    Slic3r 1.3.0 finally released. Not the Prusa edition.
    1.5k
      https://github.com/slic3r/Slic3r/releases/tag/1.3.0
      Looks like it has support for direct to Duet printing now?
      • Dr_Ju_Juundefined
        Dr_Ju_Ju
        Careful, its' a Dev build, & I can only get it to talk to the printer using USB.
        For network connection it requires an API ket that the printer needs to generate ??
        Julian,
        Old goat, learning new things….
          No I'm pretty sure this isn't another dev release.
          • DocTruckerundefined
            DocTrucker
            Looks promising. The file name one th git hub doesn't have the revision number that the dev releases from the website have: https://dl.slic3r.org/dev/win/
            That said the last dev release and the 1.3.0 file on github seem to have been posted on the same day. That said a final revision would probably be made to go through some internal test sheets before being released as a final version.
