Delta bl touch auto leveling
delta bl touch auto leveling little monster
2.0k
    Tasos
    Hello i bought duet ethernet as an upgrade for TLM ,the wiring and the first calibration of the machine was easy to complete and everything went fine.
    The problem is with bl touch and the auto-leveling ,i follow these instructions,https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe,https://betrue3d.dk/bltouch-on-duet-wifi-duetreprapfirmware/.
    So the when the machine powers up bl touch is self tests and everything is ok ,even when i manually touch the bl touch it triggers.
    But when i hit the delta auto leveling in DWC the efector goes to the trigger height (set it in config.g) the bl touch pin goes down,but doesn't probe the center waits some ms and the moves to the first tower and suddenly the DWC shows the manaul bed leveling in which i have to move down the z axis until the bl touch triggers and if do that the bl touch after the first trigger goes to error mode (RED led blinks) and even if move to the next point the bl touch doesnt respond 0_1523357488108_bed.g 0_1523357491506_config.g 0_1523357494231_homedelta.g
      Check that you have the correct parameters in your M558 command. You should have P9 for bltouch if you are using version 1.21 firmware, or P5 for older firmware.
      undefined 1 Reply Last reply 10 Apr 2018, 13:51 Reply Quote 0
        Tasos @dc42
        @dc42 yes all tests that i ve tried is with P9 and with P5 but the results are what i have described above
          Is there an error message in the GCode Console page of Duet Web Control after you run G29? There should be one, if the G29 command quit early.
          undefined 1 Reply Last reply 11 Apr 2018, 07:05 Reply Quote 0
            Tasos @dc42
            @dc42 No i tested again the same story, nothing shows up in the console.
            I think the problem is somewhere else , my thought is why it shows me inDWC the manual bed leveling . It supposed to do itself right?.
            undefined 1 Reply Last reply 11 Apr 2018, 12:07 Reply Quote 0
              dc42 administrators @Tasos
              @tasos said in Delta bl touch auto leveling:
              If it pops up the manual bed levelling prompt, then either the M558 command is not being recognised, or the probe type in it is not supported e.g. you have specified probe type 9 but you are not using version 1.21 firmware.
                Tasos
                OK i change the P9 to P5 and also Z2 to Z1 and now works
                i run mesh and i got this
                Number of probe points: 109
                Probe area: 452.4 cm²
                Maximum deviations: -0.633 / 0.027 mm
                Mean error: -0.273 mm
                RMS error: 0.161 mm
                I m not sure if this is right
                6 out of 7
