    New firmware 1.21RC3 available
    Firmware installation
    31
    159
    23.8k
    • garyd9undefined
      garyd9
      @dc42:
      @garyd9:
      I don't know if this was fixed in RC3 or not…
      When setting up a z-probe with P5 (It's a BLtouch) A3 (probe each location up to 3 times) and B1 (turn off bed heater while probing), the heater gets turned off for the FIRST of multi-tap probes, but not subsequent multi-tap probes.
      I believe that was fixed in RC3 along with the other multi-touch issues, but please check.
      I can confirm that this IS fixed in RC3 for G30 probes (multi-tap or otherwise.) However, if the probe is used as an endstop (G1 S1), the heater is not turned off. (I'm still using my BLTouch as a "P5" instead of a "P9" if that matters.)
      Given the following two gcode lines, the FIRST one does not turn off the heater. The second one DOES turn the heater off.
      [[language]]
      G1 S1 Z-155 F6000	; heater isn't turned off
      G30 ; heater IS turned off
      • garyd9undefined
        garyd9
        In regards to the new S2 requirement for unhomed G1 moves on non-Delta printers:
        I was making code changes in PanelDue to force the S2 parameter to always be sent when I decided to read the duet gcode wiki and see what side effects it might have. There I found out that "G1 S2" has a completely different meaning on delta printers when compared to non-delta printers. Here's my understanding (and if I'm wrong, please correct me):
        A normal "G1" on a cartesian printer moves the axis specified. So "G1 X" moves the X stepper motor, etc. Passing a "S" parameter (S1, S2, etc) doesn't change that.
        On a delta, however, a normal "G1" actually often ends up moving THREE different stepper motors in order to make a straight horizontal or vertical move. So, it's actually more of a "virtual" move in that the duet board has to figure out which steppers have to move (and in which direction) to move the print head a given distance on a single line. (Making it really confusing, each stepper motor is labeled X, Y, or Z - but those labels have nothing to do with straight lines in the printed space.)
        On those deltas, however, passing a "S" parameter completely changes the meaning of the G1 command. If S1, S2, or S3 is passed to G1 on a delta, the G1 command doesn't mean to move the print head a given distance on a given line, but instead means to move a specific stepper motor (remember that each motor has a X/Y/Z label?) a given distance. So, while "G1 X10" on a delta might move the print head 10mm to the right, "G1 S2 X10" will actually cause the print head to move in 3 dimensions (slightly down and either left or right depending on which stepper motor is labeled "X".)
        Why does all this matter?
        Because now I'm more opposed to this change as it's currently implemented in RC3. It means that the same VALID command on two different printers will have completely different end results. I realize that this situation already exists with "G1 S1", but at least in that case they both mean "detect endstop" and hopefully they're only used for that. In the case of "G1 S2", which is now valid for both printer types, one printer will "move in cartesian space" and the other will "move in… delta space?" (not sure what the proper term would be.)
        If there's really some good reason to not allow un-homed moves (and please share it with those of us testing the changes), then at least add a new non-delta S parameter for moving when not homed on cartesian (and corexy) printers where X is always X, Y is always Y, and Z is always Z. Perhaps "S4." On delta's, the parameter would be completely ignored and treated as if no S parameter was passed.
        One other reason: It makes it easier for me to add a parameter to the paneldue's "jog" buttons without wondering what kind of problems I'd introduce on a delta machine. 🙂
          @garyd9,
          1. Thanks for confirming the the heater is turned off correctly when doing bed probes in RC3.
          2. G1 S1 Z moves should only be done if you are using an endstop switch for homing Z. To home using a Z probe, use G30.
          3. Please explain why you consider it such a problem that you can no longer use the Move buttons in DWC/PanelDue before the corresponding axes have been homed. This has always been the case for Delta and SCARA printers, is the default for some other firmwares already, and is the only sensible default for a CNC machine.
            Please can those of you running 1.21RC4 on a Duet WiFi try upgrading DuetWiFiServer to 1.21RC4. I need feedback on this version asap because a deadline is approaching.
            • resamundefined
              resam
              DC42:
              Again, in case of failure or emergency there is no way to quickly move an axis after a reset.
              I was stuck twice now since the new RC3 with a hot nozzle in either my bed or a printed part.
              Immediate reaction is to hit the reset button to stop all further movements.
              Now all axis are unhomed, the nozzle is melting away my part and bed surface - AND I CAN'T MOVE AWAY!
              What would you recommend in such a way?
              Please provide an override, aka "Allow unhomed moves" M-code, and provide a button/checkbox on DWC + PanelDue to allow unhomed moves!
              • okerchoundefined
                okercho
                @dc42:
                I've updated the wifi server in my home printer from my office and it never came back, so I'm assuming the issue with my AP is still there. I can restart it (it's connected to a wifi plug) but I won't so I can check the error message in the PanelDue, but I assume is the usual "incorrect password" message.
                Regards
                Okercho
                Custom Prusa i3 Hephestos with Duet Wi-Fi
                E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                Rebuilding Hypercube Evolution
                  deckingman
                  @resam:
                  I haven't upgraded yet but I agree it's a bit of a pain. I can also see why some people might want to have that feature though. Ideally having the ability to enable or disable the "no moving until homed" feature, say in config.g would be good. Otherwise, I guess all we can do is create a macro to move Z using S2. Something like G91, G1 Z10 S2 Fnnn, G90 and call it say "Emergency Z move" or some such.
                    @deckingman:
                    @resam:
                    That's what I would do, have a macro to raise Z by 5mm or so. The latest PanelDue firmware allows you to show 4 macros on the main screen, so running one of them is quicker than pressing Move and then a movement button.
                    I have been considering making M564 S0 allow movements before the printer is homed.
                    • kraegarundefined
                      kraegar
                      Yep, I made a quick macro to raise Z by 5mm and also reset my bltouch. I need to get the paneldue upgraded so it's quicky available at the printer, but it's been the best solution for cases where I power on and the bltouch is too close to the bed to reset.
                      • garyd9undefined
                        garyd9
                        @dc42:
                        I'll get the easy part out of the way first: "This has always been the case for Delta and SCARA printers," I don't know anything about SCARA printers, but am I correct that the "home" position for a delta is all three carriages at the TOP of the towers? In other words, "home" would move the print head as far as possible from the build plate? In contrast, "home" on most cartesian printers is at Z-min: The print head is up against the build plate.
                        Why does this matter in regards to this change? Because if the only valid "movement" for an unhomed printer is to home it, then there's no conflict whatsoever for a delta printer regardless of if something is on the build plate, or if the build plate even exists. On the other hand, with a cartesian printer, "homing" the printer might even be impossible with something on the build plate.
                        On a delta, "home" reduces any conflict between the print nozzle and a printed object. "Home" as part of completing a print makes sense.
                        On most cartesians, "home" will almost always create conflict (to the point of being impossible) between the print nozzle and a printed object. "Home" as part of completing a print is usually impossible – so much so that many cartesian printers will max Z and turn off the X and Y motors just to try and reduce conflict between the newly printed object and the print nozzle. In doing so, they become unhomed.
                        "...is the default for some other firmwares already..."
                        I've only used Marlin (I think it was marlin) on an i3 clone, Sailfish on a flashforge creator pro (makerbot clone), and RRF. So far, up until today, I've never seen this restriction on a cartesian printer. In both non-RRF cases mentioned, the default configuration of the printer/software would leave the printer in an un-homed state at all times unless it was printing, yet still had jog controls that functioned. Usually, manually moving the print carriage/head on an un-powered motor is discouraged as it creates voltage sent back to the circuitry.
                        As for why I consider it a problem:
                        I partially addressed this above. Others have also addressed it and given many reasons. In addition to those, I'll give one more: Manually leveling a build plate on a cartesian printer requires moving the print nozzle around. Homing the machine first usually isn't a good idea (as the build plate isn't leveled yet, so the nozzle might crash.) Manually moving the nozzle/carriage (by hand) isn't a good idea (for the reasons mentioned above about the steppers sending voltage back.) The best option is to use jog type controls to move the nozzle around a little at a time and start slipping a piece of paper underneath and turning screws. Using a macro for this can be cumbersome, as often times I just want to move a couple of cm in one direction or another to try and make the best of an imperfect carriage rod.
                        In fact, a cartesian printer spends nearly all non-printing time in a non-homed state. To use your own words, this is how other firmwares do it. This is out of necessity. By making DWC and PanelDue jog controls useless in this state, you are effectively reducing the value of the entire Duet system for non-Delta users. If the printer is only homed when printing, and the jog controls only worked when homed, what purpose do those controls have at all?
                        Please... PLEASE keep in mind that MANY duet and paneldue users don't have delta printers. This change doesn't add any value for them whatsoever. Taking functionality away from cartesian users just because delta users never had it makes no sense. That reasoning would result in enforcing a max print speed of 60mm/sec on delta printers because most cartesians can't print (cleanly) at higher speeds.
                        • garyd9undefined
                          garyd9
                          Just a point to add to my previous post:
                          The change wouldn't be as bad if the parameter to G1 that allowed unhomed moves didn't directly conflict with delta printers. While it would be simple to add the S2 parameter to the DWC and PanelDue jog controls, doing so would break those controls for use with Delta printers (because of how S2 changes the meaning of G1 commands on delta printers.) So, as mentioned earlier, adding an "S4" to allow unhomed moves (assuming S4 is ignored on Deltas) would be a viable (if undesirable) work-around.
                          Adding the "M564 S0" you mentioned above would also allow DWC/PanelDue to override the restriction - it'd just be one more command that would be sent before the G1 (similar to how G91 is sent before the G1 now.) This actually makes more sense than adding another S parameter to G1. However, it's extending the meaning of an existing command which can be a slippery slope. (Example: G10)
                          In either case, however, I still believe that the "no normal unhomed moves" restriction doesn't make sense on cartesian printers to begin with. I've yet to see a good reason for that change.
                            deckingman
                            @dc42:
                            How would that work David? Currently M564 S0 will allow movement outside axis limits will it not? The default being S1 which constrains movement within axis limits. It would be great on a CoreXY (or Cartesian) to be able to allow movement before an axis has been homed (for reasons which others have so eloquently stated) but not at the expense of losing the constraint on axis limits after it has been homed.
                            • resamundefined
                              resam
                              I fully agree with garyd9. Count me as a second vote to everything just outlined in this post.
                                @garyd9, thanks for explaining your position.
                                First, I will not be generating S2 or anything similar as standard by default in PanelDue when the movement buttons are used, because doing so would be dangerous for CNC machines. We are getting an increasing number of people using Duets to control CNCs and I must ensure that safety is the default. That's one of the main drivers for making this change. The other is that we have had a few complaints from users who have damaged their machines because movement was allowed when the printer was not homed, in one case accompanies by "my old firmware didn't let me do that". Therefore, whatever else we do, the default will be not to allow movement of an axis before it is homed.
                                The point that you can't home a typical Cartesian printer with a print on the plate is a good one, and suggests that a simple means to raise the nozzle/lower the bed is useful. This could be a macro or a dedicated button.
                                The point about moving the head to level the bed manually appears somewhat spurious to me, even ignoring the fact that RRF provides a manual bed levelling assistant, which can be used without a Z probe. For rare operations such as that, I don't see it as unreasonable to expect the user to have to do something to override the usual safety restrictions. Once you home X and Y, you can move the head in the XY plane. You may then want to jog Z to measure the height above the bed. For that, I can see that an option to allow you to jog an un-homed Z axis could be useful - although personally I would just home Z first, or use G92 to pretend it is homed.
                                Btw I do have a Cartesian printer, and I have been using it with this additional safety feature in the firmware for more than a week.
                                Coming back to M564, currently we have:
                                S0 - allow movement outside limits
                                S1 (in practice, Sn for n >= 1) - don't allow movement outside limits
                                I could add another parameter:
                                H0 - allow movement before the axis has been homed (not for Delta or Scara printers)
                                H1 - don't allow movement before the printer has been homed (default)
                                Would you be satisfied with that? After M564 H0 should movement to absolute positions be allowed, or only relative movement?
                                • garyd9undefined
                                  garyd9
                                  @dc42:
                                  Understandable (but please see comments IRT paneldue later in this post.)
                                  @dc42:
                                  SAFETY is a good reason.
                                  @dc42:
                                  Yes, that would be reasonable. It should only allow relative movements (as absolute movements make no sense when you aren't homed. How can you move to 0,0,0 absolute when you don't know where 0,0,0 is?)
                                  Back to PanelDue:
                                  Would you accept a pull request for PanelDueFirmware that added an option in settings, defaulting to OFF, that enabled sending "M564 H0" before any jog command? By default, unhomed jogs wouldn't work, but by enabling this setting, they would (at least on printers where M564 H0 allowed unhomed moves.)
                                  (The code change involves adding a uint32 to FlashData, an extern function to PanelDue to access the bitflags, and the obvious change in UserInterface.cpp to set H0 before the G1 and H1 after the move.)
                                  I'd also suggest the same/similar toggle be added for DWC, but I'm much more fluent with C++ … and useless with javascript.
                                  Edit: No need for messing with paneldue/DWC as mentioned later in this thread.
                                  • whosrdaddyundefined
                                    whosrdaddy
                                    +1 for M564 H0
                                    @Garyd9, adding M564 H0 to config.g would be enough, no need to add an option to PanelDue/DWC.
                                      deckingman
                                      @dc42:
                                      Personally, I'd be happy with that. If it just means putting M564 H1 into my config.g file which will easier than having to edit my homing files and also save me the hassle of creating a macro and more importantly, remember that I have to use it.
                                      I appreciate the safety concern but over the years, I've become accustomed to doing things a certain way. As well as the scenarios that others have put forward, I often just want to drop the bed 100mm or so to get it out of the way when I want to change hot ends, remove the glass for cleaning, apply a coat of 3d lac without getting it on the hot end or otherwise work on the printer. So having to home it first when I don't even want to print anything would be a bit of a PITA.
                                      • garyd9undefined
                                        garyd9
                                        @whosrdaddy:
                                        +1 for M564 H0
                                        For some reason, I completely overlooked that M564 H0 could be left permanently enabled (via config.g.)
                                        • resamundefined
                                          resam
                                          Yes, M564 H0 would be acceptable. I probably also put it in my config.g.
                                          Thanks!
                                          If you really want to make me happy, please add a button in the PanelDue jog window - so this override is accessible when needed.
                                          • Catalin_ROundefined
                                            Catalin_RO
                                            Regarding homing for CNC machines, I think that the truth is somewhere in the middle. For rather simple machines, with no slave axis and no extra features (like touch probes for the tool length or tool changers), homing is not needed at all. One just jogs the spindle to the desired position, based on the already positioned raw material, zeros the coordinates and starts the job. With GRBL the homing can be disabled completely and a freshly started machine, although it reports it needs homing, can be software reset and unlocked and homing is no longer needed no matter what.
                                            Realistically now, with CNC homing is really necessary for machines with slave axis that can get out of sync (independent motors as the solution with mechanical link between the master and slave axis is much simpler for the controller) and when there are various tools installed at well defined machine coordinates.
                                            Looking differently at it, for 3D printing it might be more important than for simple CNC machines. With 3D printing you have to print an item of a certain size and you need to know that the object won't get beyond the printable area if the origin of the print is not correctly set. With CNC you already have a big lump of raw material, at least as large as the final item, and if you know the area that the machine can "process", it is practically impossible to go beyond that (misplacing the raw material or going for a smaller piece is not considered here!).
                                            As for the dangers of homing, the CNC world has its own! It is not unheard of using a tool longer than what is safe in the machine setup, based on the fact that one can manually jog through the obstacles to the location where the machining has to be done. Homing in such situations, although the Z-axis is almost always the first one, doesn't guarantee that the tool doesn't touch an obstacle. Allowing manual jogging without homing first would be very useful in these situations as well! (been there myself, luckily with rather inexpensive tools in the spindle!)
                                            In conclusion, there should be a rather easy solution for jogging without homing, especially because the emergency situations are really critical! By default it should not be allowed, but a manual override solution would be great. User defined macros are acceptable from my point of view….
