    Yet Another Wifi Connection Problem
    2.6k
    • Yonkimanundefined
      Yonkiman
      I have 2 Duets in 2 printers, and for as long as I can remember (since 1.17) the Duets will randomly disconnect (while printing or idle). If I then probe through Pronterface an M522 says the wifi is idle. The only way I can reconnect is to reset them or hook up the USB interface and send a [c]M552 S1[/c].
      Since it's happening on 2 Duets, through a year of firmware updates, and I don't see other people that are having this problem, I'm sure there is something abnormal about my system/network. That said, the dozens of other wifi connections the family uses around the house don't have this problem - they either stay connected or they reconnect after connection is lost. So it's probably some interaction between my environment and the Duet system. I'm hoping to get some help, so here's the checklist:
      Make sure you are running the latest stable versions of the main firmware
      I'm using the latest 1.21RC5 for firmware and wifiserver. Web interface is 1.21-RC4.
      If an AJAX Error is reported
      No Ajax error is reported. I get a popup that says [c]The last HTTP request has timed out. Please make sure the connection between your device and the board is not interrupted.[/c] After that, when I try to reconnect I get [c]Could not establish a connection to the Duet firmware! Please check your settings and try again.[/c] When I try to ping the address of the Duet there's no response.
      Run M122 from either the web interface (if you can reconnect) or from USB. In the Network diagnostics, check the WiFi signal strength, also called RSSI. Values in the range -30 to -50 are good, -50 to -60 is OK, -60 to -70 is marginal. Anything below -70 is weak and likely be unreliable. See below for how to improve RSSI.
      Also in the M122 Network diagnostics check the WiFi Module Reset Reason. It should be "turned on by main processor". If it is anything else (e.g. "exception"), report the problem on the forum.
      I don't get a signal strength when I run M122. Probably because it reports [c]WiFi module is idle.[/c] Here's the full network section:
      === Network ===
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi module is idle
      WiFi firmware version 1.21RC5(16b1)
      WiFi MAC address 60:01:94:0c:55:75
      WiFi Vcc 3.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 18440
      In Duet Web Control, on the Settings/General tab check that "Maximum number of AJAX retries" is at least 3.
      It is set to 3. Is this the problem? If it doesn't reconnect after 3 tries the wifi goes into an idle, unconnectable state?
      Are the disconnections related to another device that uses the 2.4GHz band? Typical devices that may cause problems include cordless telephones, baby monitors, and leaky microwave ovens.
      I don't think so. I dedicated a TP-Link router for the Duets, because I'm in my garage, far from the house's main hotspot. The router is about 1.5 meters from the Duet. Signal strength is -48dBm when the wifi is working.
      Try changing the channel on your WiFi router. Most routers default to Auto, but can be set to use a fixed channel instead. The channels overlap, so it is common to use channel 1, 6 or 11. This may also help if another device is causing interference. We have some feedback that channel 6 gives better results than channel 1.
      It's currently set to 6. Just changed it to 1 and still can't (re)connect.
      Is the connection stable when the printer is idle, but unreliable when printing? If so then there may be too few CPU cycles to service the network interface, because of an excessive step pulse rate. Check the M122 report after a disconnection during a print, or after completing the print, and look at the MaxReps figure in the Move diagnostics. This value should be kept below about 50. If it is higher, reduce either microstepping (M350) or maximum speed (M203). Please note, MaxReps is reset when you run M122 so only the value the first time you run M122 after a disconnection or completion of a print is significant.
      Max reps was 4. It's currently printing a long job at 50mm/s on a Cartesian printer so the CPU shouldn't be heavily taxed.
      Also if the connection is stable when the printer is idle but not when printing: could it be temperature-related? Does the disconnection occur when the CPU temperature displayed in DWC reaches a certain value? If so, try cooling the Duet with a fan, if you are not doing so already.
      Connection can be lost when idle or printing. Sometimes it will print for 12+ hours without disconnecting. In this case it disconnected a few hours into the print. Duet is cooled, and MCU temperature is min 21.4, current 22.6, max 30.3.
      Any ideas what could be causing the wifi to just turn itself off?
      • Yonkimanundefined
        Yonkiman
        This is the first time I've had USB hooked up when it failed. For some reason I can't restart it with M552 S1. Here's what I tried:
        WiFi reported error: Lost connection, auto reconnecting
        WiFi reported error: Timed out while trying to connect to Garage AP
        >>>  M552 S1
        SENDING:M552 S1
        >>>  M552
        SENDING:M552
        WiFi module is changing mode
        >>>  M552
        SENDING:M552
        >>>  M552 S0
        SENDING:M552 S0
        >>>  M552 S1
        SENDING:M552 S1
        >>>  M552
        SENDING:M552
        >>>  M552
        SENDING:M552
          Next time try sending M552 S-1 first. That resets the WiFi module.
          The forthcoming 1.21 release includes a fix for a known issue that can cause reconnection to fail.
          • Yonkimanundefined
            Yonkiman
            That did it, thanks.
            • SputnikOC3dundefined
              SputnikOC3d
              Ok so my wifi module light on my board has gone dark in the middle of an overnite print … it will be printing now for another few hrs. on fw released last week 1.21 - no PanelDue.
              What to do to reconnect whilst mid print ?
                You can probably reconnect by sending M552 S1 from USB. As you have a print running, to minimise the chance of disruption I suggest you use a laptop running off its battery to connect via USB if possible, to avoid getting a USB ground loop.
                • lolorcundefined
                  lolorc
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01
                  "WiFi module is changing mode"
                  Debugging enabled for modules: Network(1) WiFi(14)
                  I'm also getting this issue.
                  M552 S0/S1 doesn't change its status.
                    dc42 administrators @lolorc
                    @lolorc said in Yet Another Wifi Connection Problem:
                    Please try re-installing DuetWiFiServer.bin version 1.21. To do that, move the SD card to a PC, copy that version of DuetWiFiServer.bin into the /sys folder, also edit the config.g file to comment out the M552 S1 command. Safely remove/eject the SD card, put it back in the Duet, start the Duet, then send M997 S1 to install the WiFi firmware. If that completes successfully, you can then try sending M552 S1 again.
                    • lolorcundefined
                      lolorc
                      I will do, in the mean time it looks like there some network issues. Some network trace reveals a huge amounts of tcp duplicates.
                      It takes 45min to upload a 3MB gcode file...
                      I'm going to investigate this first. I know I already had issues with some old cisco access point, it might be related as well.
