    Nozzle dragging over print
    2.3k
    • Stealthy_TTundefined
      Stealthy_TT
      Hey all,
      So since I’ve been using Duet I cannot seem to get rid of the nozzle dragging across the layer it’s printing, it causes some stringing and I can hear the drag when the hotend is traveling.
      Any ideas on what I should be changing?
      Z steps are basically perfect, +100mm is within .07-.10mm. My first layer also lays down great
      Cura has the correct filament diameter also. My extruder is also calibrated to within.07-.10mm
      Heres a picture of my top layer, this is happening starting from like layer 4 and gets to this point. Don’t mind the blob, messed up on my end code in cura, nozzle dropped into the print haha
      ![alt text](0_1524297409228_1DF899F1-17DC-497E-8650-016F1CAC645F.jpeg image url)
      • burtoogleundefined
        burtoogle
        Make sure that the Cura combing setting is set to "No Skin". If you don't do that, it will allow travel moves to cross skin areas without retraction or z-hop. Can you please post your gcode so I can see if there's anything odd about it?
        peter247undefined 1 Reply Last reply Reply Quote 0
          Stealthy_TT
          Hey Burtoogle,
          Thanks for chiming in, I wasn't using combing but just turned it on.
          Are you wanting the actual file, or the whole gcode?
          Also printing another one now with a extrusion multiplier of 90, looks better. also scaled the overall size from 20x20x5 to 30x30x5
            Stealthy_TT
            Heres what this one looks like at 90% extrusion multiplier 0_1524300713481_7BF99C00-0101-4D37-803C-E466EDDBA2B7.jpeg
              burtoogle
              Sorry, what I meant was, don't use combing set to "All", either turn combing off or set it to "No Skin".
              Stealthy_TTundefined 1 Reply Last reply Reply Quote 0
                Stealthy_TT @burtoogle
                @burtoogle
                I set it to skin when i had it on. Now i turned it back off, and now for some reason every line it puts down its doing a retract. like every line other than outer walls
                  Stealthy_TT
                  Just loaded a older Gcode file i had, no issues with that one. i must have did something wrong here.
                  • peter247undefined
                    peter247 @burtoogle
                    @burtoogle said in Nozzle dragging over print:
                    I think that is a part of the puzzle I've been looking for ? , Cura don`t make it simple for you does it ?, I've been looking for some sort of lift while traveling command.
                    Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                      Stealthy_TT
                      So just an update. for some reason cura was giving me really crap prints. I downloaded Slic3r and configured it, and man my first print from it was pretty flawless. Seems like Slic3r slices better than Cura. The one thing I hated about cura was that it would travel to the next layer then lift z to start printing, Slic3r does the opposite and lifts head then moves.
                      Yeah I could use Z hop on Cura, but that always gave me a poorer print.
                      Will post a picture of the difference0_1524604892005_1E4FE3B0-6284-457A-96C5-C61D36EDAA57.jpeg 1_1524604892006_8829D302-24E2-4643-BB1F-4A9BE5A990C4.jpeg
                      Far right is a Slic3r print, the two on left are from Cura, all pictures printed with .2 layer height.
