    Fusion 360 CAM Gcode for DuetWifi
    2.9k
    • Adamfilipundefined
      Adamfilip
      Looking at Reprap code
      Here are some Commands that i dont see in the Duet3D Gcode list so far
      M9
      M8
      These seem to be
      M8: Flood Coolant On (CNC specific)
      M9: Coolant Off (CNC specific)
        Does your CNC machine have a flood coolant facility?
          Adamfilip
          no, this is something i need to disable in the CAM settings,
            RepRapFirmware will warn you if you try to use unsupported GCodes, but other than that they do no harm.
              Adamfilip
              Ok i tried to run the reprap Gcode
              this is the error received
              M32 "RepRap Test 1001.NC"
              File RepRap Test 1001.NC selected for printing
              Error: Bad command: %
              Error: Bad command: [[language]]
              Cancelled printing file RepRap Test 1001.NC, print time was 0h 0m
              Error: G0/G1: outside machine limits
              also under machine control, it says X&Y is not homed
              Can I tell it that current position is home? via a macro?
                You can tell it that the printer has been homed and where the tool head is using the G92 command.
                  Adamfilip
                  no sorry, what i meant was.. can you run a command/macro to tell machine is has already been homed to bypass homing check.
                    T3P3Tony administrators @Adamfilip
                    @adamfilip yes use G92
                    So it when its in the home position, you have the head at X0,Y0,Z0 then use G92 X0 Y0 Z0
                    If you have it homed at a different point adjust G92 as required.
                    • Dougal1957undefined
                      Dougal1957
                      Just what maybe a stupid observation but the Filename you have is .NC could it be that that is throwing it of most files (If not all) that we print have the .gcode extension. Remember that F360 Cam module is meant for CNC Machines rather than printers.
                      Now I may well be way of the mark with the obstacles mind but I thought it worth mentioning David is prob the man to either discount or whatever on the observation.
                      Doug
                        The firmware doesn't care what the file extension is. DWC does care to some extent, for example when presenting you with a file upload dialogue.
                        The "%" character is mentioned in the NIST GCode standard:
                        "The RS274/NGC language has no indicator for the start of a program. The Interpreter, however,
                        deals with files. A single program may be in a single file, or a program may be spread across
                        several files. A file may demarcated with percents in the following way. The first non-blank line of
                        a file may contain nothing but a percent sign, “%”, possibly surrounded by white space, and later
                        in the file (normally at the end of the file) there may be a similar line. Demarcating a file with
                        percents is optional if the file has an M2 or M30 in it, but is required if not. An error will be
                        signalled if a file has a percent line at the beginning but not at the end. The useful contents of a file
                        demarcated by percents stop after the second percent line. Anything after that is ignored."
                        I may change RRF to recognise these %-lines.
