    Prints see reversed
    • gorf26undefined
      gorf26
      Not sure what the problem could be my prints seem to print reversed, when i have the stl file in the slicer it looks fine correct direction. but when i print the file it seems to reverse the direction of the part i printed a part with a nut holder and a tube they should be on the right rear of the part but when printed they are now on the right front of the part.
      could the motors be going wrong direction, it homes right and moves down correct..
      Its on a delta printer did a 11 hour print to find out its backwards and won't work
      Have the latest duet firmware.
      Any suggestions
      Thanks gary
        See https://duet3d.dozuki.com/Wiki/FAQ?revisionid=HEAD#Section_My_prints_come_out_mirrored.
        • gorf26undefined
          gorf26
          Thanks i think i had the motors on the wrong towers
          I now have z in rear x left front y right front.
          X+ moves right Y+ moves towards rear Z tower
          Is that correct?..
          Thanks gary
            That's correct. Make sure you have the endstop switches connected correctly too or you will have problems homing the printer.
            • gorf26undefined
              gorf26
              Ok thanks i did switch the end stops also and it homes ok guess I'll try a print and see how it go's
              Thanks gary
