    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.3k
    • appjawsundefined
      appjaws
      This is after re-enabling M552 S1 in config
      === Network ===
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is starting
        WiFi module is disabled
        === Expansion ===
        DueX I2C errors 0
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • appjawsundefined
        appjaws
        resolved
        For some reason it appears that the WiFi server had not started.
        re-installed and now all OK.
        Simplify3D 5.1.2
        • DunstonUKundefined
          DunstonUK
          It is alright changing stuff around, but how do you raise your Z when you have a bed crash, and all you get is
          M120
          G91
          G1 Z5 F6000
          M121
          Error: G0/G1: insufficient axes homed
          Error: Pop(): stack underflow!
          and Yes I do have S2 in the files.
          Life’s bucket list is never ending. Remember someone else is always better than you.
            Those messages indicate that the printer was not homed when you ran that command. I guess you powered the machine down when you had the crash and then powered it up again. Possible actions in this situation include;
            • Home the printer. The homall file for a Cartesian or CoreXY printer normally raises the head a few mm before it does anything else.
            • Use M564 H0 to allow movement before axes are homed, either in config.g if you want it to be permanent, or temporarily
            • Use a macro to raise the head by 5mm, using S2 on the G1 Z command
            • jnolan72undefined
              jnolan72
              I am getting
              Request Timeout
              The last HTTP request has timed out. Please make sure the connection between your device and the board is not interrupted.
              Anytime I go into G-Code Files then into a Directory with lots of files. I get a spinney icon then
              request Timeout
              the files has a * infront of them.
              Looks like when I go into a directory that I have not gone into after the patch
              Some sort of processing is going on change the * to a page icon
              Same problem when I upload a large gcode file
              when I hit close after uploading
              the file show a * and the the Request Timeout
              • resamundefined
                resam
                jnolan72: try to reformat your SD card. I have similar issues from time to time. I think the filesystem on my card just gets fragmented or something - or my card is bad in general.
                Copy all your files to you PC. Format & wipe the cards. Make a clean FAT32 filesystem, and copy your files back.
                Also make sure to keep not too many files in one folder. There is a limit on how many files the Duet can handle. Less than 50 files per folder usually works for me.
                  That timeout is triggered when you have a very large gcode file on the SD card and your SD card is formatted with a small cluster size. You can send M39 to find the cluster size if you are running firmware 1.21.
                  Get a new SD card, format it using FAT16 it is 4Gb or smaller, else FAT32 with 64kb clusters. Then copy all the files and folders over from the old SD card.
                  Upgrading to firmware 1.21 may also help, if you are running an older version.
                  • zerspaner_gerdundefined
                    zerspaner_gerd
                    three questions:
                    1. what is meant by this?
                      [c]For Duet 06 or 085: RepRapFirmware.bin and iap.bin[/c]
                      Where do I see my version?
                    2. Is the pressure range with nozzle offset checked during simulation?
                    3. [c]When beginning a print from SD card, macro /sys/start.g is run if it is present[/c]
                      Is there such a thing for the printing end?
                    greeting
                    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                      1. The Duet 06 and Duet 085 are older boards that pre-date the Duet WiFi and Duet Ethernet. The PCB revision is printed on the board. For those boards it is 0.6 or 0.8.5. For Duet WiFi or Ethernet it is 1.0, 1.01, 1.02 or 1.03.
                      2. Please explain what you mean by "pressure range".
                      3. Yes, stop.g.
                      • rpolteraundefined
                        rpoltera
                        Unable to adjust z hight with my IR probe I have raised and lowered over 5mm what worked before is no longer working it doesn't seem to change it is over 2mm of the build pate now
                        have tried
                        G31 P500 X0 Y0 Z-5.9
                        all the way to
                        G31 P500 X0 Y0 Z5.9
                        with no change in the hight I have read the notes on the new version but not seeing it am I missing something?
                        as I mentioned this used to work flawlessly and now I cant use my probe please advise.
                          Is there a G31 command in config-override.g that is overriding the one in config.g? Prior to version 1.20, M500 used to save the G31 settings; now it does so only if you provide an extra parameter.
                            zerspaner_gerd
                            @dc42:
                            3. Yes, stop.g.
                            1. I have version "Duet2 V1.03" that means I would not need these files at all?
                            2. Sorry, meant "print area" which was defined with M208.
                            3. "Stop.g" not with me executed automatically at the end of the print, like "start.g" at the beginning of the print.
                              1. So you need the files listed for the Duet WiFi or Duet Ethernet (whichever board you have).
                              2. Yes, movement limits are applied during simulation. So G0/G1 moves that would go to outside the bed are modified to remain inside the bed, and G2/G3 moves that would go outside the bed cause the simulation to be aborted.
                              3. stop.g is only executed if your end gcode finishes with command M0.
                              • rpolteraundefined
                                rpoltera
                                no g31 in the config-override.g I added the config-override.g I also checked to make sure there was not a second g31 somehow
                                ; Heater model parameters
                                M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                M307 H1 A272.0 C158.9 D3.3 S1.00 V23.7 B0
                                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                  zerspaner_gerd
                                  @dc42:
                                  1. Have DuetWifi.
                                    So I only need these files:
                                    [c]DuetWiFiFirmware.bin or Duet2CombinedFirmware.bin (which are the same file), DuetWiFiServer.bin and iap4e.bin[/c]
                                    I do not need these:
                                    [c]RepRapFirmware.bin and iap.bin[/c]
                                  2. There is no message if G0/G1 is outside the print area?
                                    So it does not come to a collision but my part is dan for the trash can, Mhh????
                                    1. Correct.
                                    2. In FDM printer mode, that is correct. The reason is that it is quite common for a skirt to exceed the bounds of the bed. In laser and CNC mode the print will be terminated. If you want this changes, please suggest what you would like instead in the Firmware Wishlist section.
                                    • rpolteraundefined
                                      rpoltera
                                      I figured out my issue with the IR probe well got it working anyways must have been a bad update I guess formatted my sd card and added all my files back, and now it is working correctly.
                                      • alclonkyundefined
                                        alclonky
                                        i tried to adjust my homing files for my Cartesian Printer
                                        Homing X and Y works again, but home z just moves the 5 up and then stops with
                                        G28 Z
                                        myhomez.g:
                                        G91
                                        G1 Z5 F6000 S2
                                        ; Back to absolute positioning
                                        G90
                                        ; Go to first bed probe point and home the Z axis
                                        G1 X0 Y0 F6000
                                        G30
                                          Read the upgrade notes for firmware 1.21.
                                          • alclonkyundefined
                                            alclonky
                                            I did, otherwise i couldn't home X and Y
                                            or did I miss something else?
