    Heating the Hotend and the Bed
    2.0k
      1. Is it a PCB bed heater? It's very common for them to be under-powered.
      2. Measure the voltage appearing on the bed heater when it is running at full power. If it is significantly less than 12V, then you have excessive voltage drop in your SSR or cables. I hope you chose a good low voltage drop SSR, not a SSR-40DD.
      3. You can turn up the power supply voltage to the CoreXY to get more heating power. Unless it is an ATX power supply, there is likely to be a potentiometer at one end of the terminal strip.
      4. Why are you using SSRs on the hot ends? They are never needed.
      5. If you suspect the hot end temperature readings are wrong, check that you have the correct thermistor parameters in the M305 command.
      HTH David
      • Scottbg1undefined
        Scottbg1
        David,
        I am embarrassed to admit I told you I had SSR's when I have mosfets. I always thought that an SSR and a Mosfet were the same until now. Thank you Google.
        And to add insult to injury, I bought them for the Duet but I never installed them.
        I just recently rewired my Prusa clone, which does have both Mosfets installed and when I was typing this post out I had it pictured in my mind that they were installed on my Duet. Imagine my surprise when I took the door off the case for my Duet and it was all alone in there. If you're shaking your head right now in disbelief, it is well deserved. I am not usually this inept.
        When I commissioned my first El-cheapo 3D Printer the integrated mosfet on the control board fried on the very first print.
        I had to wait a month for a replacement to arrive from China, and during that time I read everything I could about the problem and the consensus among the folks who had the same problem swore by having them on the hotbed and hotend. In my defense, one mental giant adding to the conversation posted a picture of a Mosfet that he installed on his, but he called it an SSR. Lesson learned, don't believe everything you read on the internet. I suddenly feel the urge to give up 3D printing and partake in something a little less intellectually demanding, like basket weaving. Again, forgive me.
        Nevertheless, I swiftly installed them along with the replacement control board onto my Prusa clone.
        The investment I made in the Duet board, seemed to justify doing the same.
        Little good they are doing in the box of wiring stuff in my cabinet.
        So a revision: No protection of any kind installed on the heaters of my Duet Wifi.
        I am indeed running an ATX.
        My heat bed is a PCB.
        Shall I continue with measuring the voltage for the bed? Or is it still necessary now, knowing nothing is between the Duet board and the bed?
        Shall I hurriedly install the Mosfet (aka SSR) to my duet?
        For the record, here in the deep south of these United States, we call all carbonated drinks, 'Coke'.
        A perfectly acceptable conversation in my area would go like this…
        Scott- Billy Bob, you want a Coke?
        Billy Bob- Sure!
        Scott- What kind?
        Billy Bob- Diet Pepsi.
        Scott- Coming right up!
        I could talk about ya'll too.
        You guys spell the word "color" wrong, and you don't pronounce 'Aluminum" correctly either.
        (You notice my attempts at being witty and humorous to distract you to the fact that I am an idiot? I hope it worked)
        Thanks for the help. Truly.
          No need to install the MOSFETs. It's still worth measuring the voltage on the bed terminals - take great care not to short the multimeter probes together while doing this. Then compare that voltage with the voltage on the PSU output terminals.
          If there is a difference of more than about 0.2V between the two voltages, consider using thicker wires, and check that the terminal block screws on the Duet are tight. Otherwise, turn up the voltage on your 12V PSU, then retune the heaters.
          • Scottbg1undefined
            Scottbg1
            @Scottbg1:
            I know you can adjust psu voltage, but from my research you can't adjust atx voltage without modifying it.
            Isn't this correct?
            Maybe the atx is the problem for ALL my heating problems and I should just replace it with a psu.
            Or maybe a bigger atx? I thought 450w of which 360w is dedicated to the rail running to the board would be plenty.
              You may find that your ATX PSU is providing somewhat less than 12V on its 12V output. The less expensive ATX PSUs use a single feedback loop that averages the error on the 12V and 5V outputs. So if you have a low load on the 5V output and a much bigger load on the 12V output, the 5V rail ends up being high and the 12V rail ends up being low. The better branded PSUs don't have this problem.
              • Scottbg1undefined
                Scottbg1
                Thank you, David.
                Is there an ATX that you'd recommend that would power everything adequately?
                I thought I had bought a decent one, but apparently not.
                  What brand of PSU did you buy?
                  I only have experience of two ATX PSUs powering a 3D printer. The Alpine PSU (550W AFAIR) one that came with my Ormerod kit had the problem I referred to above. I then purchased a Corsair CX430M, and that one was much better - the 12V rail remained close to 12V under varying loads and the bed heating time was less. But after that I bought a cheap 300W fanless Chinese LED/CCTV PSU and enclosed the business end of it like this https://www.thingiverse.com/thing:441081. It's been powering that printer for about 3 years.
                  • Scottbg1undefined
                    Scottbg1
                    APEVIA Venus 450W from Amazon.
                    It had good reviews and I never thought the power drop would be that much despite the higher wattage.
                    The only reason I wanted an ATX was for the remote power on option, the ability to navigate DWC without powering up the whole printer, and the 5v rail to power my Pi Cam, all in one box and having one power cord for everything.
                    I am of the mind now to just get good PSU and turn it on the old fashioned way, while separately powering the RPI.
                      I suggest you measure the 12V output of the PSU, with the bed heater both off and on, to see how good that PSU is.
                      • carlossprundefined
                        carlosspr
                        ATX PSUs aren't just 12V. A 450W PSU will be the 3.3V, 5V, and 12V rails added together. On the Apevia Web page the current on the 12V rail is 32A, i.e. 384W. Therefore the Anet and CoreXY should be similar on the paper. If the ATX supplies several 12V rails, the current on one f the rails might be even lower.
                        Have you tried to perform a PID tuning (M303) wit the P parameter? The P parameter is the PWM fraction to use.
                        I have recently migrated my PSU to 24V with a 50W heater and I noticed that with standard PID calibration the M303 without the optional P parameter produced a temperature overshoot. The temperature it raised very quickly to the desired temperature, but the risk of fire in the case of an issue is high. I returned the temperature adding the P parameter with a final value of 0.3 that does not produce the temperature overshoot warning but on the downside it takes longer to reach the printing temperature. It is not a big problem for me, because the print has to wait for the bed anyways.
                        As I understand from the Wiki, the default value for the P parameter is 0.5. Try re-tuning the PID with a specific P parameter on higher values and check the results.
                          carlosspr
                          This is the specification for you PSU on the Apevia Web page: http://www.apevia.com/ProductsInfo.asp?KEY=Venus%20Power%20450W%20(ATX-VS450W)
                            @carlosspr:
                            That's only true for old versions of firmware. On recent versions (1.18 and later AFAIR) the tuning algorithm is different and P1.0 is the default.
                            If you are using a 12V heater cartridge with 24V power, I strongly advise you to buy a 24V cartridge and use that instead.
                              carlosspr
                              Thanks for the clarification. I just re-read the Wiki and for V1.18 it mentions the default value of P=1.0 (my bad)
                              My cartridge is from Aliexpres and specifies 24V/50W. However I have measured a resistance of 8.1 ohms, which would mean 20W if powered with 12V and 71W if powered with 24V. That got me thinking of the quality…...
