    New PanelDue firmware 1.21RC4 available
    Firmware installation
    13
    35
    4.3k
      Please confirm that you are getting it from here https://github.com/dc42/PanelDueFirmware/releases/tag/v1.21RC4.
      • Dougal1957undefined
        Dougal1957
        @dc42:
        See my edited post above all now sorted thanks.
        Doug
          I see what happened. I renamed the Edge folder to Edge-old because I didn't want people using it; but the renaming means that github thinks the files init are new, so it has labeled then as being from the beta4 commit.
          • timcurtis67undefined
            timcurtis67
            Is it necessary to update to a version 3 board if I want to add a splash screen to my 7" paneldue? I have a V2 currently.
              Dougal1957
              @dc42:
              Well I am getting old and senile David so get easily confused. but all sorted now
                That depends:
                • The binary + splash screen compressed image must together fit into the flash memory of the processor
                • V2 boards may have ATSAM3S2B processors (128Kb flash), or ATSAM3S4B processors (256kb) flash
                If your V2 board is the 256Kb flash version, you can add a splash screen. If it is the 128Kb version, you can only add a splash screen if you are using the 4.3" display and the splash screen compresses well.
                  timcurtis67
                  Thanks David, I will check the memeory on my Paneldue tonight. I may just upgrade anyway due to the other features of V3.
                  • garyd9undefined
                    garyd9
                    @garyd9:
                    I'd submit a pull request for this, but I'm currently at my paying job so can't fork, edit, etc:
                    Posted a pull request for two of the changes (that don't change any functionality.)
                    • mrac1undefined
                      mrac1
                      I've installed the update today and I like the macro reachability, but the issue with dialogs is not solved and I really, really don't like the dimming "feature". Please insert something in the settings tab to switch it off!
                      • garyd9undefined
                        garyd9
                        @mrac1:
                        I just submitted a github pull request that includes this (as well as an option to only dim if the printer status is idle.)
                        • JuJuDeltaundefined
                          JuJuDelta
                          I am having trouble flashing my PanelDue7i
                          I am using same Bossac tools that work with my older 7" PanelDuet V1.0 which work with that.
                          On a W10 64 bit PC:
                          Connect 7i to PC with uUSB cables, get the usual enuneration beeps, device manager reports Bossa Program Port on com3
                          I do the erase reset on the 7i, screen goes blank,
                          Go to terminal mode and run
                          C:\3D_Printer_Stuff\Bossac>LISTCOMPORTS
                          COM3 - Arduino LLC (www.arduino.cc) - USB\VID_03EB&PID_6124\6&2A0F59D2&0&4
                          C:\3D_Printer_Stuff\Bossac>bossac.exe –port=COM3 -e -w -v -b PanelDue7i.bin
                          No device found on COM3
                          Repeating the above with 7" PanelDuet V1.0 and relevant bin file works.
                          Any ideas ?
                          T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                          • garyd9undefined
                            garyd9
                            I've found in my own experiences with a normal 5 inch (paneldue v3) that sometimes you just have to wait a minute or two after the COM port shows up before bossac works. Until then, even though device manager shows the port properly, bossac won't work with it.
                            • garyd9undefined
                              garyd9
                              You might also consider jumping to RC5 which was just made available about an hour ago. 🙂
                                JuJuDelta
                                What a Dunce ! I've sorted this now, sorry for my ramblings above.
                                Needed windows BOSSA 1.8 not cmd line BOSSAC.EXE
                                RTFM !
                                https://miscsolutions.wordpress.com/paneldue/
                                http://www.shumatech.com/web/products/bossa
                                  This release has now been superseded by 1.20RC5.
