    BL Touch probe input not working
    3.9k
      If you set the probe into test mode and touch the probe what does the DWC show?
      • mhackneyundefined
        mhackney
        the macros do only have the servo commands but are they no longer needed with 1.21 or should I leave them.
        My 3D Printing blog: http://www.sublimelayers.com
        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        • mhackneyundefined
          mhackney
          P120 test mode? if so, it stays at 1000 while the probe extends and retracts until cleared.
            @mhackney:
            They still need to be there, you just don't have to call them in other macros now, you can just use M401 and M402.
            • mhackneyundefined
              mhackney
              Hmm, I have this for endstops: M574 X1 Y1 Z0 S1
                @mhackney:
                But does it change when you touch the pin to simulate a trigger?
                  @mhackney:
                  Take out the Z0 and add another command to specify the Z
                  like so
                  [c]M574 X1 Y2 S0 ; Set active-low switches, low end endstop for X, high end endstop for Y, add Z2 for Zmax
                  M574 Z1 S2 ; Use zprobe and home to min[/c]
                    The Z-probe status in the DWC isn't very helpful with the BLTouch. It triggers and releases so fast it's hard to see it flash.
                    But as long as it actually stops the bed from traveling it'll work just fine.
                    • mhackneyundefined
                      mhackney
                      I'm kind of stuck between a rock and a hard place. I can't test probing until I home and homing will kill my pristine new PEI if it fails on Z.
                      • mhackneyundefined
                        mhackney
                        Ok, I homed X and Y individually and then attempted to home Z. I saw the probe descend and then retract with thisL
                        G28 Z
                        Error: Z probe already triggered at start of probing move
                        Error: G0/G1: insufficient axes homed
                          @mhackney:
                          Test it from a few 100mm height and trigger it by hand before it gets close to the bed.
                          • mhackneyundefined
                            mhackney
                            I notice you don't have inverted signal in your M558. Wiki says to invert.
                              What does your HomeZ.g look like?
                              • mhackneyundefined
                                mhackney
                                Ok, it is working. Removed the invert on M558 and actually tested rather than watch the DWC display. A finger push triggers the probe, Z stops moving. Should be good to go from here, thank you!
                                  @mhackney:
                                  Technically it only talks about inverting. The example of the M558 command doesn't have it. The inversion they talk about refers to the servo command only. Though that's not made clear or explicit in the wiki. I ran into that at first too.
                                  • mhackneyundefined
                                    mhackney
                                    home.g
                                    G91
                                    G1 Z5 F800 S2
                                    M401
                                    G90
                                    G1 X120 Y125 F2400
                                    G30
                                    M402
                                    G1 Z2 F200
                                      Your M558 command should look something like this to get decent repeatability out of the BLTouch.
                                      [c]M558 P9 X0 Y0 Z1 H5 F100 T4000 A10 R0.5 S0.008 ; P9 for BLTouch, dive height 5mm, probe at 100mm/s, travel 4000mm/s, probe until 2 consecutive probe results are to within S up to 10 probes, pause 0.5s, Reprobe until 0.008 repeatability[/c]
                                      Here's what I'm using for HomeZ on my CoreXY.
                                      [c]
                                      ; homez.g
                                      ; called to home the Z axis
                                      ; BLTouch prep so we don't catch the probe pin on the edge of the bed
                                      M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                                      G4 S1
                                      M402 ; Retract probe just in case it's down
                                      G4 S0.5
                                      ; Drop the bed for travel
                                      G91 ; Relative positioning
                                      G1 Z5 F200 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
                                      ; Move probe into position
                                      G90 ; absolute positioning
                                      G1 X200 Y140 F4000 ; Move x and Y axis over to bed center so probe is on top of bed
                                      ; Set lower speeds for homing
                                      M566 Z10 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                                      M203 Z400 ; Set maximum speeds (mm/min)
                                      M201 Z100 ; Set maximum accelerations (mm/s^2)
                                      ; Probe the bed
                                      M558 A1 F400 ; Set single probing at faster feed rate
                                      G30 ; Do a single probe to home our Z axis
                                      M558 A10 F100 ; Set more accurate probing at slower feed rate
                                      G30 ; Probe again to get a more accurate position
                                      ; Set normal speeds again
                                      M566 Z15 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                                      M203 Z500 ; Set maximum speeds (mm/min)
                                      M201 Z300 ; Set maximum accelerations (mm/s^2)
                                      ; Move X and Y back Home
                                      G1 X0 Y285[/c]
                                      I also use this as a macro to calibrate the probe trigger height
                                      [c]; Clear compensation map and Zprobe trigger height
                                      M291 P"Grid bed compensation map and ZProbe trigger height will be cleared. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                                      M561 ; Disable any current bed compensation
                                      G29 S2 ; Clear mesh bed compensation perameters
                                      G31 Z0 ; Reset zprobe trigger height
                                      ; home all axis
                                      G28 ; Home all axis
                                      G90 ; Absolute positioning
                                      T0 ; Activate first tool
                                      ; Set lower speeds for Z homing and lower Z motor current
                                      M906 Z900 ; Drop motor current to prevent damage in case of head crash
                                      ; Preheat to probing temps
                                      M291 P"Preheating to bed to 60 and nozzle to 210 for accurate probing"
                                      M104 S210 ; Set nozzle to 210 and release
                                      M190 S60 ; Set bed to 60 and wait
                                      M109 S210 ; Set nozzle to 210 and wait
                                      ; Move nozzle to center of bed at z10
                                      M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3
                                      G1 Z1 ; Drop bed for nozzle clearance
                                      G1 X155 Y140 Z2 F4000 ; Move to bed center
                                      ; Reset z to 5 to allow jogging up to touch bed to nozzle
                                      G92 Z5
                                      ; Dialog to allow user to jog z to touch nozzle to bed gently and then move Z down 10
                                      M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
                                      G92 Z0 ; Set z = 0
                                      ; Move probe to center of bed and get probe trigger heights
                                      M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" S3
                                      G1 X200 Y140 F4000 ; Move to bed center
                                      M291 P"Heights will be found in gcode console if logging successful gcode is enabled" R"Did you remember to enabled gcode logging?" S3
                                      ; G30 S-1 10 times
                                      ; 1
                                      G1 Z10
                                      G30 S-1
                                      ; 2
                                      G1 Z10
                                      G30 S-1
                                      ; 3
                                      G1 Z10
                                      G30 S-1
                                      ; 4
                                      G1 Z10
                                      G30 S-1
                                      ; 5
                                      G1 Z10
                                      G30 S-1
                                      ; 6
                                      G1 Z10
                                      G30 S-1
                                      ; 7
                                      G1 Z10
                                      G30 S-1
                                      ; 8
                                      G1 Z10
                                      G30 S-1
                                      ; 9
                                      G1 Z10
                                      G30 S-1
                                      ; 10
                                      G1 Z10
                                      G30 S-1
                                      M291 P"Probing complete. Turning off heaters and homing axis. Check log for trigger heights and enter into config.g" S2
                                      ; Turn off heaters
                                      M104 S0 ; Set nozzle to 0 and release
                                      M140 S0 ; Set bed to 0 and release
                                      M906 Z1500 ; Return Z motor current to normal
                                      G28 ; Home all
                                      ; Tone to get user attention
                                      M400 ; Clear movement buffer so tones play reliably
                                      M300 S666 P500
                                      G4 P501
                                      M300 S1111 P300
                                      G4 P301[/c]
                                      • mhackneyundefined
                                        mhackney
                                        Ok, probing working and Z offset calibrated.
                                        I'm a delta guy and this is my first Core XY and first BL Touch. I use FSRs on my 7 deltas and IR on a couple of other printers.
                                        The whole "homing" thing is more complicated on the Core XY. I'll look over your home.g - thanks.
                                          I'm pretty new to CoreXY as well coming from cartesian. I just finished commisioning, that's why it's all fresh.
                                          Here's my home all and Home X and Y for completeness.
                                          [c]
                                          ; homeall.g
                                          ; called to home all axes
                                          G4 S1
                                          G4 S0.5
                                          ; Home XY for Z homing
                                          G91 ; relative positioning
                                          M913 X50 Y50 ; set X Y motors to 50% of their normal current for homing
                                          G1 S1 X-375 Y305 F4000 ; course home X or Y
                                          G1 S1 X-375 F4000 ; course home X
                                          G1 S1 Y305 F4000 ; course home Y
                                          G1 X2 Y-2 F1000 ; move away from the endstops
                                          G1 S1 X-10 F200 ; fine home X
                                          G1 S1 Y10 F200 ; fine home Y
                                          M913 X100 Y100 ; set X Y motors to 100% of their normal current
                                          ; Z homing section follows
                                          ; Probe the bed
                                          M558 A5 F100 ; Set tripple probing at slower feed rate
                                          G1 X0 Y285[/c]
                                          [c]; homex.g
                                          ; called to home the X axis
                                          M913 X50 ; set X motors to 50% of their normal current for homing
                                          G1 S1 X-375 F4000 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X2 F1000 ; go back a few mm
                                          G1 S1 X-10 F200 ; move slowly to X axis endstop once more (second pass)
                                          M913 X100 ; set X motors to 100% of their normal current for homing[/c]
                                          [c]; homey.g
                                          ; called to home the Y axis
                                          M913 Y50 ; set Y motors to 50% of their normal current for homing
                                          G1 S1 Y305 F4000 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 Y-2 F1000 ; go back a few mm
                                          G1 S1 Y10 F200 ; move slowly to Y axis endstop once more (second pass)
                                          M913 Y100 ; set Y motors to 100% of their normal current for homing[/c]
                                          • mhackneyundefined
                                            mhackney
                                            Great thanks. I updated my homez. makes sense. I'll do the update to all, x and y too.
