    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.3k
      Not sure if this is intended or not, but when trying to simulate a file I get various error messages if the axes are not homed first.
      [c]2:02:49 PMM37 P"z-motors_fixed.gcode"
      Simulating print of file z-motors_fixed.gcode
      Cancelled simulating file z-motors_fixed.gcode after 0h 0m simulated time
      Error: G0/G1: insufficient axes homed
      2:02:16 PMWarning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
      2:02:16 PMM37 P"lm2596_case_fixed.gcode"
      Simulating print of file lm2596_case_fixed.gcode
      Error: SetPositions called when DDA ring not empty
      Cancelled simulating file lm2596_case_fixed.gcode after 0h 0m simulated time[/c]
        That's a known issue.
        • Nengermanundefined
          Nengerman
          I have updated the firmware from 1.20 to 1.21. Now the printer does not work anymore.
          When I upload a print file, the bed and the extruder are heated, then the printer stops as if it is ready.
          At Home All I get the error message G0 / G1: insufficient axes homed.
          • resamundefined
            resam
            Nengerman: you have to read the release notes! Homing on a Cartesian/CoreXY printer changed.
            • Doc_Penguundefined
              Doc_Pengu
              Does you'r homing script 1st lower/raise bed before it homes X and Y ? If so you need to add S2 parameter to you'r Z axis movement and then X and Y can be homed and Z axis after that 🙂
              • Knaudlerundefined
                Knaudler
                @dc42:
                Get it from https://github.com/dc42/RepRapFirmware/releases/tag/1.21 and be sure to read the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. If you want the full list of changes since release 1.20, for now you will have to read all of the 1.21RC release notes too, but in a few days I'll delete the 1.21RC releases and consolidate the change lists.
                Hello
                there ist webcontrol 1.21 out
                https://github.com/chrishamm/DuetWebControl
                Ingo
                  Thanks, I've updated the release to include it.
                  • appjawsundefined
                    appjaws
                    I was running rc4 and have today updated to 1.21. I expected this to just work.
                    I uploaded the Duet2CombinedFirmware.bin, DuetWiFiServer.bin, iap4e.bin and DuetWebControl.zip files. When the duet rebooted it could not connect.
                    The USB printer interface connected to the printer so I tried to run M997 S0 to install the firmware again but this did not work.
                    I then erased and reset the board and used BOSSA 1.18 to install, so device manager shows Duet 2 WiFi or Duet 2 Ethernet 3D printer control electronics (COM5)
                    Then reset the board and connected the USB again. The printer is online but when I send M997 S0 I get the error Can't read from printer (disconnected?).
                    I have followed the Fallback procedure instruction on https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                    I am now stumpted How can I resolve this?
                    appjaws - Core XYUV Duet Ethernet Duex5
                    firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                    Ormerod 1-converted to laser engraver, Duet wifi
                    OpenSCAD version 2024.03.18
                    Simplify3D 5.1.2
                    • appjawsundefined
                      appjaws
                      This is the result of M122.
                      SENDING:M122
                      Used output buffers: 1 of 32 (1 max)
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 + DueX5
                      Board ID: 08DAM-999TL-NL5T8-6J1DL-3SJ6P-T65BJ
                      Static ram used: 16152
                      Dynamic ram used: 100440
                      Recycled dynamic ram: 2192
                      Stack ram used: 3576 current, 4456 maximum
                      Never used ram: 7832
                      Last reset 00:00:13 ago, cause: power up
                      Last software reset at 2018-03-12 17:04, reason: User, spinning module GCodes, available RAM 7768 bytes (slot 2)
                      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                      Error status: 0
                      Free file entries: 10
                      SD card 0 detected, interface speed: 12.0MBytes/sec
                      SD card longest block write time: 0.0ms
                      MCU temperature: min 18.1, current 21.3, max 21.4
                      Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0
                      Driver 0: ok, SG min/max not available
                      Driver 1: ok, SG min/max not available
                      Driver 2: ok, SG min/max not available
                      Driver 3: ok, SG min/max not available
                      Driver 4: ok, SG min/max not available
                      Driver 5: ok, SG min/max not available
                      Driver 6: ok, SG min/max not available
                      Driver 7: ok, SG min/max not available
                      Driver 8: ok, SG min/max not available
                      Driver 9: ok, SG min/max not available
                      Expansion motor(s) stall indication: yes
                      Slowest main loop (seconds): 0.000242; fastest: 0.000047
                      MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                      Bed compensation in use: none
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is ready with "M122" in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      HTTP sessions: 0 of 8
                      • WiFi -
                        Network state is disabled
                        WiFi module is disabled
                        Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                        === Expansion ===
                        DueX I2C errors 0
                      Simplify3D 5.1.2
                      • appjawsundefined
                        appjaws
                        This is after re-enabling M552 S1 in config
                        === Network ===
                        • WiFi -
                          Network state is starting
                          === Expansion ===
                          DueX I2C errors 0
                        Simplify3D 5.1.2
                        • appjawsundefined
                          appjaws
                          resolved
                          For some reason it appears that the WiFi server had not started.
                          re-installed and now all OK.
                          Simplify3D 5.1.2
                          • DunstonUKundefined
                            DunstonUK
                            It is alright changing stuff around, but how do you raise your Z when you have a bed crash, and all you get is
                            M120
                            G91
                            G1 Z5 F6000
                            M121
                            Error: Pop(): stack underflow!
                            and Yes I do have S2 in the files.
                            Life’s bucket list is never ending. Remember someone else is always better than you.
                              Those messages indicate that the printer was not homed when you ran that command. I guess you powered the machine down when you had the crash and then powered it up again. Possible actions in this situation include;
                              • Home the printer. The homall file for a Cartesian or CoreXY printer normally raises the head a few mm before it does anything else.
                              • Use M564 H0 to allow movement before axes are homed, either in config.g if you want it to be permanent, or temporarily
                              • Use a macro to raise the head by 5mm, using S2 on the G1 Z command
                              • jnolan72undefined
                                jnolan72
                                I am getting
                                Request Timeout
                                The last HTTP request has timed out. Please make sure the connection between your device and the board is not interrupted.
                                Anytime I go into G-Code Files then into a Directory with lots of files. I get a spinney icon then
                                request Timeout
                                the files has a * infront of them.
                                Looks like when I go into a directory that I have not gone into after the patch
                                Some sort of processing is going on change the * to a page icon
                                Same problem when I upload a large gcode file
                                when I hit close after uploading
                                the file show a * and the the Request Timeout
                                • resamundefined
                                  resam
                                  jnolan72: try to reformat your SD card. I have similar issues from time to time. I think the filesystem on my card just gets fragmented or something - or my card is bad in general.
                                  Copy all your files to you PC. Format & wipe the cards. Make a clean FAT32 filesystem, and copy your files back.
                                  Also make sure to keep not too many files in one folder. There is a limit on how many files the Duet can handle. Less than 50 files per folder usually works for me.
                                    That timeout is triggered when you have a very large gcode file on the SD card and your SD card is formatted with a small cluster size. You can send M39 to find the cluster size if you are running firmware 1.21.
                                    Get a new SD card, format it using FAT16 it is 4Gb or smaller, else FAT32 with 64kb clusters. Then copy all the files and folders over from the old SD card.
                                    Upgrading to firmware 1.21 may also help, if you are running an older version.
                                    • zerspaner_gerdundefined
                                      zerspaner_gerd
                                      three questions:
                                      1. what is meant by this?
                                        [c]For Duet 06 or 085: RepRapFirmware.bin and iap.bin[/c]
                                        Where do I see my version?
                                      2. Is the pressure range with nozzle offset checked during simulation?
                                      3. [c]When beginning a print from SD card, macro /sys/start.g is run if it is present[/c]
                                        Is there such a thing for the printing end?
                                      greeting
                                      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                        1. The Duet 06 and Duet 085 are older boards that pre-date the Duet WiFi and Duet Ethernet. The PCB revision is printed on the board. For those boards it is 0.6 or 0.8.5. For Duet WiFi or Ethernet it is 1.0, 1.01, 1.02 or 1.03.
                                        2. Please explain what you mean by "pressure range".
                                        3. Yes, stop.g.
                                        • rpolteraundefined
                                          rpoltera
                                          Unable to adjust z hight with my IR probe I have raised and lowered over 5mm what worked before is no longer working it doesn't seem to change it is over 2mm of the build pate now
                                          have tried
                                          G31 P500 X0 Y0 Z-5.9
                                          all the way to
                                          G31 P500 X0 Y0 Z5.9
                                          with no change in the hight I have read the notes on the new version but not seeing it am I missing something?
                                          as I mentioned this used to work flawlessly and now I cant use my probe please advise.
                                            Is there a G31 command in config-override.g that is overriding the one in config.g? Prior to version 1.20, M500 used to save the G31 settings; now it does so only if you provide an extra parameter.
