    RepRapFirmware 2.0beta1 available
    Firmware installation
    firmware vrtos
    13
    58
    9.2k
      Tim, I can confirm that in 2.0beta1 when a G0 command follows a G1 command with extrusion, the G0 command repeats the extrusion. I have fixed it and I will release a new beta tonight or tomorrow.
      timcurtis67undefined 1 Reply Last reply Reply Quote 1
      • timcurtis67undefined
        timcurtis67 @dc42
        @dc42 said in RepRapFirmware 2.0beta1 available:
        Great! I will watch for the update and try it out asap. Not sure where you get the time to keep up with these updates but I thank you sincerely.
          Firmware 2.0beta2 is now released at https://github.com/dc42/RepRapFirmware/tree/v2-dev/EdgeRelease.
            timcurtis67
            I'll try it out tonight. Thanks again.
            • hurzhurzundefined
              hurzhurz
              I did a quick test with my file where I noticed the G0 problem.
              I had stopped the print after a few layers, but it looked good so far, thanks!
              • whosrdaddyundefined
                whosrdaddy
                @dc42: any progress on the file upload problem in the latest beta?
                  dc42 administrators @whosrdaddy
                  @whosrdaddy, see the release notes.
                    whosrdaddy
                    Ah must buy some glasses, did read the notes and somehow looked over it 😉
                    Will test this tomorrow and report back.
                      whosrdaddy
                      @dc42: The file upload problem still stands in beta2, behavior is exact the same as shown in the video I posted earlier.
                      Firmware Version: 2.0(RTOS)beta2 (2018-04-19b1)
                      WiFi Server Version: 1.21
                      Web Interface Version: 1.21.1-b3
                        With 2.0alpha I always had a disconnection unless the file was tiny. With 2.0beta1 I had a disconnection only with uploading certain file sizes. With 2.0 beta2 I don't see any disconnection. What upload file sizes cause disconnections for you? Do you have more than one device running DWC?
                        whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                          whosrdaddy @dc42
                          @dc42 : only one dwc connection, tried a 2MB file and a 12MB file and both failed.
                          did some more testing and had success with a 1MB file.
                          Just to be clear, the file is correctly uploaded but DWC disconnects at the end.
                            timcurtis67
                            My Beta 2 disconnects when uploading larger files. Other than that it works perfect so far.
                            • carlossprundefined
                              carlosspr
                              I tried the Beta 2 today for two prints. Everything went fine. Then I wanted to go back to 1.21 and using DWC I hade to upload the Duet2CombinedFirmware.bit three times. The first two times I dod not receive the message to update the firmware. Once in 1.21 I changed some settings in config.g and on sage the DWC message detected a new firmware and asked again to update to 1.21. This can well be related to a "disconnect" after uploading a file although I did not notice on the DWC.
                                timcurtis67
                                @dc42 I can confirm that when uploading small files <1 meg it works fine. When uploading any larger files I get a disconnect.
                                I only ever run one device with DWC (Windows 7 Pro PC) and I only have 4 gcode files on my SD card.
                                Once I reconnect with DWC the prints run perfect.
                                  Those of you who are still experiencing disconnects immediately after uploading a file with beta 2: are you using WiFi or Ethernet Duets?
                                    whosrdaddy @dc42
                                    @dc42 : Wifi
                                    Firmware Electronics: Duet WiFi 1.02 or later + DueX5
                                      timcurtis67
                                      I'm using a Wifi board. The latest DWC, Duex5, and a 7" paneldue 2.0.
                                        carlosspr
                                        Also Wifi.
                                          Thanks all, it looks like the problem with disconnections after file uploads may be solved on the Duet Ethernet but not on the WiFi. I'll do some more testing.
                                          timcurtis67undefined 1 Reply Last reply Reply Quote 0
                                            timcurtis67 @dc42
                                            @dc42 Should I have my SD card formated a certain way? I never did anything with it when it arrived with my Duetwifi board. I just used it as is. My download speeds are usually very fast at over 600-700 mbits. This disconnect thing just has me wondering?
                                            dc42undefined 2 Replies Last reply Reply Quote 0
