in my own experiences with a normal 5 inch (paneldue v3) that sometimes you just have to wait a minute or two after the COM port shows up before bossac works. Until then, even though device manager shows the port properly, bossac won't work with it.
                                • garyd9undefined
                                  garyd9
                                  You might also consider jumping to RC5 which was just made available about an hour ago. 🙂
                                    JuJuDelta
                                    What a Dunce ! I've sorted this now, sorry for my ramblings above.
                                    Needed windows BOSSA 1.8 not cmd line BOSSAC.EXE
                                    RTFM !
                                    https://miscsolutions.wordpress.com/paneldue/
                                    http://www.shumatech.com/web/products/bossa
                                      This release has now been superseded by 1.20RC5.
