    Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?
    141
    29.3k
    • mindbender9undefined
      mindbender9
      @dc42 @c310
      I following your instructions and the Z-probe did the same exact steps as before. The same "Error: Z probe was not triggered during probing move" errors appeared (one for each point).
      I should note that this is the stock Z-probe that I'm using (it came with the Anycubic Kossel Linear Plus):
      I did not run M500 to store the results since the probe was clicking while airborne (3cm above the bed). I don't know why this is happening - do you need to see any of my config files?
      It's not the stock Z-probe that's clicking, because it's dead. The loud clicking is actually coming from either the diagonal arms which are fighting the movement, or the hot-end hardware as it's being moved toward the outer edge of the platform.
      Either way, this isn't good. Something is wrong with either the configurations or the hardware. Way to go, Anycubic3d...
      I'm stumped.
        dc42 administrators @mindbender9
        @mindbender9 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
        @dc42 @c310
        I'm stumped.
        What do you mean by "the probe was clicking while airborne" ? Have you tested the z probe and its configuration? See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
          mindbender9
          It looks like the Z-probe doesn’t respond or stop if I attempt a Dynamic Test from the link above. The repeated contact with the bed at high speeds must’ve damaged it. I’m also looking at the damage to the surface of the bed, and I have to ask: Is this all typical for new Duet board owners?
          Moving ahead - Is there a way to calibrate this printer without the use of a Z-probe? And if so, how?
          I’m trying to make the most of this, but This is all very discouraging.
          3mmundefined 1 Reply Last reply Reply Quote 0
            Hads the probe ever worked with the Duet? If not then it's probably a wiring or configuration issue.
            You can do manual configuration as long as you are running fairly recent firmware. Set Z probe type 0 (that's P0 in the M558 command in config.g) to tell the firmware that you have no Z probe. Then run G31 as usual. The web interface will prompt you.
            mindbender9undefined 1 Reply Last reply Reply Quote 0
            • Danalundefined
              Danal
              You can also make a probe for a couple of dollars/pounds, if you have access to a printer that works. (Check local libraries and maker organizations).
              https://www.thingiverse.com/thing:1976680
              And a microswitch, which are available from MANY channels. Here's what I did on an Anycubic that was old enough to have not shipped with a probe (non Duet board... but the switch holder and stuff is still good knowledge).
              http://danalspub.com/2017/11/upgrading-an-anycubic-kossel-to-marlin-1-6-6/
                mindbender9 @dc42
                Hi DC. I'm not sure if the stock probe has ever worked from the beginning with either board, so I've ordered your DC42 IR sensor to continue this setup with. Your video on the IR sensor convinced me to purchase it, but I'm hopeful that its install will be easier.
                In the meantime, I'll attempt the manual configuration with Z probe type 0 and see what happens (when I get home).
                Question: If I run G31 (after setting the Z probe type to 0), will I have to save any settings or alter the config,g file with any values? If so, where are those values found?
                Thank you for your continued help.
                  mindbender9 @Danal
                  @danal
                  I've decided to upgrade to an IR sensor, but I appreciate your help.
                  Best regards and many thanks!
                  P.S. Your BFD delta is something else. Do the mag arms make a difference performance-wise?
                  • Danalundefined
                    Danal @mindbender9
                    @mindbender9 Yes, the mag arms are a HUGE benefit to almost any delta.
                    In this picture, which is "side light" to massively highlight flaws, the bottom piece was printed on a stock Anycubic Kossel Linear. The top is the exact same printer, nothing changed except upgraded to Hayden Huntley magnetic-end arms. Literally the same G-Code file, reprinted. Same filament.
                      I think you mean G32 not G31. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Saving_the_calibration_results.
                      mindbender9undefined 2 Replies Last reply Reply Quote 0
                        mindbender9 @dc42
                        I should be receiving the DC42 IR Sensor on this Monday. Do you have any tips or suggestions for installing/configuring it (on my Anycubic Kossel)?
                        Thanks!
                          I don't know the AnyCubic, but mount it as close to the nozzle as possible, make sure that the back of the sensor PCB can't short against anything, and connect it as described at https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe.
                            mindbender9
                            ANYONE -
                            Q1 - Does anyone know what kind of hot-end comes with the Anycubic Kossel Linear Plus? I hear it's a E3D V5 (thanks Teel!)
                            Q2 - Does anyone have a suggestion on how to correctly mount the DC42 IR Sensor to the Anycubic Kossel Linear Plus that does not involve printing something since I can't print anything?
                            There is no place to vertically screw/attach the IR Sensor to on the stock hot-end. Therefore, I am stuck with a non-printing delta printer and an IR Sensor that cannot be mounted without a printed part to attach the sensor to.
                            I should have seen this coming.
                            @dc42 - If you design both the Duet board and the IR Sensor, why didn't you make the connector a 4-pin connector by default (to match the Duet's 4-pin Z-probe connector)? Just wondering, because I have to decide whether to splice a 4-pin connector end to the IR Sensor probe.
                              mindbender9 @dc42
                              @dc42 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
                              @dc42 - Actually, I got the G31 from your instructions a few entries above. See:
                              So what would be the best way to do a manual calibration with P0 in the M558 command?
                                There isn't room on the IR sensor PCB to fit a Molex connector. Also the IR sensor doesn't only work with the Duet.
                                My mistake, I meant G32.
                                  mindbender9
                                  So here's what's happening, as of Monday night:
                                  • Still can't print. The nozzle remains roughly 5-10cm off the bed, so it literally dumps filament onto the bed and let's it pile up. It doesn't look like the nozzle moves vertically as the printing progresses, so it ends up pushing the print around the bed. The PLA remains soft and mushy.
                                  • Cannot auto-calibrate. I need the IR Sensor to be mounted, and it's not mounted because I can't print a mount. Sounds like a Catch-22.
                                  • Manual calibration doesn't seem to help, because I can do the 2-paper test and printing is still screwy. Nothing changes.
                                  Any suggestions? Anything?
                                  elmoretundefined 1 Reply Last reply Reply Quote 0
                                    You can "auto calibrate" manually as I tried to explain in my earlier reply. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer. The online configurator can generate the bed.g file for you.
                                    • elmoretundefined
                                      elmoret @mindbender9
                                      This is an expected result if calibration has not been performed properly.
                                      Would recommend either sending me an STL to print for you, or sending STL to Shapeways.
                                      A video of the manual calibration being performed would be helpful, so we can spot anything being done incorrectly.
                                      I'd also recommend checking that the IR sensor is working properly, so you don't become frustrated when you get the mount in. Wire it up per the instructions and check that the LED illuminates when you hold a piece of paper in front of it, and also check that the z-probe value in Duet Web Control changes accordingly.
                                      • Danalundefined
                                        Danal
                                        To get the very first prints, perform manual probing. This is a pain... be meticulous and patient...
                                        1. M558 must have P0. This says there is no probe. Reboot after changing this.
                                        2. Issue a G32 (or use the web "Auto Delta Calibration")
                                        3. This pop up will appear in the web interface:
                                        Use the controls to adjust until a business card "drags" between the nozzle and the plate. Then click OK.
                                        Repeat for each point.
                                        1. When complete, do an M500 to save. (Be sure there is an M501 near the end of your config.g to load)
                                        Just for fun, you may want to do a M665 before and after, to see what changed.
                                          mindbender9 @elmoret
                                          @elmoret
                                          Thank you for the tips. I will attempt to manually calibrate before testing the IR sensor. I appreciate your help. Thanks again.
                                            mindbender9 @Danal
                                            @danal
                                            Thank you for your steps. I performed two of the manual probes and received the following results when typing M665:
                                            Attempt #1:
                                            M665
                                            Diagonal 271.000, delta radius 134.000, homed height 745.351, bed radius 85.0, X 0.000°, Y 0.000°, Z 0.000°
                                            A print attempt resulted in the nozzle positioning itself from the top of the printer (near "home") and dripping filament until I halted the print.
                                            Attempt #2 Results:
                                            M120
                                            G91
                                            G1 Z-10 F6000
                                            M121
                                            Calibrated 3 factors using 4 points, deviation before 286.144 after 1.67
                                            M665
                                            Diagonal 271.000, delta radius 134.000, homed height 459.464, bed radius 85.0, X 0.000°, Y 0.000°, Z 0.000°
                                            I don't understand why the "homed height" values are so large.
                                            The second attempt to print after another calibration resulted in the same print from the top of the printer. I halted this print as well - here is a screenshot of the web interface at the time:
                                            Any idea why these manual calibrations are resulting in prints from the top of the printer? What did I miss?
