Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?
141
28.9k
    mindbender9 @dc42
    @dc42 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
    I think you mean G32 not G31. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Saving_the_calibration_results.
    @dc42 - Actually, I got the G31 from your instructions a few entries above. See:
    You can do manual configuration as long as you are running fairly recent firmware. Set Z probe type 0 (that's P0 in the M558 command in config.g) to tell the firmware that you have no Z probe. Then run G31 as usual. The web interface will prompt you.
    So what would be the best way to do a manual calibration with P0 in the M558 command?
      dc42 administrators @mindbender9
      @mindbender9 said in Beginner Needs Help - Anycubic Kossel Plus + Duet WiFi -- HOW?:
      @dc42 - If you design both the Duet board and the IR Sensor, why didn't you make the connector a 4-pin connector by default (to match the Duet's 4-pin Z-probe connector)? Just wondering, because I have to decide whether to splice a 4-pin connector end to the IR Sensor probe.
      There isn't room on the IR sensor PCB to fit a Molex connector. Also the IR sensor doesn't only work with the Duet.
      My mistake, I meant G32.
        mindbender9
        So here's what's happening, as of Monday night:
        • Still can't print. The nozzle remains roughly 5-10cm off the bed, so it literally dumps filament onto the bed and let's it pile up. It doesn't look like the nozzle moves vertically as the printing progresses, so it ends up pushing the print around the bed. The PLA remains soft and mushy.
        • Cannot auto-calibrate. I need the IR Sensor to be mounted, and it's not mounted because I can't print a mount. Sounds like a Catch-22.
        • Manual calibration doesn't seem to help, because I can do the 2-paper test and printing is still screwy. Nothing changes.
        Any suggestions? Anything?
        undefined 1 Reply Last reply 22 May 2018, 14:02 Reply Quote 0
          You can "auto calibrate" manually as I tried to explain in my earlier reply. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer. The online configurator can generate the bed.g file for you.
          undefined 1 Reply Last reply 22 May 2018, 18:33 Reply Quote 0
            elmoret @mindbender9
            This is an expected result if calibration has not been performed properly.
            Would recommend either sending me an STL to print for you, or sending STL to Shapeways.
            A video of the manual calibration being performed would be helpful, so we can spot anything being done incorrectly.
            I'd also recommend checking that the IR sensor is working properly, so you don't become frustrated when you get the mount in. Wire it up per the instructions and check that the LED illuminates when you hold a piece of paper in front of it, and also check that the z-probe value in Duet Web Control changes accordingly.
            undefined 1 Reply Last reply 22 May 2018, 17:59 Reply Quote 0
              Danal
              To get the very first prints, perform manual probing. This is a pain... be meticulous and patient...
              1. M558 must have P0. This says there is no probe. Reboot after changing this.
              2. Issue a G32 (or use the web "Auto Delta Calibration")
              3. This pop up will appear in the web interface:
              Use the controls to adjust until a business card "drags" between the nozzle and the plate. Then click OK.
              Repeat for each point.
              1. When complete, do an M500 to save. (Be sure there is an M501 near the end of your config.g to load)
              Just for fun, you may want to do a M665 before and after, to see what changed.
              undefined 1 Reply Last reply 22 May 2018, 18:14 Reply Quote 0
                mindbender9 @elmoret
                @elmoret
                Thank you for the tips. I will attempt to manually calibrate before testing the IR sensor. I appreciate your help. Thanks again.
                undefined 1 Reply Last reply 23 May 2018, 09:30 Reply Quote 0
                  mindbender9 @Danal
                  @danal
                  Thank you for your steps. I performed two of the manual probes and received the following results when typing M665:
                  Attempt #1:
                  M665
                  Diagonal 271.000, delta radius 134.000, homed height 745.351, bed radius 85.0, X 0.000°, Y 0.000°, Z 0.000°
                  A print attempt resulted in the nozzle positioning itself from the top of the printer (near "home") and dripping filament until I halted the print.
                  Attempt #2 Results:
                  M120
                  G91
                  G1 Z-10 F6000
                  M121
                  Calibrated 3 factors using 4 points, deviation before 286.144 after 1.67
                  M665
                  Diagonal 271.000, delta radius 134.000, homed height 459.464, bed radius 85.0, X 0.000°, Y 0.000°, Z 0.000°
                  I don't understand why the "homed height" values are so large.
                  The second attempt to print after another calibration resulted in the same print from the top of the printer. I halted this print as well - here is a screenshot of the web interface at the time:
                  Any idea why these manual calibrations are resulting in prints from the top of the printer? What did I miss?
                    mindbender9 @dc42
                    @dc42 - Thank you for replying. I appreciate your help.
                    I completed two manual calibrations (M558 P0 X0 Y0 Z1 H5 F1000 T5000 I1) and had very odd results. The nozzle attempted to print from tall heights.
                    • I have to admit that I have a difficult time following the Duet wiki. Although American English is my only language, the wiki comes across as engineer's notes rather than howto instructions. I realize that a failure to understand is my problem, but I can't grasp what I'm supposed to do. Still trying, though.
                    • I used the Online Configurator to recreate the bed.g file:
                    ; generated by RepRapFirmware Configuration Tool on Sun May 13 2018 19:16:40
                    G31 X0 Y0 ; don't want any probe offset for this - ADDED 5/21/2018
                    G28 ; home the printer
                    M401 ; deploy the Z probe
                    G30 P0 X0.00 Y85.00 Z-99999 H0
                    G30 P1 X73.61 Y-42.50 Z-99999 H0
                    G30 P2 X-73.61 Y-42.50 Z-99999 H0
                    G30 P3 X0 Y0 Z-99999 S3
                    M402 ; retract the Z probe
                    G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
                    Thanks again for the help.
                      Dougal1957
                      try generating a new bed.g file using DC42 Bed file generator use at least 10 points and select 6 factor (or even change the s6 in the generated output to S8)
                      also rather than use m500 to store the values in eprom I would run the routine at least twice then send M665 and M666 and graft the resultant figures into your Config.g. I learnt a long time ago that useing the EEPTOM type setting can lead you seriously astray when something changes for example if you change something in your config.g and that part is also in the config-override then the override will take priority when you run M501 to retrieve it. Can leave you scratching your head.
                      You could of course still use M500 to save the results and then cut and paste the two lines back to your Config.g and then delete the override file to save you falling into that trap.
                      HTH
                      Doug
                        Are you sure that you have the correct X, Y and Z steps/mm set in config.g? The common values for a delta printer with GT2 belts are:
                        1.8deg motors, 20 tooth pulley: 80 steps/mm
                        1.8deg motors, 16 tooth pulley: 100 steps/mm
                        0,9deg motors, 20 tooth pulley: 160 steps/mm
                        0.9deg motors, 16 tooth pulley: 200 steps/mm
                        undefined 1 Reply Last reply 23 May 2018, 10:37 Reply Quote 0
                          mindbender9 @dc42
                          Hi @dc42.
                          I believe these are 1.8 deg motors. But I apologize, I don't know what a tooth pulley is or where it's located on the printer.
                          Trying to google-fu the part, but not seeing it.
                            The pulleys I am referring to are on the stepper motor shafts. Each one will have 16 or 20 teeth on it - or just possibly 18.
                            You can check that the steps/mm is correct. Home the printer, then send G91 followed by G1 Z-100. The effector should move down 100mm. If it moves some other distance, you have incorrect steps/mm set in config.g.
                              Danal
                              @mindbender9 in your first post, it shows your config.g contains M92 X80 Y80 Z80 E663 ; Set steps per mm Double check that this has not changed, because I believe this is probably correct.
                              I have an Anycubic Kossel Linear (NOT plus) and it has 1.8 motors and 20 tooth pulleys, resulting in 80 steps per mm. 80 per mm works correctly in the Marlin/Trigorilla native printer (along with a 16 microstep setting).
                              As an aside, your steps/mm for your extruder look odd to me. My Anycubic is set to 96. Please note this is NOT your problem with movement/homing/probing... and you can check this later... just mentioning it because we are looking at M92.
                              As David said, be sure and home, then command a 100mm move and measure the results, just to be sure.
                              G28
                              G91
                              G1 Z-100
                              undefined 2 Replies Last reply 24 May 2018, 03:32 Reply Quote 0
                                mindbender9 @Danal
                                @dc42 and @danal,
                                When I enter G28, the printer arms rise to the top and stop. G91 does nothing.
                                When I enter G1 Z-100, nothing happens and the arms remain in place at the top of the printer. No errors are registered in the G-code Console.
                                One interesting thing is the "Head Position" for all three axis are set at "9999.9" after homing. Would this be related?
                                Here's my config.g for reference:
                                ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                                ; generated by RepRapFirmware Configuration Tool on Sun May 13 2018 19:16:40 GMT-1000 (Hawaiian Standard Time)
                                M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                                ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
                                M665 R134 L271 B85 H285 ; Set delta radius, diagonal rod length, printable radius and homed height
                                M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
                                M550 Pduettest
                                M552 S1 ; Enable network
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Disable FTP
                                M586 P2 S0 ; Disable Telnet
                                M558 P0 X0 Y0 Z1 H5 F1000 T5000 I1 ; Set Z probe type to MANUAL and the dive height + speeds
                                G31 X0 Y0 Z0 P100 ; Set Z probe trigger value, offset and trigger height
                                M557 R130 S20 ; Define mesh grid
                                M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
                                M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
                                M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
                                M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 Z0 S1 ; Set minimum Z
                                M574 X2 Y2 Z2 S1 ; Set active high endstops
                                M305 P0 T100000 B4267 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                                M305 P1 T100000 B4267 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                                M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M563 P0 D0 H1 ; Define tool 0
                                M501
                                undefined 1 Reply Last reply 24 May 2018, 07:02 Reply Quote 0
                                  mindbender9
                                  I have to ask: Is there a particular order or hierarchy for G-codes in the configuration files? Could that be a cause for the weird results/actions?
                                    Yes! it means that the parameters in your M665 and M666 commands are mechanically impossible. What M665 and M665 commands do you currently have in config.g? Check that they are not being overridden by other commands in config-override.g.
                                      mindbender9
                                      Hi @dc42
                                      My config.g has the following values for M665 and M666:
                                      M666 X0 Y0 Z0
                                      My config-override.g file (which I had no idea existed) has the following values:
                                      ; Delta parameters
                                      M665 L271.000 R134.000 H1032.754 B85.0 X0.000 Y0.000 Z0.000
                                      M666 X250.573 Y79.532 Z-330.105 A0.00 B0.00
                                      ; Heater model parameters
                                      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                      I’m guessing that those wild numbers in the config-override.g file should not be there? Should their M665 and M666 values match the config.g G-code values?
                                        The values in config-override.g were written when you ran M500 after auto calibrating. I suggest you delete them and restart the Duet. When you have auto calibration working well and you no longer have those 9999.9 values for the axis positions, you can run M500 to save the new values to config-override.g.
                                        It is the M666 values in config-override.g that are causing the problem.
                                        undefined 1 Reply Last reply 24 May 2018, 09:32 Reply Quote 0
                                          mindbender9 @dc42
                                          With your advice, I did a manual 6 point calibration using the paper test. I'm now able to do a test print of a 1-layer circle, but it's really ragged and rough. It's not pretty, but it's my first print and I'm psyched!
                                          I'll have to figure out how to clean this up and fine-tune it a little more before printing the IR sensor bracket (my first real 3D printing project).
                                          With all honesty, you and the forum contributors made it possible for me to get this far. Thank you very much for this breakthrough, David/@dc42.
                                          This is a great start, and I appreciate everyone's help!
                                          35 out of 141
