Extra axies not interpolatedduring G2 and G3 moves
1.7k
    Kulitorum
    Extrusion works, but U interpolation does not work.
    Changing XY jerk makes no difference, but changing acceleration does.
    Kulitorum
    undefined 1 Reply Last reply 22 May 2018, 14:24 Reply Quote 0
      dc42 administrators @Kulitorum
      @kulitorum said in Extra axies not interpolatedduring G2 and G3 moves:
      Kulitorum
      Can you give me a small example of the sort of G2 or G3 move with U movement that you are making? I was planning to do a release later this afternoon but I'll try to fix this issue first when I am sure I understand what it is.
        Kulitorum
        I assume you are doing some kind of piecewise linear move, and if you use the start AND end position of each piece, you will get double coords (end is the same as start) and this leads to constant acceleration and deacceleration. Maybe you just need to use the end points and this will fix it?
        Kulitorum
          Kulitorum
          G1 x0 y0
          g2 x000 y1000 i00 j500 u9000 e9 f6000
          undefined 1 Reply Last reply 22 May 2018, 15:00 Reply Quote 0
            Kulitorum
            After a demo of x and y axis, I execute the G2 command I pasted here:
            https://youtu.be/g3Q2_Sx2frY
              G1 x0 y0
              What was the U coordinate before you executed that command?
              EDIT: ignore that, I found the problem.
                Kulitorum
                Any progress?
                Kulitorum
                  whosrdaddy
                  I believe @dc42 fixed this problem in 2.0RC5...
                    Kulitorum
                    Just tested RC5, the missing axis problem has been fixed.
                    Thanks
                    Michael
                      Thanks for confirmation.
                      15 out of 15
