    Z Probe Help
    1.1k
    • Kozlowundefined
      Kozlow
      Hi
      The Z probe that I have doesn't have the identification sticker on it, but I believe that it is an SN04-N ( NPN NO ),
      but It could be an SN04-N2 ( NPN NC).
      I believe it to be normally open because if I hook it up as a normal endstop switch it will work as a open switch.
      The problem is when I hook it up as per WIKI instructions, Blue wire to ground, Brown wire to 5v, Black wire to cathode end of a
      Bat85 Schottky diode, anode end to E0 stop pin.
      The probe when triggered reads 0 on the Duet Web Control, and reads 1000 when untriggered.
      That makes it seem like a normally closed switch. The wiki doesn't address normally closed probes, that I seen.
      If I change the M574 E0 S0 to S1, were I'm guessing that the S1 = active high endstops, nothing changes.
      So…What am I doing wrong?
      Here is my firmware settings
      M574 X1 Y1 S1 ; Set active high endstops
      M574 Z1 S2 ; Set endstops controlled by probe
      M574 E0 S0 (S1)
      M558 P4 H5 F360 T6000 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X0 Y0 Z4 ; Set Z probe trigger value, offset and trigger height
      M557 X50:271 Y35:271 S20 ; Define mesh grid
      Thanks for any and all help.
      Steve
        Add parameter I1 to the M558 command.
        • Kozlowundefined
          Kozlow
          AH Ha!!
          Thanks dc42. That fixed it.
