    BL Touch probe input not working
    4.0k
      @mhackney:
      I'm kind of stuck between a rock and a hard place. I can't test probing until I home and homing will kill my pristine new PEI if it fails on Z.
      Test it from a few 100mm height and trigger it by hand before it gets close to the bed.
      • mhackneyundefined
        mhackney
        I notice you don't have inverted signal in your M558. Wiki says to invert.
        My 3D Printing blog: http://www.sublimelayers.com
        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
          What does your HomeZ.g look like?
          • mhackneyundefined
            mhackney
            Ok, it is working. Removed the invert on M558 and actually tested rather than watch the DWC display. A finger push triggers the probe, Z stops moving. Should be good to go from here, thank you!
              @mhackney:
              Technically it only talks about inverting. The example of the M558 command doesn't have it. The inversion they talk about refers to the servo command only. Though that's not made clear or explicit in the wiki. I ran into that at first too.
              • mhackneyundefined
                mhackney
                home.g
                G91
                G1 Z5 F800 S2
                M401
                G90
                G1 X120 Y125 F2400
                G30
                M402
                G1 Z2 F200
                  Your M558 command should look something like this to get decent repeatability out of the BLTouch.
                  [c]M558 P9 X0 Y0 Z1 H5 F100 T4000 A10 R0.5 S0.008 ; P9 for BLTouch, dive height 5mm, probe at 100mm/s, travel 4000mm/s, probe until 2 consecutive probe results are to within S up to 10 probes, pause 0.5s, Reprobe until 0.008 repeatability[/c]
                  Here's what I'm using for HomeZ on my CoreXY.
                  [c]
                  ; homez.g
                  ; called to home the Z axis
                  ; BLTouch prep so we don't catch the probe pin on the edge of the bed
                  M280 P3 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                  G4 S1
                  M402 ; Retract probe just in case it's down
                  G4 S0.5
                  ; Drop the bed for travel
                  G91 ; Relative positioning
                  G1 Z5 F200 S2 ; Lower bed 5mm to ensure it is below the switch trigger height
                  ; Move probe into position
                  G90 ; absolute positioning
                  G1 X200 Y140 F4000 ; Move x and Y axis over to bed center so probe is on top of bed
                  ; Set lower speeds for homing
                  M566 Z10 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                  M203 Z400 ; Set maximum speeds (mm/min)
                  M201 Z100 ; Set maximum accelerations (mm/s^2)
                  ; Probe the bed
                  M558 A1 F400 ; Set single probing at faster feed rate
                  G30 ; Do a single probe to home our Z axis
                  M558 A10 F100 ; Set more accurate probing at slower feed rate
                  G30 ; Probe again to get a more accurate position
                  ; Set normal speeds again
                  M566 Z15 ; Set maximum instantaneous speed changes (mm/min) (Jerk)
                  M203 Z500 ; Set maximum speeds (mm/min)
                  M201 Z300 ; Set maximum accelerations (mm/s^2)
                  ; Move X and Y back Home
                  G1 X0 Y285[/c]
                  I also use this as a macro to calibrate the probe trigger height
                  [c]; Clear compensation map and Zprobe trigger height
                  M291 P"Grid bed compensation map and ZProbe trigger height will be cleared. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                  M561 ; Disable any current bed compensation
                  G29 S2 ; Clear mesh bed compensation perameters
                  G31 Z0 ; Reset zprobe trigger height
                  ; home all axis
                  G28 ; Home all axis
                  G90 ; Absolute positioning
                  T0 ; Activate first tool
                  ; Set lower speeds for Z homing and lower Z motor current
                  M906 Z900 ; Drop motor current to prevent damage in case of head crash
                  ; Preheat to probing temps
                  M291 P"Preheating to bed to 60 and nozzle to 210 for accurate probing"
                  M104 S210 ; Set nozzle to 210 and release
                  M190 S60 ; Set bed to 60 and wait
                  M109 S210 ; Set nozzle to 210 and wait
                  ; Move nozzle to center of bed at z10
                  M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3
                  G1 Z1 ; Drop bed for nozzle clearance
                  G1 X155 Y140 Z2 F4000 ; Move to bed center
                  ; Reset z to 5 to allow jogging up to touch bed to nozzle
                  G92 Z5
                  ; Dialog to allow user to jog z to touch nozzle to bed gently and then move Z down 10
                  M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
                  G92 Z0 ; Set z = 0
                  ; Move probe to center of bed and get probe trigger heights
                  M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" S3
                  G1 X200 Y140 F4000 ; Move to bed center
                  M291 P"Heights will be found in gcode console if logging successful gcode is enabled" R"Did you remember to enabled gcode logging?" S3
                  ; G30 S-1 10 times
                  ; 1
                  G1 Z10
                  G30 S-1
                  ; 2
                  G1 Z10
                  G30 S-1
                  ; 3
                  G1 Z10
                  G30 S-1
                  ; 4
                  G1 Z10
                  G30 S-1
                  ; 5
                  G1 Z10
                  G30 S-1
                  ; 6
                  G1 Z10
                  G30 S-1
                  ; 7
                  G1 Z10
                  G30 S-1
                  ; 8
                  G1 Z10
                  G30 S-1
                  ; 9
                  G1 Z10
                  G30 S-1
                  ; 10
                  G1 Z10
                  G30 S-1
                  M291 P"Probing complete. Turning off heaters and homing axis. Check log for trigger heights and enter into config.g" S2
                  ; Turn off heaters
                  M104 S0 ; Set nozzle to 0 and release
                  M140 S0 ; Set bed to 0 and release
                  M906 Z1500 ; Return Z motor current to normal
                  G28 ; Home all
                  ; Tone to get user attention
                  M400 ; Clear movement buffer so tones play reliably
                  M300 S666 P500
                  G4 P501
                  M300 S1111 P300
                  G4 P301[/c]
                  • mhackneyundefined
                    mhackney
                    Ok, probing working and Z offset calibrated.
                    I'm a delta guy and this is my first Core XY and first BL Touch. I use FSRs on my 7 deltas and IR on a couple of other printers.
                    The whole "homing" thing is more complicated on the Core XY. I'll look over your home.g - thanks.
                      I'm pretty new to CoreXY as well coming from cartesian. I just finished commisioning, that's why it's all fresh.
                      Here's my home all and Home X and Y for completeness.
                      [c]
                      ; homeall.g
                      ; called to home all axes
                      G4 S1
                      G4 S0.5
                      ; Home XY for Z homing
                      G91 ; relative positioning
                      M913 X50 Y50 ; set X Y motors to 50% of their normal current for homing
                      G1 S1 X-375 Y305 F4000 ; course home X or Y
                      G1 S1 X-375 F4000 ; course home X
                      G1 S1 Y305 F4000 ; course home Y
                      G1 X2 Y-2 F1000 ; move away from the endstops
                      G1 S1 X-10 F200 ; fine home X
                      G1 S1 Y10 F200 ; fine home Y
                      M913 X100 Y100 ; set X Y motors to 100% of their normal current
                      ; Z homing section follows
                      ; Probe the bed
                      M558 A5 F100 ; Set tripple probing at slower feed rate
                      G1 X0 Y285[/c]
                      [c]; homex.g
                      ; called to home the X axis
                      M913 X50 ; set X motors to 50% of their normal current for homing
                      G1 S1 X-375 F4000 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X2 F1000 ; go back a few mm
                      G1 S1 X-10 F200 ; move slowly to X axis endstop once more (second pass)
                      M913 X100 ; set X motors to 100% of their normal current for homing[/c]
                      [c]; homey.g
                      ; called to home the Y axis
                      M913 Y50 ; set Y motors to 50% of their normal current for homing
                      G1 S1 Y305 F4000 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 Y-2 F1000 ; go back a few mm
                      G1 S1 Y10 F200 ; move slowly to Y axis endstop once more (second pass)
                      M913 Y100 ; set Y motors to 100% of their normal current for homing[/c]
                      • mhackneyundefined
                        mhackney
                        Great thanks. I updated my homez. makes sense. I'll do the update to all, x and y too.
                        • mhackneyundefined
                          mhackney
                          Ok, mesh grid compensation run complete with inexplicable results:
                          In 100s of probes on deltas I've never seen anything like this. How is this possible or what is the issue?
                          My z offset is dialed in pretty nicely. I tested it in 9 spots on the bed. But the mesh grid is completely off.
                            What does your M558, M557 and G31 command look like in config.g?
                            What did you get for your probe height and how did you calibrate it?
                              Michael, please post your homeall.g, homez.g and config.g files. If you are using either bed.g or a macro to do mesh probing instead of just G29, post that macro too.
                              • gen2engundefined
                                gen2eng
                                I'm in the process of commissioning a new corexy using 1.21 and I'm getting the grid compensation results with a large shift in the z height also. I assumed it would have found some average zero itself.
                                I've corrected the offset using a single probe in the center of the bed prior to grid compensation.
                                [[language]]
                                M561 		; clear any bed transform
                                G1 X200 Y200	; Move to center of the bed
                                G30		; Simple probe of the bed to set z=0
                                G29		; Detailed probe of the bed
                                  One cause of a large offset is that you are homing Z using an endstop switch, and the endstop position assumed when the switch is triggered is not accurate.
                                  If the switch is a Z Max switch, the M208 S0 Z parameter should be set to the height at which it triggers. If the switch is a Z Min switch, use a G92 Znnn command in homez.g and homeall.g to define that position.
