Firmware 2.0RC1 and 1.21.1RC1 released
Firmware installation
10
39
6.1k
    Printtome3d
    Thanks i have put the old DWC and the board work fine, them i have update the DWC to the new 1.21.1 and now works very well this firmware is the better Version of all i have print with the two Duet WiFi and the result is very good. thank for all
      ShadowX @dc42
      @dc42 said in Firmware 2.0RC1 and 1.21.1RC1 released:
      @shadowx said in Firmware 2.0RC1 and 1.21.1RC1 released:
      My settings all have the Thermostatic control turned off.
      Edit: It seems like you already confirmed that its a bug.
      I updated the firmware using the "upload file" function on the DWC, however, it still shows up as 1.21 after the "update". I uploaded with the older revision of DWC and also the RC1 version and it would not update the firmware. I don't know if others have the same issues with upgrading the firmware. I have the DuetWifi version 1.01 board and tried upgrade using the "Duet2CombinedFirmware.bin" file.
      Is there a different process to upload the RC1 file?
      If you are already running main firmware 1.21 and DWC 1.21 or later, then you should just be able to upload the new Duet2CombinedFirmware.bin file through the Settings/General page of DWC. DWC should then offer to install it.
      I am running 1.21 and using Duet Wifi 1.0 or 1.01. I upload the Duet2CombinedFirmware.bin through the DWC Settings/General/Upload files. It would upload the file and ask me if "You have just uploaded a firmware file. Would you like to update your Duet now?" I press "Yes" to proceed with the update. It goes through the process with the green bar till completion. However, the version stay the same as shown below. I performed this upgrade with the released 1.21 DWC and also the RC1 version shown below with the same results.
      I think this may affect the people still using the original or 1.01 hardware but not the later versions. It would be great if someone else with the same hardware can confirm if this is a bug.
      Firmware Electronics: Duet WiFi 1.0 or 1.01
      Firmware Version: 1.21 (2018-03-21)
      WiFi Server Version: 1.21
      Web Interface Version: 1.21.1-RC1
      Edit: I retried the process by renaming the file as "DuetWifiFirmware.bin" and it worked. It would not work when it was named as "Duet2CombinedFirmware.bin" when I uploaded it. The file in the system editor is now named "Duet2CombinedFirmware.bin". It looks like the DWC or the firmware was looking for that original file name and rejected the update if its not the right filename. The system now shows 2.0(RTOS)RC1 on the software information page.
      Firmware Version: 2.0(RTOS)RC1 (2018-05-02b1)
      undefined 1 Reply Last reply 10 May 2018, 10:40 Reply Quote 0
        rmriggin
        Just updated to the latest 2.0 RC and had a print just stop with no error or message 6 hours into a print. Print looked excellent and came back to it and it was just stopped with print head still over the print like it just stopped in the middle of a layer. The bed and nozzle were not at temp still either. I'll have to lookup the and to pull log and see if it shines any light on what happened.
        undefined 1 Reply Last reply 10 May 2018, 10:48 Reply Quote 0
          dc42 administrators @ShadowX
          It might just mean that you have a very old version of iap4e.bin on the SD card. Try uploading the latest one through DWC.
          undefined 1 Reply Last reply 10 May 2018, 11:07 Reply Quote 0
            dc42 administrators @rmriggin
            @rmriggin said in Firmware 2.0RC1 and 1.21.1RC1 released:
            I'm sorry to hear that you had a crash. It's possible that you hit the bug reported by @BMMal in the second post in this thread. Please can you run M122 and post the software reset data from that report.
            undefined 2 Replies Last reply 11 May 2018, 00:55 Reply Quote 0
              ShadowX @dc42
              iap4e.bin
              I still had the original iap4e.bin file from 6/11/2016. I didn't realize I had to update that until I looked at the bottom of the 1.21 which mentions the iap4e.bin should be revised also. Thanks.
              undefined 1 Reply Last reply 10 May 2018, 11:10 Reply Quote 0
                iap4e.bin
                Thanks for confirming. The original iap4e.bin file had the firmware filename hard coded as "DuetWiFiFirmware.bin". Later versions use the filename passed to them by the firmware that is being replaced.
                undefined 1 Reply Last reply 10 May 2018, 11:11 Reply Quote 0
                  ShadowX @dc42
                  iap4e.bin
                  I just did a quick test with the old iap4e.bin and it won't take the 2.0RC1 update. As soon as I updated the file to the latest one from 1.21, the update worked perfectly. Thanks for all your help. Hopefully, this will help someone else if they have not updated that file.
                    rmriggin @dc42
                    @dc42 misread the command and did a M112 which cleared log so I guess I won't know what caused that print failure.
                      ayudtee
                      @dc42, I am pleased that you have created another release for the SAM3XA boards. I have a duet 0.8.5 on an Ormerod 2, and I installed 1.21.1. Unfortunately it noticeably slowed down the printer. I only ran a few prints on 1.21.1RC1 before I downgraded back to 1.21. I read in your post that released 2.0RC2 that you had not received any feedback on 1.21.1RC1 and apologize for not responding days ago. I also read that you have upgraded your Ormerod to a Maestro. If you would like any further followup feedback or testing on 1.2.1RC1 or anything else, my Ormerod 2 and I are at your disposal Sir.
                        rmriggin @dc42
                        @dc42 it happened again at the same height into a print (25mm)
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC1 running on Duet Ethernet 1.02 or later
                        Board ID: 08DDM-9FAMU-JW4S4-6JKD4-3SJ6R-92YRV
                        Used output buffers: 3 of 20 (9 max)
                        Static ram: 28484
                        Dynamic ram: 95388 of which 16 recycled
                        Exception stack ram used: 324
                        Never used ram: 6860
                        Task NETWORK ready, free stack 448
                        Task HEAT blocked, free stack 1260
                        Task MAIN running, free stack 3800
                        Last reset 07:41:11 ago, cause: software
                        Last software reset at 2018-05-11 01:00, reason: Hard fault, spinning module GCodes, available RAM 6516 bytes (slot 3)
                        Software reset code 0x4033 HFSR 0x40000000, CFSR 0x00010000, ICSR 0x0441f803, BFAR 0xe000ed38, SP 0x200049dc
                        Stack: 00444d4f 00424f82 61000000 0042afda 21000000 0000000a 20000180 200001e0 00000000 000000f8 00000000 00000000 2000b3c8 2000a480 00000000 000000f8 20004cf4 a5a5a5a5 a5a5a5a5 a5a5a5a5 00424fc3 2000b3c8 0042afe1 00000000
                        Error status: 0
                        Free file entries: 10
                        SD card longest block write time: 0.0ms
                        MCU temperature: min 46.2, current 46.7, max 54.8
                        Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
                        Date/time: 2018-05-11 08:41:38
                        Slowest main loop (seconds): 0.006040; fastest: 0.000069
                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                        Bed compensation in use: mesh
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        HTTP sessions: 1 of 8
                        Interface state: 5
                        === Expansion ===
                        undefined 1 Reply Last reply 12 May 2018, 07:03 Reply Quote 0
                          M122
                          ...> Last reset 07:41:11 ago, cause: software
                          Thanks, that is indeed the same fault that was already reported, and is fixed in RC2. Please try 2.0RC2.
                          undefined 1 Reply Last reply 12 May 2018, 08:41 Reply Quote 0
                            dc42 administrators @dc42
                            Now that RC2 is released I am closing this topic. I moved the post by @carlosspr to the RC2 thread.
                            36 out of 39
