    Probe Help
    1.8k
    • gorf26undefined
      gorf26
      I have a bltouch
      m307 H7 have it set to heater 7 in config
      internal +5 jumper set
      if i do a m307 h7 says heater disabled i don.'t have a config-override file yet so its not that
      if i do a m307 h3 it looks like its enabled but i am not on that heater 3 i am on heater 7
      checked wiring over and over look good
      I can issues all the commands deploy retract test mode and release form error all work
      but with heater 7 disabled it will not stop when probe hit but it's set in the config
      Any suggestions
      Thanks gary
        Can you post the rest of your config.g?
        • gorf26undefined
          gorf26
          I can will do tomorrow i have it working went back to heater 3
          I do find that with the bltouch it's doesn't seem totally reliable mostly the first run sometimes the probe needs to be
          triggered a couple times before it will probe correctly seems like it's not being read by the software or not sending
          the signal, i did do 3 g30's and got readings from 1.173 1.179 1.184 as for the probe height i don't have a resistor but my bltouch
          has the trace that i cut so i assume you don't need the resistor just doesn't seem as reliable as when i was using smoothieware
          or i'm doing something wrong also set the probe speed way down.
          Gary
            Several users have commented that their bltouch doesn't give very consistent readings. The following features in firmware 1.21 may help:
            • the multi-touch facility (A and S parameters in the M558 command)
            • disabling heaters during probing (B parameter in the M558 command)
            If your bltouch gives less consistent readings than it did before, perhaps you are probing at too high a speed, or the pin no longer slides smoothly in the sleeve.
            • gorf26undefined
              gorf26
              does A work with g30 s1 i set it to 2 and only hit once
              I set b to 1 P to 9 haven't figured out S yet
              I ran g30 9 times and i got back
              1 - 1.204
              2 - 1.214
              3 - 1.209
              4 - 1.199
              5 - 1.189
              6 - 1.189
              7 - 1.199
              8 - 1.199
              9 - 1.189
              looks like it settled down a bit after 3 or 4 hits
              should i set the A to 4 or 5?
              would this be considered close enough or should i look for a different probe?.
              Thanks gary
                G30 by itself sets the current Z height when the probe triggers. To test reproducibility, use G30 S-1.
                • gorf26undefined
                  gorf26
                  That is what i was using sorry i put G30 S1 in my last post
                  Gary
                    Looks like either the bltouch or your mechanics takes a few attempts to settle. Based on those figures, using A5 with S about 0.005 might help, but it would be better to fix the underlying problem.
                    • gorf26undefined
                      gorf26
                      Found another problem i moved the axis x0 y-100 z10 and i was going to do a G30 S-1 there
                      Now i homed from that position and the x and y towers homed and hit the end stops but the z tower stopped about 30 or 40 mm short and then
                      I got the error message G0/G1: insufficient axes homed
                      it homes ok as long as i am in the bed center but not from outside.
                      Also if i enter x0 y-122 z10 it seems to only go to y-85 that's what the web control shows
                      this is my m666 have it set to 100 should make at least 100 i assume or does that need to be a high number
                      M665 R122 L288 B100 H315 ; Set delta radius, diagonal rod length, printable radius and homed height
                      Gary
                        See the FAQ in the wiki for that problem.
                        • gorf26undefined
                          gorf26
                          Got that figured out thanks
                          But now have a major problem I'm stuck on
                          I have been doing a manual config of the center and the a b c tower corners
                          my heights are so far off i am getting lost checked the stops and there the same height and the frame is level square
                          I just had smoothieware on the same machine and calibrated good. and haven't touched anything to make it way off,
                          My center is at Z0 good but the a b c corners are way off i am getting at build plate x A = 15.30 y B = 15.20 z C = 14.70
                          So the corners need to be about 15mm less so if the corners are brought down then the center will be about 15mm off
                          and at zero will crash the plate.. I'm sure its something simple in the settings i'm missing.
                          any suggestions
                          Thanks gary
                            Why are you doing a manual calibration when the firmware has a much faster least squares auto calibration algorithm built in? See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer. You can use it without a Z probe if you use P0 in your M558 command.
