Wifi ...disalbled Kinematics ...
The newline characters in those messages are missing. There are actually 2 messages there:
- "WiFi is disabled" means that in config.g you have a M552 command without an S parameter to change the WiFi state, so it is reporting the existing state
- the kinematics message means you have an incomplete M667 or M669 command in config.g
Hi David
FOR M552 I have only
M552 S1 ;start wifi
For M667 I have only I have no M669 command
M667 S1 ; set CoreXY mode
M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
M569 P3 S1 ; Drive 3 goes forwardshere are two different errors
and
sometimes after I make a modificartion when it restart I see this but can not connect, when I restart the printer i can connect again.
I'm using:
Firmware Version: 1.21RC5 (2018-03-16 build 1)
WiFi Server Version: 1.21RC5(16b1)
Web Interface Version: 1.21-RC4thanks
steve -
@synapsis said in Wifi ...disalbled Kinematics ...:
M667
so part of the problem is you have
M552
M552 S1 ;start wifiget rid of that first M552.
Not sure what is going on here
M567 / M569
See correction above.
I have also tried with the a new file from the RFF configuration tool
same errors, Installed aldo the beta 2 but still the same problem. -
is there a reason why you are using 1.21RC firmware instead of 1.21 release?
That was the last one I had installed when it came out, but it was working.
OK installed :
Firmware Version: 1.21 (2018-03-21)
Web Interface Version: 1.21-RC4but still the same problem ...
This all start when one day I turned on and it did not connect
I had to use YAT and found that there was bo config,g file anymore.
after I copied the file from my pc it has been giving me problems.
As to why the file disappeared I have no idea as I had not made any changes in them at taht time. -
M667
Kinematics is CoreXY with axis factors X:1.000 Y:1.000 Z:1.000=== Diagnostics ===
Used output buffers: 3 of 32 (8 max)
RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
Board ID: 08DGM-95BNL-MGPSN-6J9F6-3S46Q-TJWVW
Static ram used: 16152
Dynamic ram used: 100448
Recycled dynamic ram: 2184
Stack ram used: 1224 current, 4512 maximum
Never used ram: 7776
Last reset 00:05:43 ago, cause: power up
Last software reset at 2018-04-13 22:45, reason: User, spinning module GCodes, available RAM 7840 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 25.0, current 32.6, max 32.7
Supply voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0
Date/time: 2018-04-13 23:04:57
Slowest main loop (seconds): 0.014025; fastest: 0.000046
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 2c:3a:e8:0b:08:49
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 17192
WiFi IP address 192.168.0.6
WiFi signal strength -50dBm, reconnections 0, sleep mode modem
Socket states: 2 0 0 0 0 0 0 0
- WiFi -
Ok if i comment the M667 S1 I do not get that message when it starts.
So is that a normal message I do not remmeber seeing it before but to be honest never really looked at the console on start up. -
So do I have to keep this error? To I have to change board as its a hardware problem?
I think there may be a minor bug that is causing M667 to report the kinematics type when it wasn't intended to. I will check it tomorrow.
Thanks David
