Mass Dampers
Well I only wonted that you post yours acl and jerk settings. I am just interested in those.
https://www.dropbox.com/s/06um8lldsadv4x4/VID_20180419_204852.3gp?dl=0
Here is my printer printing with travel 550mm/s. Travel acl is set to 5000mm/s and jerk 200mm/min but I need to verify acl and jerk because now I am writing from memory. I hope this is usefully too for OP.
And directly about mass damping I still have an idea in my mind to fill all free space in my printer with epoxy. Something like that https://hackaday.com/2017/03/27/casting-machine-bases-in-composite-epoxy/
@dragonn said in Mass Dampers:
Why didn't you just ask instead of just being rude and saying that my information was useless?
Anyway. Mass in X is around 2.7kgs (2,700 gms) and in Y it is around 4.0kgs (4,000 gms). Printable area is 360mm x 360mm. I have the accelerations set to 2,000 mm/sec^2 for both X and Y. I can go higher but with 4kgs suspended over a metre above the floor, the entire printer can start to rock about a bit because the floor has some "give" in it.
So with acceleration set to 2,000 mm/sec^2 and a distance of 360mm, the maximum speed possible is (sqrt(2 x Acceleration x length/2) = 848.5 mm/sec. The time to reach 300mm/sec is ((Vf-Vi)/a) = 0.15 seconds. The distance travelled to reach 300mm/sec is (1/2at^2) = 22.5 mm.
Sorry, you a right. I could just ask. I checked my settings, acl is like I posted 5000, but jerk is higher X700 Y500. Small BTW it is possible to have different jerk for printing and travel? Like accelerations. Would be a nice idea to have such option.
I didn't give you my jerk settings but for info I currently have them set to 600 for both X and Y but I need to revisit that when I get time. Non print moves tend to be a single straight line move so I don't see any value in having a different jerk setting. I'm not sure it would be possible in any case but I need to think it through.
The biggest improvement of stability I found for the DBot was making the bed a square frame secured front and back on 3 screws. That kept the bed from bouncing as it tends to do on the stock cantilevered design. The wheels and plastic mounts just have too much flex to support much weight.
After that I replaced any plastic part I could with aluminum. Corner plates and brackets. That reduced flex quite a bit. There are no other frame modifications than this.
Aluminum wheel spacers and shims allow for proper tightening of the wheels without binding them. That combined with 3 wheel tensioners keep them nice and tight. No slop.
Then I replaced the idler bearings with actual smooth and toothed idlers. That removed some of the belt vibration. I've tried both steel and glass belt. The glass belt was a bit quieter and had less vibration. The diameter of the toother idlers are still too small to use with the steel belt, but interestingly I've noticed less ringing with the steel belt than with the glass when properly tensioned. I also switched to a carriage with belt tensioners built in which make it much easier to get equal tension on the belts.
The printer sits on a very heavy (300 pounds) bench which was originally designed to be a fish tank stand capable of holding 1000 pounds (double the weight of the tank), so there is no sympathetic vibration in the stand.
Since the Dbot has the XY movement at the top, it tends to wobble a bit. At first I tried to add some weight at the bottom of the frame to clamp it down to the table more. This worked ok, but was louder. Then I sat the printer on some thick dense foam blocks. The printer sways a bit more on fast travel moves, but is far quieter, and ringing seems to be less. It's as if the foam is absorbing the force rather than springing it back, so there's less oscillations.
Travel moves are comfortable up to 220mm/s. I usually keep them to 180, but 250 worked, but felt a little violent. Perimeter and infill print moves up to 150mm/s are doable and I use that for my draft settings. Good quality with no artifacts up to 90mm/s.
I'm still tuning my accell and jerk settings. I think I'm going to switch over to Cura again to have more fine grained control over the jerk and accel settings for different moves. 2000 accel is fine for infill, but for outer walls 500 keeps ringing down while still letting me hit 90mm/s on long walls.
This is all on a 24v setup with 2a 0.9 degree motors with a Titan Aero.
Reducing the mass of the extruder is tempting. The stock Dbot uses a short bowden tube setup and reduces weight compared to direct drive substantially, but all of the carriages I've seen tend to be tall and stick the hotend fairly far out from the plane of the cross bar, whereas the Titan aero carriage i'm using is very short and compact and slings most of the weight directly under the crossbar.
The new CoreXY printer E3D is working on is very interesting. Extreme rigidity from the tooling plate top frame and carbon fiber cross bar and bowden setup for light weight. They haven't really talked much about print speed from what I can see, but I would think it could be quite the mover.
Ha, sorry for the essay, but I've been playing with the Dbot design for the passed year. It's a great design in the stock form and leaves the door open for a lot of improvement. A perfect tinkering platform.
I look forward to see what you come up with on your Dbot.
Thanks for the comments. So so far no one seems to have tried strapping heavy static weights to the top of the frame.
Thanks also for the current settings people are using. I'm on about 450 x/y on jerk and low on acceleration at 1000. I realise the system could be capable of performing faster moves in the x direction but I don't want it to. Parts suffer non-isotropic strength enough already with the weak z. My understanding is that allowing different x and y accel/jerk would mean there would be a subtle difference in the processing of predominantly x or y direction vectors.
My understanding of the print speed issue is the duration of the acceleration (+/-) periods will be greater with higher print speeds. As there is mass in the static system as well as the flex the motion of the head will cause opposing accelerations in parts of the frame the creater the duration the greater the displacement and peak speeds. The mass on the frame aims to reduce the accelerations and so displacement and peak speeds attained.
...and timely reminder abouth the toothed belt running on the smooth bearings. I had wondered about that. I think that is one of the potential causes of a constant amplitude wobble.
Just to add that if the print head and frame move together, then there is unlikely to be a problem. It's only when one moves in relation to the other that there is an issue. When I've been experimenting with high speed tests, throwing 4 kgs around at 300 plus mm/sec, at a height of over a metre above the floor, I've had the entire printer rocking. However, print quality didn't really suffer as the head and frame all rocked together. (Sounds like a concert I once went too ).
@doctrucker my friend did try it https://reprapy.pl/viewtopic.php?f=50&t=1766 (it is not English but I am sure you can interpret it only by looking at the photos). The question is if this helps when you printer frame is rock solid since K8400 is a only an acrylic light weight frame. Did you looked at my post with casting epoxy to dump vibrations?
I appreciate that, but don't have any equipment that I can use to see whether I've got movement of the bed relative to the nozzle so just trying things out and seeing what happens to the ghosting.
Think belt tension wasn't great. Next itteration of the carriage will have a more continuous adjustment. Belts themselves not likely to be class leading either.
No sure if I said it in my first post but essentially trying what the do in washing machines!
@dragonn Thanks for the link. Looks like it made quite some difference for him. The extrusion based core xy are far from rock solid. No triangulation in the frame work so relying on the printed corner pieces to maintain rigidity and they're a balance between needing rigidity and needing to print quick.
Do you mean filling the extrusion voids with epoxy of larger areas within the machine?
@doctrucker my corexy is relay solid solid, I don't have printed corner pieces and additional I have on all corners aluminium corner plates https://www.aliexpress.com/item/Hot-anodized-90-Degree-Joining-Plate-with-5-OR-7-Holes-For-EU-Standard-2020-OR/32818782878.html I think my partial enclose out of dibond add some rigidity too.
And yeah - I mean filling the extrusion voids areas with epoxy. But to be sure - I don't mean the voids inside the extrusion but the space between 2 parallel extrusions when no moving parts interferes.
@deckingman printing speed have complete nothing to do with vibrations, zero. Only acceleration and jerk values have effect on vibration.
Lol what?? Stepper motors have resonant frequencies that cause tons of vibrations at certain constant speeds.
