    Firmware 2.0RC2 released
    Firmware installation
    19
    45
    5.8k
    • wilrikerundefined
      wilriker
      DHT sensor support?! That sounds cool, especially as I have at least one of them laying around. How would they get connected? And is there any use-case already? I could imagine measuring humidity in a filament dry-box. Any other ideas?
      Manuel
      My Tool Collection
      resamundefined 1 Reply Last reply Reply Quote 0
      • resamundefined
        resam @wilriker
        @wilriker DHT support is available since a few releases ago!
        You can use M305 to configure two new channels for temp and humidity:
        Channels 400, 401... are DHTxx temperature and humidity channels. The DATA line of the DHTxx must be connected to CS6 (was E3 Endstop on the expansion header) on the Duet WiFi/Ethernet. Specify the sensor type (11 for DHT11, 21 for DHT21 or 22 for DHT22) via the T-parameter
        whosrdaddyundefined 1 Reply Last reply Reply Quote 0
        • mperdueundefined
          mperdue
          I tried installing this but now things don't work.
          The software information shows:
          Firmware Electronics: Duet WiFi 1/02 or later + Duex5
          Firmware Version: 2.0(RTOS)RC2 (2018-05-10b1)
          WiFi Server Version: 1.21
          Web Interface Version: 1.21.1-RC4
          I can activate the bed and the extruder heater but I can't move in any axis.
          Anyone have any ideas what I may have done wrong?
            dc42 administrators @mperdue
            @mperdue said in Firmware 2.0RC2 released:
            Were you already running firmware 1.21 ? If not then read the upgrade notes for version 1.21 and any other stable versions that you skipped.
            • whosrdaddyundefined
              whosrdaddy @resam
              @mperdue: in newer firmwares, you can only moves axes when they are homed.
              If you want to revert to the original behavior, add M564 H0 to your config.g, or else you will need to add S2 to your G1 commands to allow movement on a non homed axis...
              • mperdueundefined
                mperdue
                I had skimmed the release notes prior to updating but, obviously, I need to read them more closely. The movement comments certainly address the immediate issues I was having but I think I’ll read everything before I do it again. Thanks guys.
                • carlossprundefined
                  carlosspr
                  Same for me. At some point the Web Interface lost connection and the print stopped. I was able to access the board via Telnet and generate an M122, but several atpempts needed before gettign the log because the Telnet would close connection before dumping all information.
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC2 running on Duet WiFi 1.02 or later
                  Board ID: 08DDM-9FAM2-LW4S4-6J1D8-3SJ6M-TMVZY
                  Used output buffers: 2 of 20 (8 max)
                  Static ram: 28564
                  Dynamic ram: 96048 of which 0 recycled
                  Exception stack ram used: 288
                  Never used ram: 6172
                  Task NETWORK ready, free stack 1408
                  Task HEAT blocked, free stack 1256
                  Task MAIN running, free stack 3804
                  Last reset 00:01:23 ago, cause: software
                  Last software reset time unknown, reason: Hard fault, spinning module Platform, available RAM 5864 bytes (slot 3)
                  Software reset code 0x4030 HFSR 0x40000000, CFSR 0x00000400, ICSR 0x0041f803, BFAR 0xe000ed38, SP 0x20005004
                  Stack: 0040b539 00433b84 01000200 f8000000 406e386f 3edb6db7 b7b4d800 3e178897 3e1cd04f 41700000 3e23e0ac 3e3a4c97 3e63a87e 3e9258c9 3cd1cfc0 3f317180 3f800000 60000000 40382d26 60000010 004448bb 20005070 200050b8 00000001
                  Error status: 0
                  Free file entries: 10
                  SD card longest block write time: 0.0ms
                  MCU temperature: min 37.5, current 37.7, max 38.0
                  Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
                  Slowest main loop (seconds): 0.010376; fastest: 0.000075
                  Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                  Bed compensation in use: none
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2) Telnet(0)
                  HTTP sessions: 0 of 8
                  • WiFi -
                    Network state is running
                    Failed to get WiFi status
                    Socket states: 2 0 0 0 0 0 0 0
                    === Expansion ===
                  dc42undefined 2 Replies Last reply Reply Quote 0
                  • mperdueundefined
                    mperdue
                    OK, I've reloaded and gotten things moving again so I'm working on my homely.g file now. In the previous releases I've run I would start the home sequence by moving both the X and Y towards the origin simultaneously, then I would fine home each of them separately. I don't seem to be able to move them both at the same time anymore but I can live with that. A bigger issue is that I would also fast home the Z and then fine home it. I'd do this my moving the X and X to the center of the bed and then moving the Z at a reasonable speed toward the bed. Then I'd back off and do the actual probe.
                    The code I used
                    M401 ; Deploy probe
                    G1 Z-999 F1000 S1 ; Course home Z Only
                    G1 Z5 F1000 ; Back off home location
                    M401 ; Deploy the probe
                    G30 Z-300 S0 ; Probe Z
                    The G1 using the S1 no longer seems to work as it did so this script no longer works. The G30 works well but it is very slow so if the machine was shut down with the bed at Z 250 it will take a very long time to probe the Z. Is there something I'm doing wrong here?
                    On the plus side I no longer have to tell it to deploy the probe since the BLTouch now has a unique definition and is handled properly.
                      You should still be able to home X and Y concurrently initially, nothing has been changed in that respect.
                      Your method of Z homing is unusual. Normally you would use either a G1 S1 Z move and a homing switch, or a G30 Z probe, not both. But either of the following methods should still work if you want to do fast then slow Z homing:
                      1. Tell the firmware that the Z endstop (for the G1 S1 Z command) is the Z probe, by using M574 Z1 S2 in config.g.
                      2. Use G30 to do the fast Z homing instead of a G1 S1 Z move, but use an extra M558 command to temporarily increase the probing speed (F parameter in M558).
                      mperdueundefined 1 Reply Last reply Reply Quote 0
                      • Cataundefined
                        Cata
                        What is that? need a not-maestro explanation
                        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                        • okerchoundefined
                          okercho
                          Hi, I just installed the RC2 and from the interface I'm not able to shutdown the heater, it turned on automatically (at 0ºC for active and standby temp) and if I try to "control all, turn everything off" or to switch from active to standby (from the interface) it does nothing, but I can switch from active from standby in the paneldue though.
                          In the console I see this "G10 P0 R-273.15 S-273.15", but nothing changes.
                          I think nothing changed at heater config level between 1.21 and this RC, right? (at least, I didn't see it...)
                          Anyone else sees the same?
                          Regards
                          Okercho
                          Custom Prusa i3 Hephestos with Duet Wi-Fi
                          E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                          Rebuilding Hypercube Evolution
                          • mperdueundefined
                            mperdue @dc42
                            I've changed my Z homing code to work as in your second option and it works well. However, I've decided to disable the functionality for now using M564 H0. I'll revisit this after I get a few print jobs completed and I can give it my full attention.
                            • JohnOCFIIundefined
                              JohnOCFII @Cata
                              @cata This is a 12864 display.
                              https://www.amazon.com/Sintron-Graphic-Display-Controller-Printer/dp/B06WP8BSBB
                              Cataundefined 1 Reply Last reply Reply Quote 0
                              • Cataundefined
                                Cata @JohnOCFII
                                @johnocfii Yes, i know. But, can we have that on the duets?
                                  JohnOCFII @Cata
                                  @cata said in Firmware 2.0RC2 released:
                                  I looked into this a bit a year or so ago. My understanding is that it would require another board to supply the smarts that are in the PanelDue displays in between the Duet and the 12864. With that level of hassle and expense, it would be easier to just get the PanelDue if you wanted a display. At least -- that is what I remember. I decided not to pursue a display.
                                  • Cataundefined
                                    Cata @JohnOCFII
                                    @johnocfii You are wrong, i see the full graphics display with a 2 usd wemos working in the duet. Total cost = 10 usd. I want to know how is working in the maestro.
                                      On the Duet Maestro we included 2 more 10-pin ribbon cable sockets and and extra chip to gate and convert the SPI bus to 5V, so that we can support 12864 displays. We did that on the basis that someone buying a budget board would be more likely to want to use a budget display.
                                      To do the same on the other Duets you would need an adapter that plugs into the daughter board connector and the CONN_SD connector, to provide the gating and level shifting.
                                        dc42 administrators @dc42
                                        @dc42 said in Firmware 2.0RC2 released:
                                        Another type of budget display that works with all Duets is an old smartphone running DWC.
                                        mickey30mundefined Cataundefined 2 Replies Last reply Reply Quote 2
                                        • wilrikerundefined
                                          wilriker
                                          I upgraded to 2.0RC2 and currently my second print is running perfectly fine so far.
                                          Only thing I realized was that after upgrading I did not reset the Duet (would that have been recommended anyway?) and when running a G29 (no Z probe, so manually adjusting via DWC buttons) movement commands where heavily delayed. So when clicking on a button to move Z up/down sometimes this was instantaneously and sometimes it would take up to several seconds for the printer to react. I have not reset the Duet afterwards and I have not yet tried this again (I will likely do it tonight or tomorrow as I have to move the printer again).
                                          If you tell me that this is something that can be expected when upgrading firmware and not doing a reset then you can ignore this one. 😉
                                          Manuel
                                          My Tool Collection
                                          • mickey30mundefined
                                            mickey30m @dc42
                                            @dc42 where stands dwc for. A Google search on dwc telephone dont give any good results
                                            dragonnundefined 1 Reply Last reply Reply Quote 0
